Impious
SSA Tech Team
    6,708
  • Days Won
    149
Everything posted by Impious
  1. There are advantages and disadvantages to both. To call one better than the other, or to call one a joke is, well.......a joke.
  2. Or space issues as you can use smaller 16v batteries as the current draw will be much lower... It's something that takes a lot of planning.. And some know how. By the time you factor in the increase in power as a result of bumping the voltage up to 16V, current draw would probably equal or exceed that of the same amplifier running at 13.8V-14.4V. Even excluding an increase in power, if we leave power constant the difference in current draw between 14.4V and 16V is going to be ~10%. And the increase in power would be 100% inaudible. Not worth the time or expense to try to do anything like this for a daily driver system. You're better off focusing on maintaining a proper "normal" voltage than trying to increase the voltage up to 16V+. For competition it can make sense. For daily driver systems, it's complete waste.
  3. Impious
    Extremely Disappointed
    I hope so... I've spent plenty of $ with them to at least get a recone and some epoxy out of it.... Don't see why you'd expect a company to fix your screw up just because you've spent "plenty of $ " with them. If you cooked the coil, you cooked the coil. And that coil is cooked, whether you did it intentionally or unintentionally. Admittedly running the amplifier at low voltage doesn't help your case either. Fi might help you out, I wouldn't be surprised if they did just to be nice. But acting like you deserve it or something is owed to you is a jackass way of going about it. They don't owe you shit. EDIT: Didn't see Nick's reply before I posted.
  4. Impious
    Can Anyone help me solve my problem?
    Really hard to help you without a DMM to check the coils and wiring. If you don't have one you can borrow from someone and money is really that tight......go to Walmart and buy one. Use it for the day or two it takes to figure out what's going on....then return it (make sure you keep your receipt). I typically don't condone this type of behavior but it's going to be really hard to troubleshoot without one.
  5. Impious
    JL tw5 13.5 or SA8
    Not sure if you saw the thread on DIYMA about the new Alpine Type-R's, but there was an Alpine engineer on there discussing them and I must say I was pretty impressed. They actually took some time to re-engineer them and did some important things like focusing on linearizing BL, etc. There was more info in there about the normal R's than the Slim's from what I recall, but if they put the same focus into the Slim line them I wouldn't be surprised if they were solid drivers as well. link? http://www.diymobileaudio.com/forum/diyma-sq-forum-technical-advanced/91741-alpine-utilizing-xbl.html
  6. Impious
    Sealed Box.
    I'm a little confused. Why do you want to run them sealed, when you're almost done making it a ported enclosure?
  7. Don't worry about the preamp voltage.
  8. Impious
    JL tw5 13.5 or SA8
    Not sure if you saw the thread on DIYMA about the new Alpine Type-R's, but there was an Alpine engineer on there discussing them and I must say I was pretty impressed. It appears they actually spent some time on quality re-engineering them and did some important things like focusing on linearizing BL, etc. There was more info in there about the normal R's than the Slim's from what I recall, but if they put the same focus into the Slim line them I wouldn't be surprised if they were solid drivers as well.
  9. Impious
    Leviathan questions
    If your headunit has a highpass crossover that you can use, then you could use the highpass built into the headunit to highpass the signal. Then you would just need the amplifier to lowpass the signal. And why do you want/need so many speakers?
  10. Impious
    Surround Sound in Vehicle
    Just tossing speakers in the rear doesn't give you "surround sound". The sound might surround you, but it's not "surround sound" in the sense used today with the rear speakers playing the proper (i.e. non-staging) sound information. Surround sound and other similar formats would need to be properly mixed in that manor into the recording (or a suitable processor capable of "upconverting" standard stereo to such a format). The vast majority of music is recorded and replayed in a standard 2-channel stereo format.....in which case, the rear speakers are typically a hindrance as helotaxi pointed out. Confusing the soundstage and producing undesirable frequency response affects. That said; there is some merit the a properly utilized rear stage. This isn't as simple as just tossing some speakers in the rear of the vehicle. To begin to approach a useful result with rear speakers, you would need a L-R (left minus right) summed signal, bandpassed and time delayed. The speakers here wouldn't play a prominent role in the system. They would be used for ambiance only since basically any of the real "center staged" info is removed from the signal via the left minus right signal summation, leaving you essentially with only the left and right ambiance/reverb stuff. Never tried it, but always sounded kinda fun. Though with all of the true surround sound processors available, those are probably a better/easier option since that's specifically what they were designed to accomplish. Some people swear by surround sound (actual, properly implemented surround sound) for the added ambiance and spaciousness. I did listen to GrampaDon's (another user on here) system in Logic7 and to be honest....it didn't sound all that different. Though it could have been something in the setup or vehicle.....he has a long vehicle with the rear speakers all the way in the back, and IIRC he was just using the 20w amp built into the MS-8 for rear amplification.
