6,708 -
Days Won
149
Content Type
Profiles
Forums
Gallery
Everything posted by Impious
Any idea the actual model number for your subwoofers? The two owners manuals I could find on RF's website for the older model Punch Z's like yours showed the specs varied some between the two models, but neither were particularly well suited for ported enclosures. Also, typically not a good idea to port a sealed enclosure as ported enclosures are typically required to be slightly larger. Just off a glance, after you subtract out the volume of the port your current enclosure would be too small to function ideally as a ported enclosure for the subwoofers. So overall.....probably not a good plan to do what you wish to do.
Three 10's have slightly less cone area than two 12's. Three 10's sealed seem pointless if you can fit two 12's sealed. Two 12's would be less expensive, take up less room and have equal output capabilities. As for the 10's port verse 12's sealed.....that's a personal decision that I can't much help you with.
The JL Audio link in my prior post explains the proper way to calculate port length when using multiple ports. I don't have time right now to mess around with that calculator to be able to tell you how to interpret the information it's giving you.
The port end correction factor increases the effective length of the port. Therefore, for a given tuning frequency you would need to decrease the physical length of the port by the end correction factor so that the effective length was correct for the tuning frequency.
Other amp options..
Impious replied to smashedz28's topic in Amplifiers / Head Units / Processors / Electrical
Or try a different enclosure -
Other amp options..
Keep in mind a clamp test isn't a very useful or accurate method for testing amplifier power. To the average user (such as yourself), the numbers stated in that thread are pretty useless. That was my point Increasing power is most useful to competitors where tenths of a decibel can be important. To the average user (such as yourself) even doubling power output won't result in a significant audible benefit, especially when considering the added expenses. But people lose sight of this fact because of all the attention raw power figures are given on the internet. Also was mentioning it to point out that if you have a 1500w amp now and you want to significantly increase audible output don't run out and buy a 2kw or 2500w amp as it won't make a much if any audible difference and all you'll have accomplished is spending money for pretty close to nothing. -
As bromo said, the issue is with the difference between physical port length and effective port length. On the carstereo.com calculator when you mark slot port "yes" the calculator reduces the length of the port by 1/2 of the port width to account for port end correction. If you notice the difference between the two calculators is 12", which is half of 24", which you apparently entered as the port width on the carstereo.com site. The 12volt site does not account for port end correction. For more on port end correction factor, see here: JL Audio - Car Audio Systems Without knowing details on the layout of the port in the enclosure, I can't tell you which is accurate. If you are using an enclosure wall as the sidewall of the port, you will need to account for end correction. It would seem odd to have a port that's only 4" tall & 24" wide unless it's horizontal across the bottom of the enclosure. If the port is vertical in the enclosure I would assume the 4" is the width and 24" is the height? Either way, you would only need to subtract 2" from the port length for end correction factor as opposed to the 12" initially calculated (i.e. on the carstereo.com site, put 4" for the width and 24" for the height and mark slot port "yes" if you are using the enclosure wall as a a sidewall for the port).
Other amp options..
Keep in mind that even under ideal conditions you would have to double your power to gain 3db in output, which is an audible but not dramatic increase in sound. After you factor in power compression & other factors, even doubling power will yield less than a 3db increase. -
This definition isn't very accurate either. For "phase cancellation" (destructive interference) to occur between two or more speakers the speakers do not have to be out of phase. For destructive interference to occur, the soundwaves simply need to interact with each other while the soundwaves are not in phase. The speakers may in fact be in phase while this is occurring. This phenomenon is very prevalent in car audio where we sit at different distances from the two speakers or in home theater where the listening positions can vary. There are other ways for destructive interference to occur. In home audio speaker design the center-to-center distance of drivers in speaker may cause destructive interference. The crossover can also cause two drivers in a given speaker to be out of phase since the crossover will shift the phase of the signal (90* phase shift for every 6db/oct increase in slope), in which case you must wire the drivers out of phase in order for the soundwaves to be in phase at the crossover point. You can also have destructive interference with a single speaker due to reflections. The reflected sound may reach the listener out of phase with the original sound. Not nitpicking your definitions.....but also do not want people misunderstanding the information being provided.
The sentences highlighted in red are rubbish and should be excluded from any viable definition of DF. For more information on damping factor see here: Damping Factor
Ehh...not really. I would maybe define beaming as a term used to describe the narrowing off-axis disperson of a loudspeaker as frequency increases due to the relationship between the wavelength of the sound wave and cone diameter. When you say "maybe" I question your definition. How does Cone Diameter directly affect beaming? I used "maybe" because I hadn't given more than a moments thought to the wording of my definition, thus it was subject to revision if I came up with something that was worded either more cleverly or more comprehensively.
Tuning JL 1000/1 for Fi BL 15 all options.
