669 -
Days Won
2
Content Type
Profiles
Forums
Gallery
Everything posted by Punkeyboozter
dang you are right noob question... im just like a kid in a candy shop so excited...i hope i can atleast see 140 though
any idea what he/we can exspect(score wise) with that gear out of a trunk?
mmm ok that is what it is then poor choice of words and if money is not a issue by all meens go ahead. personally im going to build it myself and just get someone to carpet it for me.
bro i think they might rob you (no offence).. i think its cheaper to build your own and at the end of the day you learn something and get that special feeling of satisfaction. im getting the same gear at the end of the year it be good if you can post some pics very intrested to see how it turns out and if you can get it on the termlab that would be great two ... getting loud in trunk cars sweeee
ya your customers are very wise.. my installer confirmed should work just fine thx now from "Your" exsperience should a 110 amp alt work with two biggish deepcycle batts using only around 2000RMS into 1 ohm from the saz 3000 D or am a I better of with a diff amp? the plan is to power two BL 12;s but my electrical is weak and here where i live its about as stong as it will get..not to mention i pay about double for everything you guys use... at least the amps are very reasonable here
Custom bracket
Punkeyboozter replied to Punkeyboozter's topic in Amplifiers / Head Units / Processors / Electrical
so wireing shouldnt be a problem? if i end up going with the saz as mentioned above and use the 110 alt using OEM alt will that be enough with the two bats? -
Custom bracket
ok I found someone that are willing to make me a backet.. they use to make a lot of these in the old days apparently now the guy is conserned that the wiring might not be compatible with my ECU. the plan is to run a SAZ - 3000D at 2000RMS into 1 0hm. Reason why im not going for a t2000BD is simply cos i can get the saz for cheaper "New" the other option the guy said was to get a factory alt but they only go upto 110 AMP and add two deepcycle batts.. will this be enought? im starting to pull my hair out over this. thx -
Custom bracket
lancer glx there are plenty space.. worth the risk? car about a year old so if something go wrong ill feel the pain -
any one...perhaps any one from sundown who can answer this?
thx for all the help guys.. what you discribe above is like gain matching with any other headunit right?so where will i get a -0db sinewave and wich will make for a better H/U at the end of the day?
sorry care to exsplain? and how do i test this? i dont have a o-scope but the thieves at the audio shop will let me use it $100 bucks a go whould it be better to stick to a 4V deck. I think at the moment its pretty much between the eclipse 7200 and the 9887
if you get the 9887, you wont need the 701 the 9887 wont even work with the 701, all you need to go active, is already built in, you can go for a 3 way active system and (inofficial) use imprint, official imprint only works with a 2way setup, but thats bs what is the inofficial imprint? and 3-way i.e. 2way + sub?
ya i actually use to have a kenwood 2 back in the day, but here every one is alpine and pioneer crazed. did considder the p80 as well but imaho id rather get the 9887 for that money. can this deck you are referring run active? 2-way +sub? may i know the model you are referring 2 pls? thx
so is it safe to say that it can be done safely? or would you guys recommend i go with another unit that can run active? i dont want to turn the knob 5 times to get a good volume either my current sony if i turn it to twenty its about where i want it. btw if i change i cant take double din unfortunatly
if i use a 5 M RCA will that change any thing? The thing is i really want to go active a this thing comes with coper chasis and what not. will a 9887 with a 701 be a better option?
thx guys now i really cant wait till the end of the year sweee btw "sec" i have the same opti amp aswell with a matching 2000D opti till i can afford the saz
hi im planning to get 2x fi BL12's (cooling + flatwind)but live on a isolated island and every thing is pretty hard to comebuy. the plan is to get a saz 3000 d to run them but my electrical will struggle. till then... so how will 1750 RMS into 1 ohm push them for the time being? and lets say i build a fart box and use only one woofer will it take 2000 RMS into 0.5 ohms for 3 seconds or so? thx in advanse
ok thx guys.
Hi Guys, So I want a SaZ 3000D and nothing else. problem is i know my electrical might or might not make it. All i Need (for the time being) is 2000RMS into 1 ohm problem is; im half way around the world and no one is doing a alt for my car. at the moment im pushing 1200 RMS (mono only) into 2ohms and dont have any problems with my all stock electrical the plan is to get the big 3 done and two identical deepcycle battery's im planning to push the 2x BL 12's if any one would want to know my current amp will do 1750 RMS into 1 ohm but somehow i think a big amp working not so hard will give better results then a smaller one driven to its max ?? + its a sundown so i got to have it. might be the old model (if that will make a difference)as not many people use it in these parts so they might have been on the shelve for a while. So can this be done? thx in advanse any advise are welcome
o ok ill wait for him to reply, i might be able to get hold of a stinger as wel.. you guys are so lucky when it comes to prices btw i have the same voltmeter you have in your linc very clean car thx for all the input
so does that mean i should be ok? we dont have much battery choices here either what should i be goig for? ive been told to get two of the same batts one under the hood and one in the boot. this is two options i found. the first one wount fit under the hood unless i get a smaller one http://www.carsounds.com.sg/shop/index.php...p;productId=809 Ameron might have a few more but none that i can find at the moment should i stick to the same bats or can i keep my stock and just add the other two of whatever i end up buying?
wow didt exspect so many reply's any how i made my first real post under sundown asking about electrical if any one can add to what has already been said or advise me in any way that will be great. thx
hey guys, well not really a noob as ive been lurking around but sometimes you just have to ask some questions. and as i was banned from ROE cos some MOD dint like me telling him he was talking about lineconvreters. any way you guys seem nicer anyway not to mention you have a larger audience here. check you around
i was afraid that might be the case. i only need 2000 RMS at 1 ohm. and only use it while driving. what is the mimum alt size recommended to use this amp at full potentioal....along with two deepcycle batts. i have a amp that will do 1750RMS into 1 ohms and 2000RMS into 0.5 would you suggest i rather keep it. its a so-so amp opti 2000D i think one of the models originally desighned by ZED <this might or might not be. maybe my ass is just itchy but i really wish i could run the saz savely
thx guys.. i think stock is a puny 85 amps with my current setup its resting around 13.7 for most of the time and hardly ever touch 12 unless i abuse it a bit
