slam
Members
    185
Everything posted by slam
  1. slam
    What is the fastest you have gone
    495 MPH!!! proof below also went 192 on my 900rr honda
  2. slam
    re mt18 specs?
    oh thats cause only 3 are going in an spl vehicle. sorry for the confusion
  3. slam
    re mt18 specs?
    actually..... all on 16v too this is not going to be a daily
  4. If u call Kinetik they will also tell u 19.2v to charge their 16v is fine, but they dont recommend anything higher. 18.6-19.2 is recommended for the kinetik and above 20v is recommended for the batcap 8400 Still have my 16v tap running fine. Iunno what the deal was about the kinetik. Guess i wasted 150 bucks
  5. So, I bought 2 hawker 2v cells to run a 16v tap. I thought i had a problem with that setup and found out it was ok. Someone said it was a bad idea and said i should purchase a 3 post kinetik hc16v(brand new). Thought to myself that id be on the safe side if i went ahead and did it. Called kinetik personally and talk to Jon( I believe) and made sure everything was properly installed and according to my Blue Point Dmm everything was like he said. Well, let me tell u what..... The hc16v setup with the EA alt on 19.1v to the 16v side and with a digital meter with about 3 weeks of driving, the battery dies completely. Got pissed and ran my 2 2v cells now for more miles/hours and nothing wrong. WTF?
  6. slam
    Kicker l7 8's
    i bought my l7 8 for a 100 shipped. Sounds pretty badass in the center console
  7. slam
    How to do a 16v system
    no, only charge the 16v side
  8. slam
    yes u can do that or u also can use ur existing 12v battery under the hood with 2 2v cells. Its the same thing as running a kinetik hc16v battery but cheaper. and what do u know i have 2 2v cell for 50 bucks shipped lol
  9. slam
    (6) Mayhem 15's and (6) 40.1's
    yes nice score!!!
  10. slam
    how did u do at finals?
  11. slam
    lol that suks. I did that on my first ever comp but in 1992 and hit a 139.xx. Good luck tomorrow
  12. slam
    my new bl's
    looking good and im sure itll get loud
  13. slam
    Emp dual alt pics
    gotcha. u actually would be fine charging it at 19.2. u can charge up to 2.4v per cell. thats the highest recommended for the 16v kinetik. u can charge it high but u risk the batteries life u have it charging on the 16v post at 18v+ tho right?
  14. slam
    Emp dual alt pics
    yes the 40.1's. floating voltage right now is about 17.1. what amps u run on 16v?
  15. slam
    Emp dual alt pics
    gotcha. I also run 16v. tried different setups and all performed the same. but now, i run a hc16v under the hood and 2 batcap 8400 16v in the back. all an a ea alt What amps u running 16v?
  16. slam
    Emp dual alt pics
    more power... my stock 105 amp alt isnt going to do quite enough for my t30001bd sub amp and even if they made high output alts for the 2.0 ss supercharged (which i haven't seen a reputable company do so) i would probably loose a bit of idle power. Either way a 245a alt plus the 105 is going to give me the most power... not including the fact that the new alt is externally regulated so im getting a 16v charging system and keeping all my idle power and my car should never die from the system (haven't figured out how im going to wire all the highs amps thou) Either get amps that support 16v for the high freqs or run those amps on your 12v system. thats the beauty of it... the batteries im using are hc16v with the 3 post... so i can put the entire audio system on the secondary charging system (while keeping the highs amps at 12v) but my dilema is trying to keep everything running smoothly. The 2 16v batts and the 245a alt is enough to keep the sub amp happy but if i start adding more on to that its eventually going to strain a bit plus i would be wasting the upgraded battery and wiring on the stock system. My main goal is to prevent voltage loss as best as i can and im pretty sure i have enough power with both alts and 3 batterys to do so but im unsure on how the best way to approch it to get that goal. One of the main problems im looking at facing is the way the highs amps are going to be mounted and all im not going to be able to play around with it easily. So all that wiring is going to be semi permanant so u have 3 hc16v batteries and 2 alty. 1 for 12v system to a hc16v and the other external voltage regulator alty to the other 2 hc16v? suks about ur axe a dent
  17. slam
    very very nice!!! Im sure u have some tuning and itll be better then that. U going tomorrow or sunday to dallas?
  18. slam
    are we gonna have to wait til finals to see some numbers?
  19. slam
    Batteries..how many
    how much for the 50c?
  20. slam
    sundown on myspace
    <------- request sent sundown saz-100.4 owner here
  21. slam
    Pictures of my Explorer ..All kicker....
    looks like itll get nasty
  22. slam
    8" sub, need some help
    i have a kicker l7 8 in .5 cu in my middle console on a vr1000d. but since its a dual 4 its on 500w at 2ohms
  23. slam
    looks very appetizing
  24. http://www.soundsolutionsaudio.com/forum/i...&pid=420845 Purchased supposedly 20 foot flex from him for 60 bucks. When i received the wire it seemed short so i took measurement. came out to 14'11". Link above is from the thread i purchased. Pics of wire when received below He has no intention to resolve this issue
  25. slam
    Big 3
    no fuse(s) here with an ho alty
