6,708 -
Days Won
149
Content Type
Profiles
Forums
Gallery
Everything posted by Impious
LMAO....I guess I hadn't considered the window deflectors to be something for old people....I guess I actually thought they were more for the "hip" younger crowd. I smoke, and I want them to deflect the rain when it's raining & I'm in my car smoking. The only 4-window kit that WeatherTech sells only fits the wagons, which apparently have different rear doors I think it looks a little goofy to not have them on all 4 windows, but I guess it'll have to do if I can't find another vendor.
Ryan, Sean, Aaron, et al.... I would like to get some in-channel wind deflectors/vent visors for my Buick. JC Whitney sells the WeatherTech brand which are in-channel, but a 4-window set is $115...which seems pretty damn steep to me. But I don't know, never bought a pair before. The out of channel sets are around half that, and I don't understand why the in-channels would be twice the cost. Any other good retailers to look for that would sell these? I've tried searching around some online but most others sell out of channel only.
New "SQL" system for a metalhead - Right direction?
Impious replied to pascalc's topic in General Audio
The measurements I've seen of the B&C drivers show the company rated "Xmax" to truly be a 2-way measurement rather than a 1-way measurement. IIRC the 8NDL51 has a "rated" Xmax by B&C of 8mm, when measurements show it's true Xmax (one-way measurement) is actually 4mm. Overall very good drivers though. 18sound makes good drivers overall as well. The one's I've seen measured all did extremely well in distortion measurements with good usable response. Faital I don't really know much about. -
Help me find best 5 channel amp please!
Impious replied to mcquinnh's topic in Amplifiers / Head Units / Processors / Electrical
Memphis, but a lot pricier Really there aren't many 5-channel amps with high power on the sub channel. The other option is a Zed Leviathan 6-channel. Not 1kw on the sub channel (2-channels bridged) but a lot more power on the main channels, which to me would be a fair trade-off. -
Where/Why is the JL 12W6v2 starting to "come apart"?
That's because they don't actually try to help you, they just need to make it look like they're trying to help you. As long as it looks like they're trying, they look like the good guys.
HOW DO I FIND OUT WHAT SUB I HAVE, I BAUGHT USED FROM CRAIGSLIST
Impious replied to PURO ORGULLO 89's topic in Subwoofers / Speakers
It's VERY LOUD in Florida Is that why they all require 64 mids and 18 tweeters per door in their systems? -
You are going to need to give more details about your present wiring scheme, what headunit you have, and what flip down monitor you have.
My guess is he copy-n-pasted his post from DIYMA onto SSA and it copied the hyperlinking as well. DIYMA has this fucking retarded dictionary thing that hyperlinks any word found in it's dictionary. It's annoying as shit. I edited out the hyperlinking.
need some help with midbass placement and door pods
Impious replied to dbsupra's topic in SPL & SQ / Fabrication
You could also build a "pod" that's not sealed in the rear to give yourself a little more mounting depth but still fire into the door for more airspace. -
I dislike SMD as much as the next guy, but if this audio thing ever falls through he should be at the top of the recruitment list for most Fortune 500 companies. The guy is a marketing genius. Armed with nothing more than youtube videos & online forum promotion, and despite his obvious lack of understanding of the basic principles of both acoustics and electronics, he was able to turn his name into a fairly prominent brand with nothing more than mediocre builds and primarily ignorant logic in the process and design of the system. That takes some real marketing talent to pull off. Companies would kill to be able to build a brand out of absolutely nothing (by "nothing" I mean no real skill, talent or knowledge) the way he has.
Actually running them isobarically requires 1/4 the power and IIRC 1/2 the enclosure size to achieve the same output. Is not the idea being the iso to use the second driver for control to make a smaller enclosure work? I've never seen an instance where efficiency is increased, especially to the point where you need 1/4 the power. You've decreased enclosure size, and added a driver, so if anything, efficiency is increased and more power is needed. With the drivers wired inversely they act upon each other through coupling. One sub pushes the other, reducing the power to reach full excursion. I expected roughly 1/2 the power, but someone somewhere explained how they amplify each other, making the required power 3/8-1/4 the required power. You decrease the enclosure size because you are doubling the motor strength by coupling them isobarically System efficiency for isobaric loading is 3db less than that of a single driver in twice the enclosure volume (i.e. same alignment). So not sure why you think required input power decreases, when actually the necessary power input to reach the same SPL level compared to a single driver in the same alignment doubles. The ONLY advantage is 1/2 the enclosure volume. Since everything is a set of compromises, the trade-off is less efficiency and the requirement of 2x the power input to reach the same SPL.
You are correct, middle of the door is a terrible location. My two suggestions would be: 1) Kickpanels (my favorite, if room allows & you can fit proper airspace) 2) Cut some metal, rework the door panel and mount them here: If you want to go the "easy way out" you could always try to build some mounting rings to give yourself more mounting depth of the panel allows, but I don't really like the factory mounting locations anyways so I would cut some metal or go for kickpanels. -
what amp would be the best deal for me?
