Duran
SSA Regular
    11,435
  • Days Won
    28
Everything posted by Duran
  1. Duran
    Welcome to the IHoP
    I understand, I know people swear by Sundown and some swear by PAP, I want an unbiased opinion.
  2. Duran
    The "X"con 12" prototype has arrived
    Mark and Aaron, what do you guys think about 2 12's on an SAZ 3000D? Price?
  3. Duran
    Welcome to the IHoP
    And thaaaaaat is a top ladies!
  4. Duran
    Welcome to the IHoP
    Give me a reason! I don't care what you personally think is better, I want proof!
  5. Duran
    Welcome to the IHoP
    Refurb 12" Sundown Nightshades or 12" PAP WMD2's?
  6. Must you ask the same question over and over? It is a bit repetitive.
  7. Duran
    18" BTL's
    ^^^ For burps only I could see that, good luck in a daily though.
  8. Duran
    Picking amps
    I second the Sundown, it doesn't get better than an under rated, overbuilt amp with a warranty and excellent customer service vs. the horror storied Ive heard about AudioQue amps.
  9. Duran
    steve meades speaker wire
    I can't help it, I just got home from hanging out with the girlfriend...Good times... did she spit on it? or did u do all the spiting... There was saliva on it from earlier!
  10. Duran
  11. Duran
    If you are trying to fit all your wire into the terminal and it just isn't fitting, spit on it and force it in. Or try lube.
  12. Duran
    Welcome to the IHoP
    Vagina: Mans best friend...
  13. Duran
    There are very few things in car audio that aren't ridiculous. We are good at fitting very large things into very small holes!
  14. Duran
    whos got the best GF on the planet???
    You should adopt me Jon, you know you wanna!
  15. Duran
    HELP ME PICK A SUBWOOFER !!! ASAP
    yeah you read it will make the motor weaker......BUT YOU WILL NEVER EVER know that its weaker on a daily set up EVER Yeah Jon, he worded that terribly. He should have said, if you are running ~1500 watts don't get cooling to save motor strength, get only the pole chamfer. Cooling is a pole chamfer and axial cooling drilled into the motor, you don't loose that much metal. I say get cooling since you will not need all the motor strength you can get out of it.
  16. Duran
    How it's for a ported box?
    What year Stratus?
  17. Duran
    You heard right, most of the time the Q will play the lows a little better, and the BL will (normally) have more output.
  18. Duran
    Kicker L7
    The new L7's are designed to run as cool as possible, they ditched pole venting and use pole chamfers and axial cooling now, along with an insane amount of metal to absorb heat from the coil they run extremely cool now.
  19. Duran
    Welcome to the IHoP
    Good night HOPers, school in the mornin'.
  20. Duran
    >30mm Xmax <20Hz Fs D2 15's
    Who do you need so much xmax? Lots of stuff can do that too...
  21. Duran
    Need Opinions...
    It it were a W6 I would go for it, but W7's are very over rated.
  22. Duran
    Welcome to the IHoP
    Do it yourself. http://www.jamglue.com/
  23. http://www.discogs.com/release/1090567 Frankie Rio demos "The Boogie man" and I want the album.
  24. Duran
    Question about FIQ 12
    That will depend on your amp settings.
