Kanaworm$
Moderators
    6,886
  • Days Won
    28
Everything posted by Kanaworm$
  1. Kanaworm$
    12" in a 2.5 cu.ft. vs 15" in 3 cu.ft.
    Depends on the subwoofer and it's T/S parameters!
  2. Kanaworm$
    SAZ-2500D Prototype Is Here !
    Patience guys! This will be worth the wait!
  3. Kanaworm$
    More Sundown Issues Unfortunately
    Try not to let 1 lemon get you down! I understand the frustration. Try the other amp to rule out any installations issues that may have occured. Always a good thing to troubleshoot all wiring when things like this happen. Never know when something my have got pinched or shorted when putting the vehicle back together again. I'm sure Chris will take care of everything for you. Just be patient a little longer.
  4. Kanaworm$
    It's almost time.
  5. Kanaworm$
    surprise!!!!!!
    Mmmmmmmmm DCONS!
  6. Kanaworm$
    the "(2) XCON 18s" build....2010
    Damn those AA Carbon mids look impressive! Tuned in for this ...
  7. Kanaworm$
    Ernie's 2 12" Demo Car Build | New PICS p4
    Damn! Those new look ICONS are calling my name!
  8. Kanaworm$
    Orion HCCA D2400
    Definately a good thing!
  9. Kanaworm$
    sq. inches of port area needed per cubic ft. of volume
    Welcome .... Take your vent height x vent width = square inch of port area!
  10. Kanaworm$
    Orion HCCA D2400
    Just a guess, somewhere around $75-150!
  11. Kanaworm$
    Orion HCCA D2400
    Better off to leave it to a pro like db-R. But this is a good read .... Speaker Load and Amplifier Failure
  12. Kanaworm$
    how long to ship from ssa store?
    Welcome .... Best guesstimate I would say 1-3 buisness days.
  13. Kanaworm$
    Orion HCCA D2400
    Output transistors! Most likely won't be able to tell unless you have a DMM.
  14. Kanaworm$
    Team Decent "Punisher" Build
    Impressive scores!
  15. Kanaworm$
    Orion HCCA D2400
    Broke! Most likely outputs!
  16. Kanaworm$
    System performance question?
    Ok i will def check them out...and thanks for the info thus far! You're welcome! Btw..... Welcome to SSA ....
  17. Kanaworm$
    Check out the fabricators section: SSA Car Audio Forum -> Custom Fabricators Or Argent Audio SSA Car Audio Forum -> Argent Audio
  18. Kanaworm$
    SPL meter prototype versus Termlab
    When they are ready, i'm getting in line with my $$$!!
  19. That is a very nice looking amplifier with a lot of flexiability, good choice! What size mid/midbass are you looking at? Vehicle?
  20. Kanaworm$
    Your high end should stay about the same. To many variables to say though. As far as the sub set up, you should see a noticeable difference with the added upgrade in woofers and seperate amplifier. To really make those L7"s move you should look into a ported design.
  21. Kanaworm$
    Key To Hair Trick
    Around 3.25 per sub they work 3 to 3.5. I'm no SPL or hair trick specialist but I would recommend at least 156in^2 of port area and tuned a bit higher to 38hz. Just my .02!
  22. Kanaworm$
    You added another woofer and more than doubled your amplifier power, so it should be more than noticeable as long as it was installed correctly. But is the box big enough to house 2 10" vs the 1 10" from before?
  23. Kanaworm$
    Fi SSD 15's
    Nice review! For the money they are hard to beat imo!
  24. Kanaworm$
    I love U X2
  25. Kanaworm$
    need some help please
    Unless you're doing an all out SPL "Burp" style enclosure all the vendors subwoofers will be musical (All install dependant). Some designed for more sound quality like the Fi "Q". If you can supply some max dimensions like max width, height and depth it will be easier to answer your questions and help with suggestions.
