djjdnap
Moderators
    3,482
Everything posted by djjdnap
  1. Could have been my GIMP editing lol http://infiniteinnovations.thomasnet-navigator.com/category/all-categories-limousine-parts-dual-alternator
  2. djjdnap
    SLOW build on a 2001 GMC Jimmy
    well that almost makes me want to seal my boxes when i take them out, i still have a ton of stain and sealer from working on new cabinets
  3. djjdnap
    Best Car alarms ?
    The fobs are where companies stick you. I got a 80$ alarm came wt 2 fobs, broke 1, so i decided hey let me get another 1 and its more than the alarm now, smh.
  4. djjdnap
    NAV EXP Alternator Instructions2
    From the album: Ran dum
  5. djjdnap
  6. djjdnap
    L3 1030
  7. djjdnap
    adjusting voltage?
    That makes some logic. The sensing wire just reads the voltage and adjust the alt to keep it at a certain voltage basiclly if your alt is reading 15.3v and the sensing wire is reading 15v, its going to think oooh i need .3+v and crank out 15.6v, but think its only putting out 15.3v
  8. everybody wish they can get shit they don't do shit for
  9. Copper has one of the highest electrical conductivity rates amongst metals. The negligibly higher resistance from the aluminum tho just depends on the application, most people wont see the difference other than in their pocket. 1-4. - Comparative Characteristics of Copper and Aluminum CHARACTERISTICS COPPER ALUMINUM Tensile strength (lb/in2). 55,000 25,000 Tensile strength for same conductivity (lb) . 55,000 40,000 Weight for same conductivity (lb). 100 48 Cross section for same conductivity (C.M.). 100 160 Specific resistance (W/mil ft). 10.6 17 I mean why buy shoes from Payless when i got enough money to buy Jordans thank u goodnight
  10. i didn't read anything just posting e=ir p=ei 6kw=14.4*I I=417Amps Max
  11. ^^^ IE sealed = more power Higher tuning = more power lower tuning = less power sealed and higher tuning doesn't give the sub an exhaustive workout as 20hz and below would. I could be wrong tho..Bonjour
  12. djjdnap
    IAK Slamology roll call
    Oooh. Sounds like a trip to sunset strip is in order. certified booty lmao
  13. djjdnap
    Chop"s 86' Cutlass
    if you need help im down the street
  14. djjdnap
    Recommended fastners for the 18" N3?
    After having my subs stolen I tend to add 2 of these. On each sub as well Except i get the 2" long ones and whip out the air tool to zip them down. A thief would be all day with a ratchet. Just my 2c
  15. djjdnap
    Chop"s 86' Cutlass
    just link them from facebook
  16. djjdnap
    Senchez if you bring some decent clothes maybe I can get you in a club this time lol
  17. djjdnap
    Lmao it does say Pre Show: 1X BEAT OFF Friday Night
  18. djjdnap
    u know u have to post details or is that a post count tactic?
  19. djjdnap
    SSA Dickies L-5XL Now Available
  20. djjdnap
    building a box inside the trunk
    1.:take the trunk lid off. Drop it in. 2:Take the trunk lid off if it doesn't fit cut out whats stopping it and weld it back up..
  21. man you would have to run a wire all the way to the front or rear depending on mounting. And its only got 3 post
  22. djjdnap
    Recone?
  23. djjdnap
    Recone?
    ehh i wouldn't recone it. I look at recones as a coil problem, but thats just me
  24. http://www.irv2.com/forums/f54/equalize-batts-with-which-charger-87298.html Lots of good info
  25. the second part is true as well depending on your charger. A smart charger will charge until it senses that the bat is fully, if you have multiple batts it will charge until it senses 1 of the batts is fully charged. Leaving the rest of the bank and whatever level it charged to prior to the other being fully charged. If you have a bulk charger you can charge them all for as long as you want because it doesn't have any sensing technology. The problem is you risk overcharging and damaging the batts. Think of it as you have multiple buckets of water. All are attached to the same hose. You turn on the water and they all fill. Lets say all the buckets are at different levels. After one gets full you turn the water off. the other buckets are still not full, only one is.. pretty much why they say you should have the same batts, and same age.
