lamchop_8
Members-
316 -
Content Type
Profiles
Forums
Gallery
Everything posted by lamchop_8
AQ3500D Or Stetsom V 4K2D
lamchop_8 replied to lamchop_8's topic in Amplifiers / Head Units / Processors / Electrical
Ok so if I get the 250amp ho alternator and 2 hc2400's will that be enough power the get the max rms wattage out the amp & enough power for me to play it all day everyday? -
Now the stetsom 4k2d pulls 240amps so is a 250amp ho alternator and a kinetik hc2400 enough power for me to get the max rms wattage out the amp? -
Yeah I just hope they hold up well since their so called the best amp since they hold the world record with 181.6db with alan dante. And their so cheap!! -
You think they put out their rated power? -
Thanks! & what do you think about their amps? -
Yep. Why? -
Okay thanks & like I was saying the stetsom 4k2d amp is not 1ohm stable it puts out max power @ 2ohms (like kicker amps) and only one sub will be hooked up to this amp so you said get a dual 1ohm sub instead of a dual 2ohm sub? -
Well the nonimal independence on the hdc3 sub is 1.8-1.9ohms So what if I wire it paralell making it 1.3-1.4ohms and then it will go up after independence rise making it close to 2ohms wont it? -
good point! but he can learn! and on here he can learn from some of the best!!! and brightest! Yep! =) -
Ok thanks & I will be getting a dual 2ohm sub if I go with stetsom because the lowest independence is 2ohms but one thing I dont like about stetsom is that they dont have a subsonic filter. =( ? with a duel 2ohm sub the only ohm load you can get is 1ohm or 4ohm. so you want to run the stetsom under its rated power.. lol okay i also heard a rumour about those stetsom amps that they are for spl and burping and aren't the best at daily? i don't know and i can't vouche for that rumour but i thought i would let you know and hopefully someone can chime in and explain or deface that rumour. Yeah its a rumor I personally talked to stetsom and they said the amps can be used for daily. And I was going to wire the subs in series wire to sub & wire to the amp no paralel wiring so wont that be a 2ohm load? -
I would go Sundown SAZ-3500D, FTW! How much is it? -
Ok thanks & I will be getting a dual 2ohm sub if I go with stetsom because the lowest independence is 2ohms but one thing I dont like about stetsom is that they dont have a subsonic filter. =( -
Are stepsom amps really the best amps? if not, are they really good and do they really put out the power they say for example, does the V 14K2D really put out 14000wrms @ 12 volts or not? Last thing, how much are these amps from the V 9K2D too the V 142KD? Heres a link just incase: http://www.stetsom.com.br/eng/Produtos.aspx (Go to amps and click on "DIGITAL")
On 4000-5000wrms all day everyday what sub is best and loudest between a fully loaded BTL, a DC LVL. 5, or a DD 9500
I plan on gettin either a Stetsom 11K2D or a Stetsom 14K2D. I was going to buy about four or five kinetik 2400's but I seen this battery. Is this ONE battery "Strong Enough" to power a Stetsom 11K2D or 14K2D all day everyday? Battery http://www.batcap.net/Products/BatCapProdu...91/Default.aspx
Are stepsom amps really the best amps? if not, are they really good and do they really put out the power they say for example, does the V 14K2D really put out 14000wrms @ 12 volts or not? Last thing, how much are these amps from the V 9K2D too the V 14kKD Just incase heres the website link to the amps. Go too "Digital" amps (Look @ V 6K2D-V 14K2D) http://www.stetsom.com.br/eng/Produtos.aspx
What is better, louder for my subs ,more efficent, and just better in any other way between 2 Sundown 3500d's or 1 MA Audio HK10KA? http://www.sonicelectronix.com/item_11682_...dio+HK10KA.html
Which Component speakers are better? Kicker http://www.sonicelectronix.com/item_3573_Kicker+KS65.2.html Rockford Fosgate http://www.sonicelectronix.com/item_3144_R...ower+T162S.html
My Sig.
That would be too loud!!! That would drown out all the bass.
The reason why I'm set on kicker and fosgate is because sundown re audio,rd audio, and other places charge too much for components. So I picked kicker and fosgate because their mainly the two best mainstream manufactures am I right?
They will be powered by this amp I'm buying three sets (six speakers,six tweeters) http://www.sonicelectronix.com/item_6519_H...s+ZXi+6406.html Yes enclosed there will be three mids in each door, and three highs in each a-pillar When I say "Loudest" I mean out of those two I listed between the kicker and the fosgate which components will be louder. When I say clearest I mean sounding the best "Clarity"
This topic is different than the last one duhh. No put downs either.
For my setup (In My Sig.) which mids and highs are the best, crisp, and loudest between these three? MIDS Rockford Fosgate http://www.sonicelectronix.com/item_2481_R...nch+P1692S.html Kicker http://www.sonicelectronix.com/item_11504_Kicker+KS6930.html JL Audio http://www.sonicelectronix.com/item_1603_J...+TR690-TXi.html HIGHS (TWEETERS) Kicker http://www.sonicelectronix.com/item_11520_Kicker+08KS20.html Rockford Fosgate http://www.sonicelectronix.com/item_18209_...gate+P1T-S.html
Which is better? RD Audio Heavyweight 18 INCH http://www.rdaudio.net/heavyweight/heavyweight.htm FI.BTL FULLY LOADED 18 INCH https://ssl.perfora.net/www.ficaraudio.com/...view.shopscript
