SoundQubed
Vendors
    97
  • Days Won
    2
Everything posted by SoundQubed
  1. SoundQubed
    Please welcome SoundQubed to the SSA forums
    We are a 3-4 weeks out on them. Will have more concrete information today! Be careful your backup may become your number one starter! Nah, I'm interested in the Fi BL 12" i ordered these are just a great looking driver at a great price that I wouldn't mind using in case I ever had to send in the BL for some TLC, which given their good rep and my experience I shouldn't need to do. I'm just a dang addict and can't stop shopping for subs even though I've ordered one already...Lmao We do understand! It's an addiction for sure!
  2. SoundQubed
  3. SoundQubed
    3 8's, 2 10's, or 1 15
    We have a 2011 Xb that has seen the likes of a single HDC412 (2,000RMS), to a wall of HDC315's (1.500RMS). There is more than enough room to run any of our woofers, though it's up to you to decide how much space you are willing to give up! Check out our Demo Install here: http://www.youtube.com/watch?v=4YM9y_rUlt4&list=UUiAFvyEqYBU36BOPwSn0ERA&feature=share&index=1
  4. SoundQubed
    Soundqubed 18
    Hope you are enjoying these woofer!
  5. SoundQubed
    HDC3 & HDC4 coil and motor's
    Whats the story behind the high Fs of the HDC'4? Was this a non broken in woofer or something? The suspension is that stiff? (equivalent HDC3 is 9hrz lower IIRC) A. These test are done after eight (8) hours of play time. The FS will drop substantially once broken in. Between the HDC3's copper coil & the HDC4's aluminum coil 1. Can I daily an HDC4 on music? A. You sure can! These things can get low, loud, and be musical with no worries. 2. Is there a large efficiency difference? A. Not at all! Although there is a loss it's not substantial enough for most users to notice, it's minute. The benefits of the aluminum outweigh the loss that you may or may not see.The HDC4's even with its 4" coil will keep up with the HDC3 musically. 3.Why is the 4's coil an aluminum winding? Just weight savings and thermal dissipation? is it worth worrying over? A. Follow the link supplied for the Copper Vs Aluminum Battle: http://www.soundqubed.com/Copper-vs-Aluminum_ep_67.html The weight you see is Shipped weight and not motor weight. As Andrew stated these motors are exactly the same from the 12" model to the 18". This factor in motor size is true for all series of woofers from SDC,HDS,HDC.
  6. Looking good! Hope you are enjoying your Q1-3500
  7. SoundQubed
    HDS300
    So you want a woofer that will move some air? Something in a reasonable price range? Perhaps the 3" coil turns you on? Well the HDS300 is the route for you. This series truly is the "Most Bang for Your Buck." Features Include: Vented back-plate for optimal cooling and less turbulence in the coil gap. 3.0" diameter four-layer copper coil.Heavy Duty push connectors for ease of install. (Accepts up to 10awg speaker wire)Stamped, Steel Frame. Black electroplated top and bottom plates for additional cooling. Non-pressed cone for maximum rigidity. High excursion foam surround. Power Handling 1200W RMS, 2400W Peak * Model: HDS310 * Piston Diameter = 203.2 mm * f(s)= 37.68 Hz * R(e)= 7.06 Ohms * Z(max)= 76.00 Ohms * Q(ms)= 5.231 * Q(es)= 0.536 * Q(ts)= 0.486 * V(as)= 9.340 liters (0.330 cubic feet) * L(e)= 8.74 mH * n(0)= 0.09 % * SPL= 81.59 1W/1m * M(ms)= 282.10 grams * C(ms)= 0.06 mm/N * BL= 29.67 * Model: HDS312 * Piston Diameter = 254.0 mm * f(s)= 33.65 Hz * R(e)= 7.39 Ohms * Z(max)= 73.74 Ohms * Q(ms)= 6.912 * Q(es)= 0.769 * Q(ts)= 0.692 * V(as)= 22.130 liters (0.782 cubic feet) * L(e)= 8.62 mH * n(0)= 0.10 % * SPL= 82.29 1W/1m * M(ms)= 364.40 grams * C(ms)= 0.06 mm/N * BL= 27.20 * Model: HDS315 * Piston Diameter = 330.2 mm * f(s)= 35.66 Hz * R(e)= 7.27 Ohms * Z(max)= 68.69 Ohms * Q(ms)= 7.836 * Q(es)= 0.927 * Q(ts)= 0.829 * V(as)= 56.730 liters (2.003 cubic feet) * L(e)= 8.87 mH * n(0)= 0.26 % * SPL= 86.33 1W/1m * M(ms)= 361.60 grams * C(ms)= 0.06 mm/N * BL= 25.20
  8. SoundQubed
    This guy^^ Thanks for the great response, and welcome to SSA! I have yet to use anything from you guys but am very interested in your amplifiers. Now that you are a part of the SSA crew I might have to pick one up to play around with. We can def. get you taken care of! Whether you purchase through SSA or our site, whichever you feel more comfortable with!