  11. Impious
    Boston Acoustics SPG555
    2nd page of the manual lists T/S parameters: http://www.bostonaco...s/SPG555Man.pdf
  12. Impious
    Leviathan questions
    I mean the signal being input into the amplifier would need to already be bandpassed. Yes, most commonly accomplished either with the crossover capabilities of a headunit or an external processor. I don't know off hand if the 360.2 has the capability to bandpass or not.
  13. Impious
    loudest $300 sub
    Then you didn't do something right. Being square has nothing to do with it.
  14. Personally I would try to step up to 0ga. But the length of 4' isn't a problem.
  15. How much power are you going to be running?
  16. Is there a short in the power wire somewhere, or possible that the connection is making contact with something? Can you make the event happen, or is it completely random? Are you using the internal amplifier in the headunit?
  17. The chassis of my vehicle, so 15' or so.
  18. Impious
    Stupid Question
    They are different beasts, but physics remain the same. Some people do things more because it gives them a warm, fuzzy feeling inside than any logical acoustic purpose. But, let's look at this a little more. First, we would need to determine the potential for standing waves within the enclosure. From what I could find the formula for determining the fundamental frequency for standing waves is; f = V/2d Where: f = Frequency V = velocity of sound d = dimension of the parallel walls His enclosure looks to be around 54" tall (based on the approximately 18" cutout on the baffle, it looks like the overall height is around 3x the size of the cutout, so we'll guesstimate 3 * 18 = 54). The velocity of sound is around 1130ft/sec, or 13560in/sec. Using the above equation, this would give us: f = 13560/(2*54) = 125hz So, the fundamental of the standing wave in that enclosure would be 125hz (there will be standing waves at the harmonics as well, but we'll ignore those for the moment since they'll be far enough outside of the bandwidth to not really matter). Where is the typical subwoofer crossed over? 60-80hz? With a fairly steep slope? With a 60hz lowpass and 24db/oct crossover, the output from the subwoofer itself would be attenuated by 24db before you would reach the standing wave. You would be well outside the operating bandwidth of the subwoofer, at 125hz the output from the main speakers should be dominating the response of the system. So that standing wave won't really be much of a problem to begin with because it will be well enough attenuated and outside of the bandwidth of the subwoofer . But let's say we do feel that the 125hz standing wave is a problem, maybe we plan to use the subwoofer up that high. We can't only worry about the standing wave itself....we also have to look at what is done to "fix" the standing wave problem if one exists. This guy felt that lining his enclosure with OCF (open cell foam) was a good solution to the problem. Now, the absorption coefficient of an open cell foam is directly related to it's thickness (among some other things). He doesn't state what the thickness of the OCF is....but the wood is 3/4", and the foam appears to be somewhere around twice as thick, so let's assume it's 1.5" OCF. What is the absorption coefficient of 1.5" OCF at 125hz? (absorption coefficient is how much energy is absorbed by the material). It's probably going to be ~ .1 or so, which means it's only absorbing 10% of the energy. 90% of the energy is still present. Pretty ineffective treatment, wouldn't you say? So let's say you have a really large subwoofer enclosure that has a standing wave right in your problem area, say 50hz (you would need to have two parallel enclosure walls approximately 11 feet apart to have a standing wave close to 50hz). You are not going to be able to throw some 1.5" or 2.5" OCF on the enclosure walls and call it a day. The absorption coefficient of that thickness OCF is going to be virtually zero at 50hz. The foam would need to be incredibly thick, and ideally spaced away several inches away from the enclosure walls, to begin to have a noticeable effect. Not something easily accomplished. So, moral of the story. Most people aren't going to experience problems with standing waves within the enclosure for subwoofers. If they do, then the solution shown in that link (relatively thin OCF) is not going to do much to solve the problem anyways. Polyfill has a different goal. The goal of the polyfill is to "trick" the enclosure into thinking the enclosure is slightly larger than the physical dimensions. It can work for this purpose. But the lining on the enclosure walls are not polyfill. For polyfill to work, you need to restrict the movement of the air within the enclosure. Polyfill is essentially pillow stuffing.
  19. Impious
    Stupid Question
    Folded or not, still not enough length/area to do anything in the true subbass frequencies.
