streetbeater07
Members-
348 -
Everything posted by streetbeater07
AA Havoc VS DC lvl 4 or lvl 4 xl
streetbeater07 replied to streetbeater07's topic in Subwoofers / Speakers
yes i want loud, but i also want to be able to play low. I want the best of both worlds. -
I want ground pounding lows and still have musicality. I want a good all around daily system that will turn heads. -
im running dual 2 ohm and they will be wired to series parallel -
bump.. -
Need new sub suggestions please
The box tuning is fine. I like the way it sounds, just need woofers designed for a daily beater that will take 1000+ rms. I was IA Lethal Injections. -
Which one would have the most output for daily in a 3 12, common chamber slot port tuned to 32 hz? Im mainly looking for something that will get loud and low and still sound moderately decent. My amplifier is a saz-3000d so im looking for 3 12's in the 1000 + watts range. Anyone have experience with the two? Any help will be greatly appreciated.
box is 6 cuft. internal after all displacements tuned to 32hz. I want a loud daily beater that gets low. Running 3 deep cell batts in the trunk and soon to be mechman or dc power alt. I havent decided on the alt yet, i've been checking around and getting mixed reviews on which is better. -
anybody? -
does anyone know who the rep for Alabama is? Can someone point me in the right direction so i can inquire about 3 Havoc 12's D2 ohm. thanks
Will the md3d do rated power or a little more? who's clamped one to see what it actually puts out?
which of these is better:
Im getting ready to order three fi ssd with bp option, but i want to make sure i get the right ones for my application. I will be running 3 of the 12 inch ssd's off of 2500 watts at 1 ohm. my question is, do i need dual 1 ohm or dual 2 ohm subs? What is the actual coil impedance? Are they dead on 1 or 2 ohm, or are the impedances actually lower or higher?? I want to do 3 dual 1's ran in series and then paralleled all together at .67 ohm, but if the actual driver impedance is lower than 1 ohm per coil, the total impedance may be a lot lower and i don't want to risk burning up my amp. Now, on the other hand, if i go with dual 2's and wire them in series then paralleled all together, i would be looking at around 1.3 ohms. I want to get as close to 1 ohm as possible so if i go with d2's and they are actually higher than 2 ohms each coil, my final impedance will come out closer to 2 ohms.. So basically what i need to know is do the coil configurations normally run higher or lower impedances from the factory? i prefer someone from FI answer this question. i emailed nick yesterday but haven"t gotten any response yet...
help with deciding on dual 1's or dual 2's
streetbeater07 replied to streetbeater07's topic in General Fi
ok thanks for clearing that up. one more question for you, if i go with the ssd's do i need to get the bp power options and flatwind coils? what do these actually mean? It will only be a daily driver setup with 2500 watts. I wanted to get the bp power option because of the extra cooling it adds but dont really know if i should get the flatwind coil?? I hate to spend the extra money on options if i really dont need them> thanks guys for your help -
Thanks guys i really appreciate your help..thats exactly what i wanted to know. You saved me some time and money... -
hello Jacob, I my nightshades blew on me. I was pushing them with an IA 40.1 @ 1 ohm no bass boost and gain set properly, however, I don't want to change my amp so I want to upgrade these to handle the power. I need to know how much it will be to have these two reconed with more spiders and longer coils. They are dual 1 ohm 15's. Please let me know because I want to get this done asap have the money on hand and getting ready for a local comp. Thanks.
pm'ed back
they can handle it, maybe not for sustained periods of time, or maybe not in stock form.
I want longer coils, 5 spiders and cooling options on the new recones. thankx
im ready to ship. I emailed you also.
I play them based on said ability. I buy subs according to the amount of power they take but maybe the 40.1 is too much.
haha, no, lol...
ok...what should i do with 3.5 cubes net
streetbeater07 replied to manbeer's topic in Subwoofers / Speakers
1 15" q, port back sub back. -
get some weight gainer, creatine, multi-vitamin and go heavy!
now only if had a 3000d... get one.. definately worth it got a 40.1, now I want a matching setup..