  9. SoundQubed
    No 20k's in the making at this point, however we do hear there are some brand new ones floating around in South America if you can get your hands on them! • We were established 11 years ago in Oklahoma City Oklahoma by a father and son who absolutely love and enjoy the Audio in general. To this day they are still very hands on thurought the RnD and customer service departments. • Our market is for the DIY guys/gals who prefer to get hands on. We sell through a few different venus but there are no dealer prices. You, the enduser benefits from this as you will always get the lowest price, and FREE shipping! • We started off building woofers in house however we have since moved our build houses to overseas. Our amps are made in Korea. However our HDC4's are still built in house. We do repair all amps and woofers in house unless you prefer to re-build your own woofer, in that instance we sell re-cones! We are always looking for innovative and creative ways to keep our woofers up to par with the times. Building for those who need a little bass or a lot. Either way we've got everyone covered. • Everybody knows a woodchuck would chuck as much wood as a woodchuck could chuck if a woodchuck could chuck wood.
  10. SoundQubed
    SQ banners
  11. SoundQubed
    SQ 800x100
    From the album: SQ banners
  12. SoundQubed
    HDS300
    We need to let you sit in our demo vehicle! I heard an HD3 15 trunk walled in a lancer, and for a fifteen in 4.5 @ 33hz, on 1500w it rolled off high as hell, the low lows just weren't there. The higher notes were forceful, but the lowest notes just went missing.
  13. SoundQubed
    Detailed Pic's of a Soundqubed HDS200 15"
    Very Nice! One of us here has a single HDS215 in a 3.50^ NET and it bangs! Let us know how it turns out!
  14. SoundQubed
    Sooners! Cowboys or Sooners?
  15. SoundQubed
    SoundQubed Demo Car
    Here are some photos of our demo car!
  16. SoundQubed
    Overview
    From the album: SoundQubed Demo Car
    An overview of the SoundQubed Scion Xb.
    © SoundQubed
  17. SoundQubed
    Trip on Route 66
    On a trip to a show in Tulsa Oklahoma. We took a trip down old Route 66 and had us a layover at Pops!
    © SoundQubed
  18. SoundQubed
    At a show!
    A side shot showing off the Single QP-TH25 tweeter and pair of QP-MR6.5's rocking out in the rears.
    © SoundQubed
  19. SoundQubed
    Sunny Day at SoundQubed HeadQuarter
    Right after the wrap was put on the vehicle, just before a show.
  20. SoundQubed
    HDC315's
    Shot of the Pac-Man style wall at the B-pillar boasting Four HDC315's.
    © SoundQubed
  21. SoundQubed
    Mockup
    This was during the build of the Pac-Man style wall. Two Q1-2200's, Two Q4-120's, and a single Q2-200.
    © SoundQubed
  22. SoundQubed
    Thanks for welcoming us, it's been a long time coming! We are here to answer any questions about SoundQubed that you may have.
