Dee
Members-
91 -
Content Type
Profiles
Forums
Gallery
Everything posted by Dee
I have explored that option.. But with the 15s due to lack of space. Also looked in to re audio mx 15s senct they can be put in a sealed box.. If i build a walled enclosere i would gain some more air space. Only reason i put 5 cuft for the box is because it would be a strugle to get any thing bigger in
The sealed box would passably allow me to add more cone area without dramatically increasing the actual side of the box (port & extra bracing displacement) They sometimes offer more accurate bass but not always. If I can find 2 12s that would have a lot more output than an 18" bl then i would take those hands down.
That's what i was thinking. Other options I have breafly researched were gettin 4 12's in a sealed box. In doing this more cone area will be present (in theory) but that allwais dosn't mean any thing. Or Walling off my my trunk to turn that into a box, but (in doing that) i would have to fire the subs away from the cabin (not sure how that will effect responce mainly because I rearly ever see anyone fire the subs in a walled enclosure anywhere but foward. I am also flexable on the budget
Dude, I am goin to amp up my door speakers and use the 360 to its full potental. I am waiting on speed cable and my 4ch rcas to come in while i was deciding on what 4ch to get. I am simply asking how can i get more bass out of my car. And please show me where i said I said "I wanted more SQ from my woofer." I said i want it louder with some reasonabal SQ, I know SPL and SQ are complete opposites and its eather one or the other.
i have some pics of some horrible installs..ill post tamorro morning
fi Bl 18 with type r 10 & kyrocera phone
2 15" Q 1500zx or PA4000 amp?
Dee replied to smiley's topic in Amplifiers / Head Units / Processors / Electrical
get a battery instead of the cap..do big 3 upgrade at minimum while upgrading alt is also a good idea.. -
any idea when they will be back up..just got the money wen they took it off
I've noticed that too, i tried 4 different computers earlier and its the same deal. Only the Bl page doesn't pop up.
I just noticed something similar to that happen to me about two days ago.. My subs (L5 15s) sound like there's something lose back there, like paper or something flapping around. The cone seems fine, I haven't pulled them out the box yet but what do you guys think that could be.
Those are 18's, try fisher customs or pound that sound
That's the code for web pages.. One for forums would work or just the direct url from the adress bar of the video would work here
A Fully loaded BL 15 would be better
I have a question similar to the one in this tread. What is the benefit of getting a Kinetic Power Cell over just a regular Optima Yellow Top as secondary batteries? Wouldn't the Yellow top be better in daily enviorment because of how it was designed to drain all the way down and charge back up without being damaged? Shouldn't that come in better use for those long bass notes? sorry if it seems a little cluttered.
he is right only options u have with 2 dual2 woofers is .5 ohm, 2 & 8.. dual 1s are what you want but about that hu thing id check to see if scosche makes some kind of adapter that integrates your after market hu and keeps functions on steering wheel. could be a bit spendy but if its that important then that's what you want to do.
up grade your front speakers:P
I am looking into getting a 18" Fi Bl or Q for daily use. Just a little caught in between the two right now. Is going in a Hyundai xg300 powered by a kicker zx1500.1. my only concern is space(32w 17h 33d) those are external demolitions before displacements if i go with the bl it has to have a ported box and they tend to be bigger than regular sealed boxes. i would prefer to do this by making a deep box that takes up my whole trunk but at the same time i wont be able to slide it in easily or at all if i go with the Q i am sure i can get a sealed box made that will fit in probably with a little poly fill. Only concern with that is even with the BP power option will it be able to handel a little over 1500w on a daily bases. Local Car shops want to sacrifice my back seat but thats not an option right now. Thanks in advance
Does any one know how i would calculate port height width length 1 n 2
If you guys dont mind me asking..jayson what program did you use to make that design fo that box
How accurate do you guys think the re calculator is? Would this be a good enclosure for a fully loaded Fi BTl 15 for daily use. and if this is not that accurate then where would i find a better calculator? http://img505.imageshack.us/img505/1457/boxgz3.jpg
they usualy reply back within 2 days from my experinces
It is a problem with getting it to go in. How would I go about doing that though? Build the Bottom and walls then put the top on? Or Putting one wall on the bottom and one on the top and going from there? Or is there a better way? But if that fails would a 15 hooked up the right way yeald the same result