Impious replied to raolito1980's topic in Amplifiers / Head Units / Processors / Electrical
Does your headunit have any adjustments? EQ, crossovers (both lowpass and subsonic/infrasonic/highpass), level settings, etc? -
Need help building a box for subwoofer without Specifications
Impious replied to The enD's topic in SPL & SQ / Fabrication
Really nothing unusual there. There are a few possible explanations. First, your ear is more sensitive to sound at ~65hz than it is at ~35hz. A sound or tone at ~65hz may be perceived as louder to your ear than a sound or tone at ~35hz even though the actual SPL (as would be measured by a microphone) of the ~65hz tone is lower than the ~35hz tone. SPL competitors are well accustomed to this, and is the reason the experienced competitors will tell you that what is louder to the ear won't necessarily be louder on the mic. This effect has been studied and is known as the Equal Loudness Contour. As you can see from the graph, a 35hz tone requires approximately 10db higher SPL to sound equally loud as a 65hz tone to the ear. Second, just because the enclosure is tuned to 35hz doesn't necessarily indicate there will be a peak in the output at that frequency. Depending on the parameters of the sub and how it responds in the enclosure you have it in, it's possible the output is actually lower at 35hz than it is at 65hz. It's also possible that the output from the subwoofer is pretty equivalent at 35hz and 65hz and you are simply experiencing effects of #1 above and #3 below. Third, I'm not sure where you have the enclosure located or the specifics of the room, but you may be experiencing the effects of some room nodes which will affect the frequency response from various listening positions. While rooms in a house don't have the "cabin gain" that we experience in car audio, there will be locations in the room where the sound waves have constructive and destructive interference which will affect the frequency response. Well, yes, if you lowpassed the subwoofer and that lowpass filter attenuated 64hz you could of course make it sound less loud than 35hz. However, that's not the mechanism(s) causing what you are experiencing. -
Keep in mind the gain is not a "power knob".....having it turned up less than half way does not mean you are not receiving full power output. It is possible to obtain full power output from an amplifier with the gain turned to it's lowest setting, depending on the input voltage from the source. That said, there are different theories on how to properly set the gain with a DMM. One theory is to use a 0db test tone so that the amplifier doesn't clip the signal. However, this decreases the amount of power output during typical music playback since music is at a level below 0db way more often than it is at 0db. So another theory is to use attenuated test tones; -3db, -6db, -10db. This gives you more power output while playing music at the risk of clipping the peaks of the signal. But before we really get into resetting the gain, it would be more useful to know what enclosure you were using, what your other settings were set at (lowpass filter, highpass or infrasonic filter, bass boost, Q, etc), and what exactly you think is lacking as well as your expectations. We may end up chasing our tail around proper gain setting when the problem is actually somewhere else. When you use a bass boost or EQ where you increase or decrease the level of the signal at a particular frequency, you are not only adjusting the frequency marked on the dial. You will also be increasing or decreasing the level of the frequencies surrounding (both above and below) the center frequency. For example, if you set the EQ center frequency to 40hz, and you turn the db dial to +3db, you are not only increasing 40hz by 3db....you are also increasing the output level of frequencies above and below 40hz (by an amount less than 3db, however). The Q setting changes the "bandwidth", or how wide of a frequency range above and below 40hz you are affecting. The lower the Q, the wider the range of frequencies. The higher the Q, the narrower the range of frequencies. Unfortunately without quite a bit of information it's hard to determine a "proper" setting of the Q....so generally it's best to set it to where ever obtains the best results by ear. -
What enclosure are his current subwoofers in? Something as simple as a new enclosure for his current subs may give him what he's looking for at the cost of about $30 in supplies and an afternoon building it. Type R's can wang chung in the right enclosure, if that's what he's looking for.
I actually chuckled when I saw the pictures. I've seen a lot of things on the forums over the past 8 years....can't say I've ever seen anyone use chimney and sewer pipes as a makeshift port before. No harm, no foul when it comes to testing though.....hopefully you'll learn a little something in the process. -
4ohm vs 1 ohm ?
Impious replied to socialstealth's topic in Amplifiers / Head Units / Processors / Electrical
The Epicenter works by looking for harmonics and filling in what might be a missing or attenuated fundamental that was filtered out during mastering process or somewhere in the reproduction chain (such as the source unit). If, for example, it finds a signal at 100hz (1st harmonic), 200hz (2nd harmonic) and 400hz (3rd harmonic) but a weak signal at 50hz (the fundamental), it will "restore" or "recreate" the 50hz signal. So it's only really useful if the fundamental is truly "missing". If the music you're listening to simply has limited bass content, then you are using the Epicenter outside of it's intended purpose. It's not supposed to be used to add bass to songs which were composed with limited bass content, only songs that had the bass unnaturally filtered out at some later point. In general with most of today's music and sources, an Epicenter is pretty useless and does more damage than good. Most people still using them are intentionally (although maybe unknowingly) using them incorrectly. Shameless plug: Damping Factor What exactly is it you want to know? -
LOL....always nice to see manufacturers combating ignorance, even if it's just a brief footnote! Glad you guys find this thread useful
So, I got bored and decided to make a lamp out of some old speaker parts I had sitting around. The components used are the soft parts from an RE MT that Nikuk mailed to me out of the blue nearly 5 years ago, and a basket and vc former from a Next 6.5" speaker. I used the basket as a base for the lamp and epoxy'd it to the bottom of the former of the MT softparts, which serves as the main body of the lamp. I used the former from the Next speaker to fill the gap between the MT dustcap and the bottom of the lamp fixture. The end result; Still need to decide what I want to do for a lamp shade. Thought about trying to make one out of speakers grills or the like. But I figured this lamp would compliment the clock I made last year; Yeah, this is what I do when I get bored.....
Id like to learn what all the specs mean on a sub
Impious replied to Lifted07Duramax's topic in Subwoofers / Speakers
http://en.wikipedia.org/wiki/Thiele_small -
Don't go active. Active is not for everyone despite what the internet would lead you to believe. There is a certain level of knowledge required to obtain decent results active. If you don't understand how many amplifier channels are necessary for going active, then you are not yet at a level of knowledge capable of doing so. So either wait and spend a lot of time learning and gaining experience and knowledge.....or stick with a passive setup for now.
You can obtain equivalent or superior performance for less cost. Like anything else, some people love them....some people don't. More details about your system layout, goals and budget would be necessary to really assist you.
Line Drivers
Why do you think you need one?
