dbjunior
Members
    673
Everything posted by dbjunior
  1. first dont bother with c/b just use fuses. you want a fuse newxt to stock battery and on the other end before the rear batts. connect the 1/0 from the front to the rear batts then from the batts to the amps. the speaker amp will connect directly to rear batts like the sub amps. as far as grounding the batts a solid frame ground should work for rear batts but a 1/0 run from the front batt to back batts is preffered. dont forget to do the big 3.
  2. dbjunior
    One loud Trunk
    with or without sec amp music or tone.
  3. dbjunior
    Sundown Audio Amp Review And Amp Lights ?
    if flashy lights are the most important thing get the hifonics. if quality products and amazing customer service are whats important to you go sundown.
  4. dbjunior
    Dual 12" D-CON project
    what you doing with the 12's giant midbass for the minivan.
  5. dbjunior
    Flared vs. Standard Slot Port
    audible performance diffrence i doubt it, on the mic you might see a .1 or .2db diffrence. if the port is on the small side id recommend the flares to help keep noise down.
  6. dbjunior
    FI BTL 12 (NOT HITTING RIGHT)
    the amp is a 4000w class a/b amp that can be bought new for $260 that might be part of the problem
  7. dbjunior
    flared helps reduce port turbulence and decreases the chance of port noise.
  8. dbjunior
    DC LV4XL 10''
    what you running for power? i plan to get 2 dual 2ohm xl10's and run off an atomic 5000.1 2ohm daily .5ohm burps. should get loud in a small hatch.
  9. dbjunior
    lithium
    any info on the new lithium. just one or a whole line. what are the being designed for.
  10. dbjunior
    Looking for experienced opinions
    what do ou plan onrunning for amps and what do you plan on doing for electrical. what type of music do you listen to.
  11. id look into diffrent equipment. whats your budget
  12. dbjunior
    Moving on
    id say bl tuned around 3.5cu tuned 35hz should sound good and punchy. if you still dont get what you are looking at id look into upgrading your midbass.
  13. dbjunior
    Bass Knobs
    whatever you have running to your amp for rca's you plug into the unit then run a set to the amp. if you are using a loc run rca's from the loc to the unit then to the sub amp.
  14. dbjunior
    New BTL Box
    The box sealing off the cabin and not letting sound waves go past it. i agree looks a little tight. id turn it around and seal it to the cabin.
  15. dbjunior
    SSA DCON GIVEAWAY! 2 SUBS!
    1. bazooka ELA300.1 2. slap and nespl competitor installe many systems for friends. 3. 75+ posts 4. check 5. music ( rap, rock,metal,country.) 6. several site memberships.
  16. dbjunior
    Stupid Question......
    what type of vehicle do you have and how is the box designed. my friend has 2 type r's in 4.3cu tuned to 35hz and it can do over 140 with 1200w. the right box can bring your subs alive. if you want more after this upgrade.
  17. dbjunior
    Recommendations
    aq sdc2.515 get one they are like $160 then have fisher build you a box and use the amp you have now for power
  18. dbjunior
    Mpyre Audio 65M COMPONENT
    ive seen them on ebay before and wanted to pick up a set but didnt have the money. for the price its work a try they look great.
  19. dbjunior
    Fi BL VS Nightshade poll
    idk if or when they might have the copper coil nightshade available but it might be something to look into as a middle ground between the two.
  20. 1/0 will not support that much power two runs of 1/0 each with its own 300amp fuse.
  21. passive you just run a channel to the crossover and let it do its work. active you run a separate channel to the tweeter and mid so you have the control of where to set the crossover freq. it lets you have more control for better sound quality. personaly id use a 4ch and go active and power the 6x9's off the headunit.
  22. dbjunior
    Four AQ SDC2.5 15"s
    id do a 3000 for all four maybe a pair per saz2000d.
  23. dbjunior
    Enclosure + Setup Help
    i believe meade only does high 150's. not that thats not loud its way more than most people can handle. but he has more power and more equipment than you and you think you are gonna hit the same. personally i think if you hit 150 you would be happy. the only reason to worry about numbers is comps. the tuning of a box makes a huge diffrence in output and perceived output. if someone has a comp box tunined in the high 40's and burps a 140 at 50hz it wont be anything like a daily driver that does 140 at 30hz. the 30hz will shake more and move more air seeming louder but not acctually being louder.
  24. dbjunior
    My System
    i like the flush look but it seals all the bass into the trunk. have you thought about having the sub fire into the cabin and have a plexy glass window in the back with lights in it so when you open the trunk it still looks good but you get more bass into the car.
  25. dbjunior
    dont listen to the dynamat bull ive seen competitors who have lost db's after installing matt.
