spl_eddie
Members-
29 -
Everything posted by spl_eddie
hi, i have two 12's i made out of wmd motors (the tripple stacked ones) and mostly sig soft parts. like i said i have two of them and two 1500 watt rockford amps. this is going into my durango. i would like to hit high numbers with these. i have tons of room back there and a 2400 bat. i just need help designing a box. thank you all in advance!! eddie g
fs - 37 hz qms - 8.63 vas - 1.74 ft^3 revc - dual 2 ohm qes - .86 sens - 86.4db 1W1M qts - .78 bl - 20.2 tm
kind of losing sight of topic. i really want to build a nice sturdy box for these that shoot hight numbers. im not much of a arguer. sorry
fs - 37 hz qms - 8.63 vas - 1.74 ft^3 revc - dual 2 ohm qes - .86 sens - 86.4db 1W1M qts - .78 bl - 20.2 tm heres all i could really find. but like i said they have sig soft parts in them. they are MONSTERS!!! i'll put pics up soon. any idea would be great. i live indianapolis if anyone wants to give a hand
ATTENTION. people with grand prixs i need your help.
spl_eddie replied to 2Loud's topic in SPL & SQ / Fabrication
nick, whats the best box design for a btl in an suv. i read some of your old stuff. what were your designs. ive been through about 4 boxes trying to get it right. help a brother out pls -
Hello, and thanks in advance for your answers or comments! . ok. i have an older style fi btl 18 fully loaded. i blew it. i have it taken apart and the ring where the foam lip is located is completely clean. 1st question. 1. what is the best method to remove the leftovers from where the spiders were. ( about 1/4 inch of spider and alot of glue) i tried to use a dremel tool but it made bad odors that i didnt think would be good to breath in. i also tried a metal brush in my drill "was going VERY slow" and a knife didnt work well either 2. what type of glue do you use when you recone and is it something i can pick up at any hardware store? 3. is this something not to hard that i can do myself or should i send it in to be done. i think im pretty good with most everything i do. Thank you again!
Need help choosing a 400-500 watt sub
spl_eddie replied to illiniguy's topic in Subwoofers / Speakers
im in indianapolis! wooo. is anyone else on here from indy btw? -
holy jebus batman!!!! cant wait to see the rest :-D
Ok, i have a pioneer avic N3 but the rca's are bad on the unit. how do i replace them or repair them. i have used a line output converter but i really dont like to use them. any help would be great. THANKS!!!!!!! Eddie G
bad RCA's on headunit
spl_eddie replied to spl_eddie's topic in Amplifiers / Head Units / Processors / Electrical
it's not under warranty anymore. so there is no way i can repair it myself? -
Views on the 08 Pioneer head unit
spl_eddie replied to cjosisek90's topic in Amplifiers / Head Units / Processors / Electrical
i have the 08 model. i was happy with it until i got a big system. this unit doesnt have a good anti skip. if you going to be making alot of vibrations invest in an ipod or a better deck. alot of features on this unit though. not bad for the money. Eddie G -
Hey everyone, hows it goin. ok, so today i started my first ever fiberglass project in my little brothers SUV, it's a mitsubishi montero. im putting a single 10" mtx 5500 single 4 ohm woofer in it. he listens to rock so i figured a 10 would be perfect in a sealed enclosure. today i went to the store got all the resin, hardener, mat, brushes, aluminum foil, making tape, ect ect. ive never done this before but i have read alot of forums on it and thought i would try it out. ( not in my vehicle of course ) so far tonight i got the foil layed in the area i want the enclosure. after i got that how i wanted it i put a quick thin layer of resin down then put the mat down. i learned fiberglass dries VERY fast and you need to prep a small area that you plan on doing RIGHT AWAY! and be prepared to go through a few brushes . and i also had to dispose of two mixes i made that i put to much hardener in, i can eyeball it out now to where it suites me! anyways; after i figured out how fast it dried i started prepping the area right before i layed the mat down and pressed it down with the brush and then brushed it out. seemed to work very well. i got two layers of the bottom down. i do have pics< i will put them up tomarrow!!!! if you guys have any input or suggestions that would be GREAT!!!!! thanks in advance. Eddie G
thanks for the tips. ya the stuff sometimes jells up if i use to much hardener. im using the bondo brand. what is a good brand to use? and the heat. on one batch that i had to dump i dumped it in aluminum foil and covered it. about 20 minutes later not thinking i picked the foil up to throw it away. WOW was i in for a surprise. that was HOTTT!!!!! i will get the pics posted today after work. thanks! Eddie G
im getting an alarm sometime soon. my truck got broken into 3 times within 2 months. wooo the ghetto sucks. lol. i have a factory alarm. they were ripping my stuff out with the factory alarm going off. i dont like the alpine type R's because the s's and the z's are pretty distorted. im going to look into the other speakers you guys have been telling me about. keep the idea's coming please :D thanks. Eddie G
im looking for some good 6.5 mids for my 2005 durango. my factory radio is amplified. i will be adding an aftermarket amp for my aftermarket HU for mids. ( i tend to take out all my aftermarket stuff alot(crooks) ) i have a pioneer 6000 deck "new style", 18'' loaded btl; amp got stolen but getting a sundown 3000, but im going to switch between that and my kicker L7 of a us amps 1600.4 bridged at 4 ohms to put 1100 rms to the L7. so there will be plenty of bass. i have tried the alpine type R mids and they did not work for me. i was thinking focal. but ide like to get a few idea's from you guys. and what amp would you recomend on them. thanks. Eddie Gossett
installing a stereo set up with multiple batts and altenators...
spl_eddie replied to nocomp1's topic in Amplifiers / Head Units / Processors / Electrical
high output. -
JL 500/1 repair
ok, im going to try them. thanks. idk if i can get those subs this weekend. friday is my 21st birthday, so i might not be able to make it and i dont know how my funds will be after that lol, sorry. i'll let you know for sure though. thanks Eddie Gossett -
Hi everyone, I have a JL Audio 500/1 that is blown. the green power light will come on, thats it; no safety light or anything. when it powers up the green light will come on but there is no output. Ive taken the boards out and looked them over. i have not noticed any visual problems but i could have missed something. does anyone know anything about these amps or how i can trouble shoot the problem! i live in Indianapolis, Indiana; if anyone lives close you can take a look. Thanks in advance. Eddie Gossett
JL 500/1 repair
i introduced a load to the amp before i powered it. i hooked up a single 4 ohm voice coil to the amp before i powered it. so it should have been there.... im hoping i can save this amp without spending to much money -
JL 500/1 repair
nope, that didnt work. now i either throw the amp away or get it shipped out for repair..... what do you think.? -
JL 500/1 repair
mine is apart right now, im using the duster in it and not seeing a spec move. i really hope i get as lucky as you did. the guy from dbr said sometimes the boards need to be disconnected then reconnected well and it'll work. but i did that last time to try. i have my fingers crossed though. i'll let you know here shortly. thanks. Eddie Gossett -
JL 500/1 repair
was yours a jl slash series? and clean it with duster spray? would that be ok you think? thanks in advance. Eddie Gossett -
JL 500/1 repair
thanks. im going to go take it apart right now and see. im not sure what all connections i can check inside the amp though... not to familiar with the guts of amps. thanks Eddie Gossett -
you never answered how it sounds. i wonder how well the sound stays in a boat like that??? curious
JL 500/1 repair
i talked to db-r and he said he's not taking in anymore amplifiers at this time. so i need to find another way. is there anyone on here who would have any idea on where to start to trouble shoot this amp? thanks in advance! Eddie Gossett
