cobracommander
Members-
110 -
Content Type
Profiles
Forums
Gallery
Everything posted by cobracommander
270amp alt in a 99 Dodge Dakota
cobracommander replied to kjmass21's topic in Mechman High Output Alternators
looks nice, that would fit about 8 of the last cars i owned (standard chrysler mounting) -
Boss Audio Amp. Does Anyone Know Actual Power?
cobracommander replied to SpeakerBoy's topic in General Audio
probably around 1200w or so going by fuse rating, not really worth it -
anyone else have a late 80's chevy pick up?
cobracommander replied to jonbearsmt's topic in Automotive and Performance
so fkn slam it -
I have 2 MJ18 8ohm if interesed. They would go great on a 1000w dayton amp or a behringer. They do IB or you can put them in big ported boxes tuned low. That would be plenty for a room that size. PM me if interested.
Did I waste my money on these subs?
cobracommander replied to bassmaniac's topic in Subwoofers / Speakers
i was just gonna post something like this lol Q would have been a better choice for a sealed box using bass boost will throw you 'flat response' right out of the window, i mean think about it, you want a flat response but you are dialing in probably a 12db boost at 40hz. you could have built a ported box and tuned it low probably mid to high 20s and have a flat response yet retain more output what kind of music do you listen to, if you say rap or rock (most) forget a flat response or 'sq' because i gurantee that isnt the sound you are looking for, unless you are listening to jazz or classical -
graveytrain
it would be good for 2
sont ever say max peak power again, but yes it should work good
could do a pair of amps, run each one at 1ohm or strap a pair
shoulda got dual 1s but kicker probably would be you best and cheapest bet, might be able to find one used
try turning it around or seal everything off from the trunk
nothing really
there was like a 20 page thread about this on ca.com about a year and a half ago
www.modifiedpowerwheels.com you can swap gear boxes, motors (they use rc car motors), use bigger motors, i beleive they have a 300 series motor and you can put in a 500, or it might be 500stock then go to a 700, i forget, theres a ton of stuff you can do, also wheel size effects gearing. Havent messed with my 2 for a while, my daughter is getting older and doesnt ride them much. BTW I ride hers (with upgrades) and i weigh 150lbs. It goes no problem.
with the same amp it would but a class a/b amp compared to a class d, no. But then if you run the class d at 4ohm it wont produce the power it will at 1ohm
Just because its a IB sub doesnt mean it can only be used that way, He has a work log on ROE, its quite interesting never said he couldnt, maybe you need to reread.
I would be a nice time for me! I want a 21
buy the cheapest fi possible so you are cool i guess will it work? yea. Would it sound good? Who knows? And I always like putting something in front of the port. What does that prove? I could drill a half inch hole in my box and air would shoot out at mach 30. I guess that means it louder.
buy this $125 http://www.caraudio.com/forum/showthread.php?t=388607
gay video
buy my other 2
the germans were designing one in WWII
