Kanaworm$
Moderators-
6,886 -
Days Won
28
Content Type
Profiles
Forums
Gallery
Everything posted by Kanaworm$
That guy has some insane install skills! A little overkill on the Carbon Fiber.
Very nice and clean install!
I would recommend the Lethal Injection series from Incriminator Audio.
Very nice!
4 or 2 channel amp?
Kanaworm$ replied to T0mmysee's topic in Amplifiers / Head Units / Processors / Electrical
Your welcome. Were always here to help. -
4 or 2 channel amp?
Yes...basically the passive crossover network takes the guess work out. The speaker manufacturer has done the work for you. For a 1st time system using components, I would highly recommend using the passive setup until your more familiar with frequencies and level matching. -
4 or 2 channel amp?
Passive = Coils, Resistors, Capacitors assembled to creat and divide the various crossover frequencies Electronic = Built in crossover in amplifiers or seperate electronic crossovers to create and divide the frequencies electronically. Hopefully that makes sense... -
From the Rockford Fosgate website... Description Size 12" Impedance 4-Ohm Power Handling 150 Watts RMS 300 Watts Max Voice Coil Diameter 1.5" 6-Layer (3.81 cm) Motor Size 40 oz. Speaker Connector Dual 10 AWG compression SPL (1w/1m) 86 dB Mounting Depth 5.875 in. (14.92 cm) Shipping Weight 12.50 Lbs. (5.67 Kg.) Rec. Sealed Enclosure 1.02 cu. ft. (28.88 liters) Range: 0.70 cu. ft. - 1.80 cu. ft. Range: (19.82 liters - 50.97 liters) Rec. Vented Enclosure 1.79 cu. ft. (50.69 liters) Vented Tuning Frequency 36 Hz Port: (1) 3" diam. x 6" long Port: (1) 7.62 cm x 15.24 cm I would use the ported specs. Good luck!
I voted active since that is what the future plan is. Currently I am running Passive to my components and active on my mid-bass.
That is one impressive port! Nice job!
Wrong section!
Keep up the good work and keep the pics coming.
Try a different ground location for your CD Player. Also may want to just disconnect the plug and rca's from the deck and reconnect. Does your sub sound okay? May want to check some settings on your deck to make sure something or someone didn't play around and mess things up. I have kids so I know... Good luck
^ Exactly!
When the wife let's me spend again A pair of these are in the plans for dedicated mid-bass.
Very nice!
Good luck with the sale of your truck! That 2001 will have all kinds of room for boom!...
Good luck trying to fit a box that size in that trunk. How do you plan on firing the woofer? Up?
