18,365 -
Days Won
212
Content Type
Profiles
Forums
Gallery
Everything posted by nem
You can go smaller, check the stickies in the Fi section. A sealed enclosure might suprise you, it might be worth a try.
Looks awesome! Be sure to post some pictures with the leds on.
If you are able to build a box like that go ahead. You have very limited room to work with. Just an idea, why don't you try a sealed enclosure fisrt to see how that sounds.
Looks different. Can't wait to see the finished product.
All are very good subs. You have a tough decision to make.
Does this mean he is now happy Oscar
That's awesome, I hope i'm impressed, everything I've heard about SSA is nothing but great! I am sure you will be impressed with that combo.
I have never used hifonics power, but from what others have said they do rated power. I think you will be happy.
Which is better?
nem replied to lamchop_8's topic in Amplifiers / Head Units / Processors / Electrical
X2 -
The ssd is a good choice for that price range. If you go sealed, keep you enclosure close to 1.1 to 1.4 cubes. What are you powering it with?
Good luck and keep us updated.
You could try these numbers to get you started. Put these numbers into the ssa box builder. You can adjust them to better fit for truck cab. I have the copper option and like the sq it adds.
I would not do that. Build a new box.
That is going to be a tight fit. The mounting depth of the sub is 7" correct.
It looks like you have quite a nice collection of equipment.
What are the deminisions you have to work with? I will help you.
Any updates on this build?
http://www.soundsolutionsaudio.com/product...sure_tools.html Use this link and as you adjust your enclosure size and port length you will see the tuning change also. Try to keep it right around 32 to 33hz if you can.
Use the box calculater on the SSA main page.
Hope you chose D1 coils so that you can run the amp at 2 ohms. If you have the room go 2.2 cubs after all displacments and tune to 33hz. It should get plenty loud with that amp. Good combo by the way
