Duran
SSA Regular
    11,435
  • Days Won
    28
Everything posted by Duran
  1. Duran
    Welcome to the IHoP
    That Greek chick is HAWT!
  2. Duran
    AQ20
    It's a fine line, I have hands on experience with the SounDigital 16KD, it has two pairs of 1/0 inputs, and I've clamped it doing more than rated.
  3. Duran
    AQ20
    That amp only does 20K at 18 volts, half that at 12 volts
  4. It takes power to make power.
  5. Duran
    Extremely Disappointed
    Nick, make me a woofa that I can plug into my 480 volt, 30 amp wall sockets. Please and thank you!
  6. Duran
    Welcome to the IHoP
    "If wanted to have sex with women who looked like 12 year old boys, I'd just have sex with 12 year old boys" I believe is the phrase? I believe my statement has been "Peng-ified"
  7. Duran
    Welcome to the IHoP
    Dude, she is fat... How is she fat? She has an hourglass waist, along with big boobies(probably fake) and some meat on her bones, I'm sorry but I don't fuck anorexic women, I'd end up breaking them in half.
  8. Common sense is truly a waste of time it seems.
  9. Duran
    LETS GO PACKERS!!!!!!!! BLACK AND BLUE
    I should delete this thread and ban you for making it...
  10. Duran
    Welcome to the IHoP
    You guys must be gay
  11. Duran
    Enclosure for Q
    High QTS is not mandatory for sealed, just recommended The Q is great for sealed or ported, if you wish to be able to switch enclosure styles, don't get High QTS
  12. Duran
    sa-8 or sa-15
    You guys are getting mixed up with terms, they will play the SAME frequencies, the only difference is the volume at which those frequencies are reproduced, that does not mean one size has "better low-end extension" than the other.
  13. Duran
    what does it take to get 150dB @ 25Hz?
    You do know you're ears have a freqeuncy response? >< And you're ear's roll off at a quite low freqeuncy, about 29-30 or higher or lower, depends on the person. So still if 25hz was louder, it could sound quietter then 6db's less on 50 hz. And most movies i watch, frequencies go below 20hz.(helicopter flying by...explosions...) You don't hear it because u don't have enough pressure at low freqs, or you're ears are not so good. You're ears roll off around 2 KHz. actually.
  14. Duran
    Sounds like full DC rail, bummer
  15. Duran
    Inside FI Facility
    I believe it's just like ferrite, and must be machined then charged.
  16. Duran
    Fi's Manufacturing line pictures?
    I HATE car audio. Can haz job?
  17. Duran
    Order #1415
    The woofer will ship from Jacob, Jacob is currently moving his warehouse and made a thread about being a little behind.
  18. Duran
    N3?
    For pure SPL purposes, like with the Gen1 & 2's, you recommend no cooling to save motor strength?
  19. Duran
    Welcome to the IHoP
    *jizz*
  20. Duran
    Welcome to the IHoP
    Are you pregnant?
  21. Duran
    Fi Audio Subwoofer Comparisons
    Slightly off topic but why would fosgate manufacturers build their amps with a predetermined subsonic filter? Back on topic- I would suggest two 12 inch SSDs for your particular case. They will sound great and get loud for under $400 which is what you want according to your first post. With the stock 160 amp alt and the big 3 you could quite possibly be alright as far as electrical. If not you could always add another battery or two for a couple hundred buckss. The SSDs would also be favorable if you have to purchase a new amplifier a nice 1500w amp could be sufficiently cheaper than a 2000w amp. That's a better question for Rockford Fosgate, the amps are set at 25 Hz.
  22. Duran
    Welcome to the IHoP
    Water, or semen?
  23. Duran
    25 Hz. won't happen in a REX, they need 70's
