Kanaworm$
Moderators
    6,886
  • Days Won
    28
Everything posted by Kanaworm$
  1. Rumor? If you don't know for sure, please don't talk. This is even way worse then misinformation. . Please don't talk? Sir you need to Relax! Tell me then as to why his vendor section has been removed from SMD and he no longer has an eBay store? How come various people cannot get ahold of him when they have problems? No return phone calls or emails. That tells me he's out of buisness. You prove me wrong and I will retract my rumor statement.
  2. Rumor has it Iraggi is no longer building or repairing his alts.
  3. Kanaworm$
    Welcome to the IHoP
    Where you doing basic at? My brother did his at Ft. Leonard Wood and is now stationed there until August. Good luck!
  4. Kanaworm$
    Welcome to the IHoP
    What part of NY is Mark from?
  5. Test the sub in a different enclosure to rule out the sub woofer. If the sub woofer tests out fine by Sundown it has to be your enclosure.
  6. Kanaworm$
    Need some bandpass help.
    I'm not a huge fan of band pass boxes but what do you think of the results you got with the calc?
  7. I would check to see if your enclosure didn't crack somwhere or something internally didn't come loose. Sounds like the enclosure is the culprit. Would you have a test box to use for a short term test in your vehicle?
  8. Kanaworm$
    Cablguy's 1997 Chevy Silverado 1500 Extended Cab
    Nice vid man! Truck looks good on those 20's. Jealous of those Plum Crazy amps!
  9. Kanaworm$
    Run your T/S numbers and input them here
  10. Kanaworm$
    Midbass
    Sure but it depends how the crossover section is on the amp. Does it have an adjustable low pass filter and subsonic filter? If so then you could use the two to create a bandpass set up where the speaker plays between a set frequency range. Btw all a SSF is a high pass crossover.
  11. Kanaworm$
    160.3db at 30hz behind C pillar -- SA-10s
    Wow that bracing should hold up now! Looks great!
  12. Kanaworm$
    Btl n3, and NSG availability
    Give them time as they are always super busy. Nick or Scott will let us know when the monsters are released.
  13. Kanaworm$
    Welcome to the IHoP
    Good here! Good luck with the classes this semester.
  14. Kanaworm$
    Welcome to the IHoP
    Post hoe .... Your caught up now!
  15. Kanaworm$
    Would like some opinions
    If you have the room the SA series is hard to beat. Go for the cone area. Even with those two SAZ-1500D keep the electrical up!
  16. Kanaworm$
    Welcome to the IHoP
    you haven't been on in awhile?
  17. Kanaworm$
    what does it take to get 150dB @ 25Hz?
    Install, install, install, testing, testing, testing!
  18. Kanaworm$
    Cone are ftw! But the NSv.2 will have some serious motor force and with 2 SAZ-3500D it will be loud. All comes down to install in the end.
  19. Kanaworm$
    I need help figuring out what to do....
    Welcome ....
  20. Kanaworm$
    * Ask Don of SDS *
    Great addition!
  21. Kanaworm$
    Incriminator Mobile
    I'm in!
  22. Kanaworm$
    12's or 15?
    Welcome ....
