streetbeater07
Members-
348 -
Content Type
Profiles
Forums
Gallery
Everything posted by streetbeater07
MMATS DHCx 2200.1 Amp malfunctioning please help!
streetbeater07 replied to streetbeater07's topic in Amplifiers / Head Units / Processors / Electrical
They are single 8 ohm woofers x 4 all paralleled then ran to the amp. Unless one of the speakers is shorting internally? possibly? I think they are rated @ 150 rms each 300 max and the amp puts out 1400 @ 13.8 volts @ 2 ohm. I hope its not a problem with my amp. -
hello, I was trying to see where I could purchase 1 inch mdf fiberboard and how much per sheet? thankds
how long is the current wait time on the q 15's? I ordered two last wed. and I checked the ups website and still no shipment. just wandering how much longer it will be. thanks
ok so how do you determine when to start the kerfs so that it falls in line where a normal square port would be? I know that ill have to start bending a couple inches before so that it flows into the port, just don't know how to figure out exactly how many inches though....
hey thanks man you're very helpful.
bump...... seen a lot of these designs, know someone knows. or is it a secret?
enclosure recommendations for 2 fi q 15s
streetbeater07 replied to streetbeater07's topic in Fi Technical
Ok I'll def. try my box first and if it doesn't work I'll already know what to go with. thanks -
hello guys I have two Q15's in a dual chambered slot port box tuned to 27hz @ 8cuft. My question is will it be better to build another enclosure where the drivers share the same chamber? And should I double baffle it? Also, what about bracing? How do I go about doing it? I tuned low because I want the ground pounding bass that you get from the lows as I don't really play anything above 45hz. Thanks.
so common chamber double baffled would be better for my application? Thanks Nick for your speedy response! Can't wait to get the subs. Spoke with Scott the other day about the delivery time and he was a great guy also and very helpful. FI all the way!!!!!! When are you guys going to produce a component set? -
bump?!?!...... -
I have the same kind of car that you have 2007 mercury grand marquis. Im just wanting to know what the better design will be and witch one will give me the best sound same tuning same cuft. I found ssa through roe. Subs haven't made it yet but there already purchased and being built should be another week before they arrive. thanks -
Just Orderd an fi Q 15, anyone know how long it will take to recieve it? I have already recieved my tracking number from Fi but there is no tracking info yet only says that the billing info has been recieved? So when should I be expecting my sub? thanks
Hey has anyone purchased a merlin md3d from Ikesound? Are they a reputable dealer? I was browsing and found that they have the new model md3d for $500.00.
anyone know how I can contact flak about one of the new merlins?
