djjdnap
Moderators
    3,482
Everything posted by djjdnap
  1. djjdnap
    custom Bridge Rectifieres
    bridge rectifier is nothing but 4 diodes....but they sell them as bridge rectifiers. You can buy one from a good online electrical site for cheap. The challenge would be getting them connected. I pretty much skimmed the thread fyi
  2. djjdnap
    Best Bass Scare Songs
    This song is pretty cool has some punchy bass notes
  3. djjdnap
    Any ideas
    well i was sitting around to day and got to thinking more about the multiple + and not - runs of wire. IN a DC circuit So it is said that voltage is used up in a circuit. thus the voltage/current going in is going to be greater going in than out. current isn't used up but voltage is but they are directly related since the lower the voltage the lower the current. But to throw a curve ball in electrons flow form neg to pos lol Soo would that not make you believe that you need a bigger ground not power wire.
  4. Only thing i can think of is shaving them down.. Then i saw another thread were it was lots of + runs and only 1 - run , which seems pointless if the power has to flow in and out.
  5. djjdnap
    From the album: Ran dum
  6. djjdnap
  7. stetsom is back.. Funny thing is its still the same burnt board with new FETS smh lol.. And DBr is saying atomic wont give up the schematics so he can repair it smh
  8. missed a package from NC today!!! weird thing is i haven't paid for anything either lol...
  9. djjdnap
    Staying motivated.
    you could really just put this on ur ipod and listen to it b4 u leave the house in the morning.
  10. got ios 5 b0 running with no ill side effects...
  11. djjdnap
    Just Joined a Gym and need Some Advice.
    wtf did this thread turn into. to lose weight is simple you burn more calories than you take in. your body is burning calories already so going to the gym is a plus no one needs to be in the gym for hours on in although i have found myself doing it before on good days. At your age man results should be pretty quick to go further to answer some of ur questions if bb.com hasn't already you cannot lose weight and gain muscle at the same time. if you lift you are going to gain mass, which is going to make you gain weight(muscle weighs more than fat) so if you are looking at the scale it will not do you justice. however muscle mass burns fat. If you are seriously cutting out the junk foods, losing weight shouldn't be hard at all. Add in some whey protein to help your muscles recover faster and keep your muscles growing....this also works while cutting. depending on ur goals you can either lift heavy now to get your muscles and later drop body fat to see ur results or go through the cutting phase now and get lean, then build on solid muscle mass lb for lb later. ur not going to be ripped at 20%+ body fat, btw Although everyones body is different and you have to find a routine that works for you. If everyone had all of the answers we would all be a 9x Olympian like ronnie coleman.
  12. djjdnap
    3 N315's gettin silly
    where are the highs?
  13. I hate... I repeat hate letting other ppl use my car. Something is always broke when i get it back.... Back from vegas and supposedbly my alternator doesn't work? WTF worked just fine b4 i left, gotta check it in the AM
    1. onebadmonte
      onebadmonte
      You got a little foghorn leghorn thing going I say a little foghorn leghorn thing going with all the repeating. :P Bummer bout the car.
  14. djjdnap
    ^^agreed find u a routine example....... mon-legs tues-cardio weds-arms thurs-cardio 30mins tops each day
  15. out here in las vegas...
    1. mccleery3
      mccleery3
      Enjoy yourself bro!
      Wish I could venture out there :(
    2. djjdnap
      djjdnap
      man im out here losin money lol... Dont believe the hype
    3. porkchop
      porkchop
      whats brought to vegas is spent in vegas, hope you didnt take all of your coin!
    4. Show next comments  84 more
  16. dam white regulator smh new reg thanks to mechman..grey/green brushes were worn something serious thats all folks btw that shim was a bch to get back in.
  17. djjdnap
    Mechman 270a
    Also the factory alts have a smaller stud where you would connect your batts too. I take it this is the reason all the mechman alts you see come with a ring terminal.
  18. jus signed up for this bodybuilding.com shredded challenge....should be fun to giv myself a challenge
  19. djjdnap
    Chop"s 86' Cutlass
    Lol man I think I used about 30 on my truck... But I have those bussbars and like 5 batts.. Those terminals get used up quick!! Propane and solder lol
  20. djjdnap
    testostorone boosters
    jack3d makes me feel good in the gym lol, has creatine everyone is on this nitric oxide fad and i cant really see the hype in it all Weights and some good whey wt bcaa's and Eaa's is whee its at
  21. djjdnap
    IAK needs an "IHOP"
    fuses both ends yes.. Both batts wired together - and + if ur running - from the front dont worry about rear chassis ground, but its up to u and wouldnt hurt. in ur case id try this one unless ur gonna get some buss bars
  22. djjdnap
    Chop"s 86' Cutlass
    ready for this wall to be done lol
  23. djjdnap
    Mechman 270a
    i meant a lmao not xp the white regulator is for pcm controlled cars the grey one is for 'regular' car lol
