Duran
SSA Regular
    11,435
  • Days Won
    28
Everything posted by Duran
  1. Duran
    power handling from magnet
    Stock, it's closer to 1,000 watts than 1,500 regardless of impedance. Power handling goes up a lot when you get cooling and the flatwound coil, I recommend them, if money is the issue it's worth it to save for the upgrades.
  2. Duran
    Port area confusion.
    For an N2 18" I would opt for as close to 110^2" as possible, you can use less if you use flared ports, a minimum of 90 or so square inches.
  3. Is the problem perhaps the logo on the case?
  4. Duran
    Julian's 2011 Mustang
    Fucking DD
  5. Duran
    6.5" sub for midbass?
    There are a lot of resources on here to assist you.
  6. Duran
    1000th Poast :P
    You are almost halfway there
  7. Wow, 29 mm of one way throw from a 10" driver. What is Xmech?
  8. Duran
    I'd say it depends on the displacement capabilities of the driver in question, a 10" PA woofer will require less vent area than a high excursion 10" driver
  9. Duran
    warden's on sale too?
    Warden's aren't included.
  10. Duran
    A BL coil will fit just fine, but you want a Q coil. The BL coil is very short in relation to the Q. The motor and coil of the Q are optimized for each other, changing to BL coils won't make it anywhere close to a BL.
  11. Duran
    Welcome to the IHoP
    i Sean will like that idea Actually I'd rather see a ridiculously lightweight something with shitloads of power. A high revving lightweight 6/8 is more than fine with tha BOOST. Hennessey Venom GT? 2,685 curb weight, 1,200 bhp note though that I don't endorse anything that buttmuch sells... Ariel Atom?
  12. Duran
    BTL questions
    Nick explained why I asked you why you think it needs a better suspension, sure you could have one, but it isn't needed.
  13. Duran
    BTL questions
    ahhhh i see makes sense.. BTL should actually come with 6 total thou since the BL's come with 5 stock now.. Why?
  14. Duran
    The foam surrounding on my dcon ripped
    You pushed it beyond it's limits, no repair, or brand new recone can stand up to that kind of abuse.
  15. Duran
    BTL questions
    Ahh, yes much easier for sewing leads I'm sure.
  16. Duran
    Sub wiring ohm outcome...
    The word you are looking for is "impedance".
  17. Duran
    BTL questions
    Thy use the yellow?
  18. Duran
    Car Audio Magazines
    Voicecoil
  19. Duran
    Welcome to the IHoP
    Yes he will No such thing as sub stage since the sub is PART of the front stage L=R = crappy "stage"
  20. Duran
    Welcome to the IHoP
    Ding ding ding. Otherwise I would use y-splitters. I'm willing to bet its a full range signal.
  21. Duran
    Welcome to the IHoP
    Multiple Y-splitters lol
  22. Duran
    Welcome to the IHoP
    Y-Splitters, he won't have a stage but I doubt he cares.
  23. Duran
    Welcome to the IHoP
    Galaxy Tab is the only one worth a damn
  24. Duran
    Is bigger better?
    Given the displacement capabilities of the SX, I recommend a total of 115 square inches of port area minimum, if you want to tune at 34 Hz. Notice, internal area isn't mentioned, because it isn't needed when figuring port area, it is only needed when determining efficiency, maximum power, and tuning of the enclosure.