Impious replied to atokad33's topic in Amplifiers / Head Units / Processors / Electrical
There will be dozens of amps that would be more than satisfactory for you. Go somewhere like Sonicelectronix.com or woofersetc.com, sort their mono & 2-channel amplifiers by price & start scrolling to see if there's anything else that trips your trigger. I would avoid things like Boss, Pyle, etc.- 8 replies
- subs
- amplifiers
(and 3 more)
Tagged with:
rockford-fosgate-t2500bd-max
Impious replied to Dfrancis24's topic in Amplifiers / Head Units / Processors / Electrical
Why would you want to run at .5ohm daily? -
Optimus was a low end brand sold through Radio Shack. Like I said though.....just look around & find an amp rated either 100-125w x 2 @ 4ohm or a mono amp ~250w @ 2ohm and you're good to go. That Kicker is at the upper end of your price range, looks like it's around $150 shipped on most sites. Should be not too difficult to find one that's still reasonably decent for a little less $$ but nothing wrong with the Kicker either....they build reliable products.- 8 replies
1
- subs
- amplifiers
(and 3 more)
Tagged with:
Both. You want to apply the CLD to both the outer & inner door skins/panels. Typically Don recommends 5-6 CLD tiles on the outer door skin (half of those on the top portion of the outer door panel above the brace and the other half on the bottom portion of the outer door skin below the brace). Then typically another 1-3 CLD tiles on the inner door panel (based on how much surface area there is, etc) applied to the most resonant areas of the panel. The purpose of the CLD isn't to block noise, it's to reduce resonance & vibrations. The MLV is to reduce road noise.
Optical Cable in Car Audio
Impious replied to Sencheezy's topic in Amplifiers / Head Units / Processors / Electrical
I honestly haven't read most of the posts in this thread, but optical as a means of signal transmission has been done plenty of times in car audio. Alpine H701, Sony CDX-90 & associated processor (this one going back to the mid 90's if not earlier), Pioneer ODR system (again, going back to the 90's), etc etc etc. I used the Alpine DVA-9860 via toslink connected to the H701 for several years in my car. Never had a single problem with either the cable or the unit. I would have to disagree with Nick, certainly any product is going to have it's issues but generally the H701 is a reliable, affordable (used) processor with a lot of tuning power. Sure you can find a lot of threads of people with issues on the forums, but given how many units are out there it's not surprising. The H700/701 was probably in production close to 10 years. If you get the non-glass cable & don't bend it at 90 degree angles the cable itself is not a problem. But as Sean said; it's one of many digital signal transfer methods and there really isn't going to be an audible benefit to any one over the others. -
Four 8s, two 10s, or one 15" subwoofer?
Impious replied to Briggiboy33's topic in Subwoofers / Speakers
Also there's absolutely no reason at all four 8's would have more "punchy bass" than a single 15". As of right now out of the options you listed I see no reason not to go with the single 15" as long as you can fit a proper enclosure. -
Single 15" has more cone area than two 10's (about 30% more cone area) & only a hair less than four 8's (though depending on the actual Sd of the 8's, the single 15" might end up having more cone area), however an SSD is going to have significantly more excursion capabilities than those Infinities so overall displacement would be significantly higher with the single 15", which means potential output would be the greatest with the single 15" out of those options. How much room do you actually have to allocate towards the enclosure? -
Anything that does ~250w RMS @ 2ohm will be fine. Mono amp is perfectly fine, also a 2-channel amp would be acceptable as I'm sure it's going to be fairly easy to find an amp that does ~100w x 2 @ 4ohm. Do you plan to upgrade soon or is this system going to last you a while? Any particular price you are looking to spend? What amp do you have presently?- 8 replies
- subs
- amplifiers
(and 3 more)
Tagged with:
Time for a new head unit
Impious replied to pimpdaddy1787's topic in Amplifiers / Head Units / Processors / Electrical
Higher preamp voltage doesn't give you more sound quality. The gain position has nothing to do with anything, as long as it's properly set & it doesn't cause audible noise (some amps can be noisy with an extremely high gain setting). The only significant benefit to higher preamp voltage is to improve the signal-to-noise ratio of the signal transmission. Which means if you have no audible noise, either from the amp due to gain position or from noise induced into the cable, with your current preamp voltage level.....then increasing preamp voltage is not going to have any audible benefit. -
I thought they came out with a higher voltage input/output version? Not a lot higher, but ~2v RMS
My son also found my old collection of CD's....they are primarily all rap from my younger days. Not really my preference now-a-days, but I'll probably spend a few nostalgic days cycling through them in the car. I will admit though, I was pretty excited to pop Sir Mix A Lot "Posse on Broadway" in the car today Sure wish I had a system in there though
Was cleaning out the basement yesterday. It's amazing how when we moved we kept an entire room worth of boxes that were filled with just senseless shit, & even more amazing we've stored those boxes of useless shit in our basement for 9 years. On the bright side, I did find these: My old collection of audio magazines.....back when they were atleast half ways decent.