  20. Impious
    Xcons: Infinite Baffle
    No, you don't need to completely seal the trunk itself (and really, you wouldn't want to for other reasons related to the vehicle itself). Some people get crazy with silicon and expanding foam and everything else to seal off the baffle. I run my subwoofer "IB" firing through the ski-hole and didn't go nearly that far in sealing. I doubt anyone could tell a difference in my car. I wouldn't leave gaping holes of course. But I didn't use any silicon or expanding foam or anything for sealant.
  21. Impious
    Can someone from DC Power Contact ME!!!!
    How you can blow waiting 22 months for an order "way fucking out of proportion" ?
  22. Impious
    Stupid Question
    Just as an FYI, you aren't going to fit a horn that actually functions as a horn into the lower subbass region to fit into a car. Most of them won't fit reasonably into a house, unless the house is built around the horn. Any "horn" that fits in a car, much less in a trunk, isn't functioning as an actual horn for very much of it's operating bandwidth.
  23. Impious
    Did you even read my post? I specifically answered your question. Are you trying for a true infinite baffle setup? I don't think you are, and 3x VAS wouldn't cut it if true infinite baffle was your goal. For a true infinite baffle setup, Qts = Qtc and Fs = Fc. You need more than 3x VAS to accomplish this. The 3x VAS rule of thumb is more of a "close enough" approximation to a true infinite baffle alignment. I think you are trying simply to run "enclosureless", which for the most part is the best we can do in car audio and what we in car audio refer to as "infinite baffle". It's a technicality in definition. Just because you won't be truly "infinite baffle" doesn't mean the enclosureless arrangement won't work. What's the difference between enclosureless in your auto and true infinite baffle? It's easy to model in any enclosure program, and I briefly outlined in my previous post how the drivers will respond to being ran enclosureless in your vehicle. Any sub can be ran IB. The only fear of "damage" is in the fear of the person operating the controls (you) not knowing when enough is enough....and this can happen in any enclosure, it's just that with IB the mechanical power handlling is lower than a sealed or ported enclosure.
  24. Your argument is stated incorrectly from the start Higher voltage has nothing to do with rejecting more noise. The same amount of noise would be induced into the signal. The difference is the level that of that noise in relation to the level of the signal. This is signal-to-noise ratio, not noise rejection. But to save you some time......if you are picking up enough noise during the signal transfer that a 2V preamp output headunit isn't sufficient....then you have other problems in the system that need worked on first. If the amplifier is generating enough noise with a higher gain setting that the noise is audible during playback, then you have other issues in the chain that need worked on first.
  25. Impious
    You have to consider the environment as well. If we were talking about home audio, then yes a Qts of >.5 (ideally closer to .7) and a super-low Fs (<20hz) are pretty much mandatory. In a car, however, things are different. We get significant boost in the lower frequencies from the transfer function of the vehicle, and most times the trunk doesn't act as a "true" IB alignment. So we don't need the drivers themselves to generate flat response down to 20hz....the car helps us do that Generally there are two routes that work well for IB in a car.....low Q (< .4) and low Fs (~20hz), or mid Q (~ .5) and mid Fs ( high 20's - low 30's). If you go with a low Q/high Fs driver, then the low frequency response is rolled off too much. High Q/Low Fs (like home audio IB subwoofers) can work with appropriate EQ to tame the bottom end....with out it, they'll be too bloated on the low end. However, you have to consider how the airspace is going to affect the driver. Chances are you're going to get some increase in Q as a result of the trunk. According to Unibox, in a 15cuft enclosure with two 18" Xcons the Qtc would be .63 with an F3 of 43hz......models pretty well for mating with the transfer function of an automobile. Maximum output is the same as that of a sealed enclosure because peak output is limited by the same factor; peak linear displacement. So the output potential isn't any lower with drivers mounted IB compared to sealed. The difference is in the response curve. Sealed enclosures will usually have a little more output in the upper-subbass (above 40hz) due to the peak generated by the affect of the enclosure.....however, IB drivers will typically have more output in the lower frequencies (40hz and below) due to the lack of enclosure (a sealed enclosure is essentially a highpass filter, so if you remove that you improve low frequency response). So to say drivers mounted IB have "less output" is typically incorrect as you have to consider what frequency region is being discussed And maximum output potential is equivalent between both alignments. As for power.....don't apply more than is required Mechanical power handling is reduced for a driver mounted IB since it doesn't have the "spring" of the enclosure to aid it mechanically. Unibox says you wouldn't hit Xmax in a 15cuft enclosure with 3500w until 12hz......but I would focus on what personal experience tells you there. Long story short....go for it Just be careful, IB drivers are easier to overdrive.
