Kanaworm$
Moderators
    6,886
  • Days Won
    28
Everything posted by Kanaworm$
  1. Kanaworm$
    distance
    Round or slot port?
  2. Kanaworm$
    xxx 18
    So what was the bad thing about the XXX? It is not an SPL woofer! Build it for the right application and test again. It is a low end monster and sounds great!
  3. Kanaworm$
    BTL terminals, Running parallel
    Shouldn't be a problem running both sets to the bolts. If you cannot get some 8 gauge ring terminals local try eBay.
  4. Kanaworm$
    so definitely DON'T do coil to coil? And then do one positive and negative from the coils to the male terminals on my terminal box and then the other set of coils to the bolts on my terminal box? Yes
  5. Kanaworm$
    No need for 8 gauge! Step down to 12 gauge and wire it to your terminal.
  6. Kanaworm$
    Welcome to the IHoP
    Gotta love CadillacMatt's avatar!
  7. Kanaworm$
    Happy Easter
    Happy Easter! Wow that is a big ol' bunny wabbit!
  8. Kanaworm$
    enclosure for two sa-12's
    35hz or higher will generally yield higher SPL numbers. 33hz - 30hz will be great for daily ground pounding.
  9. Kanaworm$
    Sir-Lancelot's Build Log - Updated July 17th - Page 8
    Great craftmanship! Box turned out great!
  10. Kanaworm$
    NEW TO THIS AND NEED HELP
    Wow, if your new to this and starting out with this big of a system your in a little over your head. Here are a couple of links to read to get you started..... How To: Set your Amplifier Gain - SSA Car Audio Forum THE BIG 3 - SSA Car Audio Forum You definitely need to address your wiring and electrical before you break your new subs and amp! Please ask all the questions you need!
  11. Kanaworm$
    Excited
    Were gonna when they arrive or else ....
  12. Kanaworm$
    Sound Deadener Showdown CLD Tiles
    Great products and service! I ordered my CLD Tiles and Butyl Rope last fall and will be going in my new build soon.
  13. Kanaworm$
    some tweeter help
    Imo yes that is why they blew! That amp has a great crossover built in might as well use it.
  14. Kanaworm$
    enclousure for btl 12
    Take a read through this very informative article .... How To: Set your Amplifier Gain - SSA Car Audio Forum Don't want you clipping your amp and burning up the sub.
  15. Kanaworm$
    some tweeter help
    Nvm saw your sig. Looks to be set at full range. What size mid is in the comp set? If your running that amp at least set it to high pass and tweak from there.
  16. Kanaworm$
    Hi From Minnesota
    Welcome ....
  17. Kanaworm$
    100.4?
    Yes that is how I had mine setup. Play around with the SSF filter and crosover settings. Play some of your favorite music and crossover as low as you can without audible stress on the midbass.
  18. Kanaworm$
    100.4?
    When in high pass mode the SSF filter will not be beneficial as it is a high pass filter itself. But if you want to run midbass you can switch to low pass and then use the SSF to use as a pass band filter.
  19. Kanaworm$
    Dcon review
    Me too! I put it in my truck and just can't seem to take it out!
  20. Kanaworm$
    1995 Chevy Suburban
    Nice equipment list and nice start! Bad cuts....that is what a sander is for.....
  21. Kanaworm$
    Hi Guys!! and Gals?
    Welcome ....
  22. If the amp is not 1 ohm stable it's going to say nope no more output for you! Need to turn the bass boost off on the amp. I would avoid the really bass heavy style music until you get the SAZ-1500D back.
  23. Kanaworm$
    SAZ 1000D sub wiring question
    Yes just wire both speakers to the + and - terminals on the amp and make sure your impedance is selected to 2 ohm.
