456 -
Content Type
Profiles
Forums
Gallery
Everything posted by kkk4
the circle of aluminum was removed?
swap is of little importance the swap does not make sense. certainly the nightshade v2 will be better, but the potential will be calculated differently
great job expect the production of these new monsters
really good line! congratulations to Jacob because he did an excellent product, economic and valid! We look forward to 15 "
pics?
I post two videos of our car, with two saz-3500D the machine was created just to play music But he also made two measurements in the race, 155db in spl regular, 153.9 db on average musical
Subwoofers are these: http://www.ciare.com/consumer/popup29_01_2010/CSW8000.pdf Coil 100mm 2x2ohm high temperature neodymium magnet type if you sponsor 4 subwoofer, the owner will be happy hahahahah
olèèèèèèèèèèèèèèè :woot: :woot: I'm happy ... expect pictures of the product and recone
2 channel no?
yes, in fact jacob should see its sales, and then decide what to build it is normal to build products based on its sales my staff had a thought, since in Italy were estimated 1000 class AB high power by one company in 1 calendar year
I did several tests with the new configuration but the result is always very low. there is to say that the machine is still very difficult to get sound in spl ... for now let us stand on this car But I can say with assurance that the subwoofer is really good!!!!!! behave very well and are very resistant vote 10! I hope to do other tests on future configurations for play music
I can only say that in Italy, a company such as GT Trading, manufacturing line STEG amplifiers, sold a bunch of amps class a / b power high. amplifier has to 700euro 1200euro and market our products at the top. companies like Ground Zero, had similar amplifiers, also cost half the price and are selling a lot. many companies are coming out of producing high power class AB and the prices are not very prohibitive, the zenon, produces among its 500x2 amp seems in Italy is the fashion of "fronts to scream", AB amplifiers that require well-sounding, and high power... also installing 8 medium-low per port, more 2-3 compression tweeter find a flood of video each of these cars, install 1-2-3 amplifiers of this kind only for the front this is my old car 5 Class AB amplifiers, pulling 800x2 watt RMS at 1ohm is full of these cars in Italy Examples of amplifiers: Steg K2.04 - Amp Guts (1200x2 at 1ohm) Steg K2.03 - Amp Guts (800x2 at 1ohm) Steg QM 310.2x - Amp Guts (800x2 at 1ohm) :: Ground Zero :: Amplifier / GZNA 2800XII (2x1200 at 1ohm) Mosconi - AS300.2 thousands are sold in Italy if they are good products
I go directly to SAX-500.2 In Europe there is the boom in low-average number of installations in the door, and good sounding Class AB, and stable to 1ohm would be ideal ... here is full of companies that have focused on this band many are so power Stereo RMS @4ohm Watt 335 x 2 power Stereo RMS @2ohm Watt 650 x 2 power Stereo RMS @1ohm Watt 1200 x 2
I do further tests with this configuration, but I do not think the result will improve many decibels
liters is correct in your opinion? or should be bigger? prominence as in the picture, which would fit the agreements listed first?
I have not measured the power But the power is there, the divers arrive to stroke, then okay simply fails to load in spl with pipes to the hood, I do not know if we went with the measurements, do not think so the machine is small and many installations are done in this way
ie? subwoofers facing forward, toward the dashboard and the tube facing the back door? so mean?
still small problems I made some changes, but the results do not change in this car will list all: FS car: 73Hz Box volume: 35 litri Measures: 26x73x27 cm Subwoofer: 2 SA-8 Amplifier: 1 Saz-3500D at 1ohm teorical here are the various tests with different airport, and different lengths diameter 16cm, length 17cm, theoretical accord 75hz : burp 60hz = 136,1 dB burp 55hz = 135,0 dB diameter 16cm, length 25cm, theoretical accord 67hz : burp 73hz = 132,2 dB burp 65hz = 136,6 dB burp 60hz = 138,1 dB burp 55hz = 137,0 dB diameter 16cm, length 36cm, theoretical accord 60hz : burp 73hz = 133,3 dB burp 65hz = 139,0 dB burp 60hz = 140,3 dB burp 55hz = 141,1 dB diameter 16cm, length 47cm, theoretical accord 55hz : burp 73hz = 131,7 dB burp 60hz = 140,0 dB burp 55hz = 141,2 dB burp 50hz = 141,0 dB diameter 13cm, length 10cm, theoretical accord 73hz : burp 73hz = 129,7 dB burp 65hz = 132,4 dB burp 60hz = 133,6 dB burp 55hz = 134,9 dB diameter 13cm, length 17cm, theoretical accord 64hz : burp 73hz = 131,3 dB burp 65hz = 134,4 dB burp 60hz = 137,9 dB burp 55hz = 138,4 dB diameter 13cm, length 27cm, theoretical accord 55hz : burp 73hz = 130,9 dB burp 60hz = 139,9 dB burp 55hz = 141,1 dB diameter 13cm, length 36cm, theoretical accord 50hz : burp 73hz = 129,6 dB burp 60hz = 140,1 dB burp 55hz = 141,2 dB diameter 10cm, length 14cm, theoretical accord 55hz : burp 60hz = 135,7 dB diameter 10cm, length 5cm, theoretical accord 69hz : burp 73hz = 127,0 dB burp 60hz = 133,1 dB as noted, I tried all the tubes, but the results do not change much .. looking at the results, what can you tell me? These are two photos of the hood, box and batteries should go in the boot, while the amplifier is attached to the back turned
I love the series SAZ I'd like to see more than 4500D amplifiers, and especially, I'd like to see some class AB with high power stable to 1ohm these would be very interesting products on our market
Tomorrow I take a picture, however it seems that cash is not loading well, seems to play inside and not to create pressure definitely a tube 29 cm would improve, but with a tube of 19cm marks 140dB, so I think we can greatly improve, plus 29 cm, I would go too high with the tube....I try to pipe 13 or 10 cm as you said I list one by one all the settings to set amplifier?
I made a box of 35 liters, with pipe diameter of 16 cm, 19 cm long. burp at 73hz, but the result was very low! car grants to 73hz, but the box does not load 60hz is much more, so I'm totally out right! What do you recommend?
pics?
and a car given to 73hz? How big the box? 2 SA-8 1 Saz-3500D for SPL
