Kanaworm$
Moderators
    6,886
  • Days Won
    28
Everything posted by Kanaworm$
  1. Kanaworm$
    hardbody door panels on a budget
    Looks good but that is going to be some serious bondo and sanding in the future!
  2. Kanaworm$
    Group buy US Amps Merlin MD-21 | EDIT >Price Drop!!
    This is a great price! Wow!
  3. Kanaworm$
    J-body owning noob
    Welcome ....
  4. Wow nice old school crossover. I haven't seen any of those in awhile. Did you try DIYMA?
  5. Kanaworm$
    Charing an AGM Battery
    This would be another option Sears It's microprocessor controlled and would be safer than an ordinary charger where that could overcharge if left on and forgotton about.
  6. Kanaworm$
    2 18's in the accord
    Looking good man, keep up the good work!
  7. Kanaworm$
    Need a big amplifier
    Look similar to Gedun Audio.
  8. Kanaworm$
    160.3db at 30hz behind C pillar -- SA-10s
    That is some sic flex going on there! Great job man!
  9. Kanaworm$
    head unit question
    LOC = Line out convertor. Meaning it takes the high voltage (Speaker) output and converts it to a low level voltage output to go into the RCA input jacks on an amplifier. If you are looking at doing any type of processing you will need an aftermarket piece like the JL Audio Clean Sweep, Rockford Fosgate 3Sixty.2 or similar.
  10. Kanaworm$
    Cerwin Vega STROKER-102
    another one of these "Are They Any Good" threads. or the "Search" function on here might be of some assistance to you. Use them!
  11. Kanaworm$
    SA-10 SQ?
    The SA-10 is a very underrated sub woofer. It has some of the best cooling for the price and the SQ and output are very impressive imo. I don't think you will be dissapointed at all with the SA-10 in your current setup.
  12. Kanaworm$
    New Box Ideas
    The trade in Program at Skar would be a great idea to get into a great sounding budget sub woofer.
  13. Kanaworm$
    sax100.4 settings
    I use my ear to set my crossovers. I set each set of channels seperately by ear and listening for distortion and setting it below audible distortion On the 100.4 the "push button" chages the frequency (X1) or (X10) if you have it on the X10 the frequency cut off will be 10x higher than the dial is set at. You also have either a 12db or 24db per octave slope. Choice is dependent on install. On your SAX-100.4 set up run the front channels 1 & 2 on highpass and on channels 3 & 4 run them on low pass. By utilizing the SSF filter (High Pass Filter) on channels 3 & 4 you can create a bandpass crossover and limit the frequency range in which you run your midbass. Goal is to play around with the frequencies on then crossovers to acheive a well balanced sound.
  14. Kanaworm$
    New Box Ideas
    When you have 8 hard spiders.. it doesn't loosen up much lol. IIRC PWK tested a DD woofer similar to the AQ and after about 24 hours of break in period.. the fs only dropped around 3-6hz DD and AQ say it takes weeks sometimes even months to loosen up!
  15. Kanaworm$
    New Box Ideas
    Dang troll!
  16. Kanaworm$
    New Box Ideas
    How old is the driver itself. AQ is notorious for a tight suspension that it takes awhile for the spiders to loosen up.
  17. Kanaworm$
    Back To Basics (1974 Dodge Charger)
    Welcome .... on the progress.
  18. Kanaworm$
    New Box Ideas
    AudioQue likes a higher tuning have you tried that? They say tune around 38-40hz. Not sure your going to gain much in SQ form that driver.
  19. Kanaworm$
    BUILD LOG Explorer limo 6 IB3s walled 300 cubic feet 50"x12"x3
    Why not build a wall with a true enclosure and tune it low. With the length of that vehichle it should have some serious transfer function and cabin gain.
  20. Kanaworm$
    Goodbye Chuck's! Hello Temporary Sundowns! lol
    Down with the Chucks and on to the SA-12's and the cool shit!
  21. I have never said he didn't have crappy CS. (because he does) fair enough.
  22. Kanaworm$
    Neo SSDs
    Wow looking forward to seeing the new neo SSD's.
  23. If he is working behind the scenes or taking a break he should at least let people know that. To just up and dissappear and not return phone calls or emails on customers who have problems is just poor buisness practices.
  24. Good luck trying to get any help from eD. But I would try running them active.
