dbjunior
Members-
673 -
Content Type
Profiles
Forums
Gallery
Everything posted by dbjunior
by looking at your products alone you know your shit about subs. i have a pair of 10's i had built for me a couple years back 60lbs each so there is some serious magnets on them. the bl/re in series is only a 92 im guessing this is due to the coil. if i had it rebuilt to something with twice the motor strength what could i see in output diffrence? current coils are round copper 8layer not sure on what the rest of the specs are. i know they could use a spider spacer for more travel they will hit the top plate before the coil can bottom. is it possible the charge is weak on the magnets?
i wasnt refering to actual looks of subs more the fact every sub he has built has proven to be great at what it was designed for. yes i was refering to the BL^2/RE is 92. i read in another forum where you comented on the hcca being around 150 and saying most spl subs are higher than that. now how does the top plate effect this? do you want a tall top plate or thin one. i also plan on having sundowz rebuild them when i destroy them unless i feel its better to just start fresh with his subs.
very dissapionting im an a s s man and neither hers or the subs are visible
Team MN Loudest, the JEEP IS BACK, 2 18 btls walled!!!
dbjunior replied to antonmiller's topic in General Fi
just get ia baskets and cones and use the btl coil and motor 21in btl ta da -
hdc3 btl death penalty Lv5 mayhem havoc DD friend gettn in the game wa
dbjunior replied to kryptonitewhite's topic in Subwoofers / Speakers
no need for a loaded btl if you plan on getting a hifonics amp. look into getting a rd 3250v1 same board as the saz3k they go used for around 450 used much better option -
SPL Head Unit
dbjunior replied to 1200 bandit's topic in Amplifiers / Head Units / Processors / Electrical
OMG, IM SORRY I THINK THE UNIT SUCKS o.k. On this unit you can't turn off the bass center frequency you must use it ( 60hz to 180hz) no flat. The bass focus delay affects the subwooter timing.Pause button takes 10 seconds maybe more before music play back. You never just get answer here. Are you talking about the low pass filter??. I think you're confusing that with something else. And a more detailed question would work, because I don't think I've heard of an SPL Deck...Like others said maybe you want something that doesn't skip, or that can pause. its a boost of the the bass frequencys like how some amps have a variable bassboost and not one set at 45hz. it may effect the sub but should be limited to the speaker outputs -
SPL Head Unit
it may be frustrating sometimes but the more detailed you are about something can help others help you better and faster so you get exactly what you wan and not another hu you dont like -
changing box : how does the sub "feel" it?
dbjunior replied to Notorious97200's topic in SPL & SQ / Fabrication
the biggest thing is you are used to hearing songs one way that get crazy loud due to the box tuning you had now as you start going thru your music again you will find songs that didnt slam before now hit crazy loud also depending on the way the box is setup it may have moved as you where driving. i get a noticeable decrease in output if my box slides forward an inch 3-4db decrease. your box may have slide into a better alignment. -
SPL Head Unit
it is possible to run in the lanes without pause but its not easy im using a factory hu and it has no pause but i get it done. panasonics that i have used have done very well at not skipping the best is if you have an ipod dock it will never skip. -
i understand you wanted to find him the right sub but there is so much more to it than the sub. how was the old system setup size of box tuning size subs box orientation and what about it did not make you happy
considering it has 75 amps of fusing i dont think it does rated at max draw if it were 100% efficient you would get 1080w so id figure 800w probably. for a true 2k it should have 4 40's not 3 25's that or be externally fused
My box is only slightly bigger ( by .3 cu. ft.) than what my driver likes and it only needs a 1000 watts to power it. I don't have many problems with the saz 1000d. I have my ssf set somewhere around tuning which is 32 hz so im not in any risk of damaging it unless i turn up the gain but i can hear when its screaming from pain. I only asked my question about unloading because i was interested in WHY subs unload under tuning frequencies, i know that it happens, its just a rule of vented enclosures. even the .3 cu might reduce the mechanical power handling to 800w and im sure the amp you have is capable of pushing 1200+ so its possible you are over powering it that or there may be a problem with the spiders being worn.
if you are having this problem at or over tuning you are not unloading you are simply bottoming out the driver not good this means you have to much power going to the driver or to large a box. decrease one or both and the problem will go away. if you want to run the same amp you have now build a smaller box
Very specific sub request... LOUD SQ WALL <$900 (shipped)?
dbjunior replied to Boomboxx's topic in Subwoofers / Speakers
your not looking for sq at all. what you want is a sub or subs that dominates the lows . first what do you plan on using for music to demo. -
personaly i dont like pioneer speakers. id look into a decent pair of cdt components and as far as subs go depends on your box if you want real sq seal the trunk and get an ib sub but you should be fine with a sealed box a 15 will work as long as it is blended properly if you want to go ported for addional bass extension a single 12 will be more than enough
Have A Problem!
dbjunior replied to supaduppaman's topic in Amplifiers / Head Units / Processors / Electrical
if you smelt something and now its not as loud you may have blown a coil and be using less power and running on half a sub. id pull sub and check impedence. -
3 wires for the big three alt to batt batt to frame frame to engine. you will need to measure these wires every vehicle is different. then a power wire from batt to batt a ground wire from batt to ground and power and ground wire from batt to amp. all this in 1/0 and the alpine in 4ga from rear batt to amp and you need to fuse the wire from batt to batt on both ends .
how much voltage drop is too much?
dbjunior replied to ppiflat10s's topic in Amplifiers / Head Units / Processors / Electrical
just curious as to where you measured voltage. you said you dont get dimming so it made me think you tested voltage at amp. if you tested at amp retest and then check at batt under hood if there is more than half a volt diffrence between the batt voltage and the voltage at the amp then you need to run bigger power wire or check your connections. -
anyone have an older crome version that is rated to do 1200wrms @ 1ohm. how was it could it handle .5ohm burps? underratted or overrated
Boss audio blx 3500m amp any good?
dbjunior replied to playmysong's topic in Amplifiers / Head Units / Processors / Electrical
ive run a g512 before and had the same issue notice it more on low volumes i think it is a resonance issue with the sub. the best box i had mine in was large and tune to 18hz. the sub can get loud though 2.5cu tuned to 38hz off 300w got me a 140 -
the guy got himself fired if he conducted himself in a more mature fashion after being spoken to he would still have a job.
Which amp do u like better?
dbjunior replied to bigrank916's topic in Amplifiers / Head Units / Processors / Electrical
send jacob an email or call and and have him change it for you remember great customer service -
i was searching ebay looking at what was out there and came across these link lanzar is not a company i would normally even look at but these look like a solid daily pounder for cheap anyone have any exsperience with them
