jntar
SSA Regular
    11,141
  • Days Won
    2
Everything posted by jntar
  1. jntar
    Welcome to the IHoP
    Seems to be the best idea I have going. That way I could make it in one larger piece instead of several smaller pieces and have to fuse them together.
  2. jntar
    Welcome to the IHoP
    Will it melt?
  3. jntar
    Welcome to the IHoP
    Any thoughts? ^^^
  4. jntar
    Welcome to the IHoP
    I have the idea to get a large "brick" of styrofoam and shave it in the shape that I want, glass over it and pull the foam out and have the console. Will it melt the foam? Should I tape the whole thing or will wax paper work?
  5. jntar
    Welcome to the IHoP
    both of you have glassing experience.
  6. jntar
    Welcome to the IHoP
    I have a few ideas for the console.
  7. jntar
    Welcome to the IHoP
    TOP
  8. jntar
    Welcome to the IHoP
    shipped both the Orion 600d and the Viper 1200.1
  9. jntar
    Welcome to the IHoP
    removed subs and amps
  10. jntar
    Welcome to the IHoP
    Went from passive to active x-ver for the system
  11. jntar
    Welcome to the IHoP
    Detailed the truck
  12. jntar
    Welcome to the IHoP
    I had a very productive weekend.
  13. jntar
    Welcome to the IHoP
    He sits on the Net all day like the rest of us.
  14. jntar
    Welcome to the IHoP
    Loozer
  15. You guys pick. Memphis amp or Viper amp. Viper claims to put out more power, the memphis is rated at 1100 but birth sheets that I have seen prove that it can put out 1200-1300 watts. I kinda thought it would look cool to have matching memphis amps. Just want to get more thoughts. Memphis http://www.sonicelectronix.com/item_3002.html# Product Description: 1100W RMS Class-D Monoblock Subwoofer Amplifier Custom Black Pearl Finish Fully Variable Low-Pass Filter: 50 - 250 Hz, 18 dB/Oct Variable Subsonic Filter: 20 - 50 Hz Bass Boost: 0 - 18 dB Gold-Plated RCA Connectors 4 Gauge Power Wire Capability Wired Remote Gain Control Power and Protection LEDs Thermal, Short Circuit, and Overload Protection RCA Outputs: 1 Pair Adjustable Input Level Control: 400 mV - 4V Damping Factor: 300 DImensions: 13.4" L x 6.25" W x 1.7" H 1-year Sonic Electronix warranty Amplifier Specifications: Number of Channels 1 - Mono RMS Power (4 ohms) 300 watts x 1 chan. RMS Power (2 ohms) 600 watts x 1 chan. RMS Power (1 ohm) 1100 watts x 1 chan. Bridged RMS Power Not Bridgeable Peak Power Output 2200 watts Min. Impedance Unbridged 1 Ohm Min. Impedance Bridged Not Bridgeable THD @ Rated RMS Power 0.75% Speaker Level Inputs No Amp Preamp Outputs Yes - 1 Pair Built-in Crossover LPF(50 - 250 Hz), Subsonic(20 - 50 Hz) Bass Boost 0 - 18 dB Signal-to-Noise Ratio 95 dB Fan Cooled N/A Fuse Rating 40A x 2 Warranty 1-year SE Viper http://www.drdetailshop.com/vd1200.1.htm Dynamic Power Rating: 1500 watts S/N: > 80 dB Freq. Range: 20-250Hz Damping Factor: > 50 Input Sens.: 150mV to 8V Rated Power @ 4 ohm: 450 x 1 Rated Power @ 2 ohm: 800 x 1 Rated Power @ 1 ohm: 1200 x 1 Crossover: var. 18dB low-pass Bass EQ: Yes 8 dB RCA Output: Yes, mono Protection: T,S,D,R,O,L T=thermal, S=short circuit, D=DC offset, R=reverse polarity, O=over/under voltage, L=status LED Nobody does class D like Directed, and the 2002 Viper amplifier lineup makes that clear. The tiny d300.1 delivers more bass power than conventional amps twice its size, the d600.1 and d1200.1 can be strapped together to double their individual power, and the d2500.1 has enough power to run most major appliances, coming in at a true 2.5KW. And if that
  16. I hope not. I can always use it and if I notice any I will sell it pronto...
  17. jntar
    ALO!
    Welcome to SSA!!
  18. jntar
    Washed, Waxed, and Detailed
    2 hours and 30 min. Washing took an hour cause I hadnt done it in a month, I always do it twice wiped it down and let it sit for 15min in the sun. detailed the rims 15 min waxed and buffed the entire truck 1 hour.
  19. jntar
    Come on over...
  20. jntar
    Welcome to the IHoP
    I think that its funny how the douches in the back ground are telling him to kill it.
  21. jntar
    Welcome to the IHoP
    I take bigger pills then that you pansey. The best ones are the manna C, if you dont take them with a full glass of water you get a bacon taste in your mouth that wont go away until you eat Just so you know, you can take them with anything you want, break them up and put them in some pudding You will still get the same affect as long as you take it on a regular basis.
  22. jntar
    Hi!
    Welcome to SSA!!!
  23. jntar
    Welcome to the IHoP
    awesome bro, wish I could hear it, but I have to be in Gulf shores the weekend I was suppose to come up. lol <{POST_SNAPBACK}> Its cool, you will get to hear it eventually
