11,435 -
Days Won
28
Content Type
Profiles
Forums
Gallery
Everything posted by Duran
The blue thing isn't mandatory till October though, I'm not sure if I'll still be with the company.
Hell yeah! Gonna get me a weed whacker and some clothes. It's really tough to beat $5 for dress shirts. I should get some dress shirts...since I'm the "Blue Crew" now.
questions about batteries and wiring
Duran replied to doug118's topic in Amplifiers / Head Units / Processors / Electrical
Yes those will work, don't order fuses till you figure out which alternator you'll be using. -
ANL fuse holders. -
Using WinISD, what are the differences between the alignments?
Duran replied to imhungnurnot's topic in SPL & SQ / Fabrication
http://lmgtfy.com/?q=QB3+Quasi-butterworth http://lmgtfy.com/?q=BB4%2FSBB4+(Super-)boom+box http://lmgtfy.com/?q=C4%2FSC4+(Sub-)Chebyshev http://lmgtfy.com/?q=EBS3+extended+bass+shelf+-3+dB http://lmgtfy.com/?q=EBS3+extended+bass+shelf+-6+dB -
Replied. -
Friends and Family night is tomorrow...homemade root beer, grilled hot dogs, and a great day for sales await
That is all the enclosure, the enclosure determines 90% of the sound you hear.
There are 12's that would love that airspace, mine are in 4 cubes a piece. I only have one 12 in at the moment, and people guess I have two 15's. -
You could get more from your car with 2 12's, I went that route. I have two 70 lb. batteries in my spare tire well. Powering my SAZ-3000D You don't need 2 runs, just one. You should make it as large as possible...4/0. The welding wire is the same as the "car audio" wire. I have welding wire myself. -
Same with me, but my power isn't out...surprisingly!
I would recommend 2 d3100's, that should be enough. As for the alternators, find out at what RPM's do they do rated power. And with the wire, run something between 2 aught and 4 aught wire, fuse with a 300 amp fuse at the front battery, and one more at your first battery in the rear, then just a jumper from battery 1 to battery 2, and ground your batteries both to the frame as you will with your front battery in the big 3. -
In a Competiton woofer: 10 gauge In a Super Tweeter: 14-16 In a Mid-bass speaker:14-16 In an SQ woofer:12 Power cable for a Competiton amp:0000 Mosfet in a competition amp: Not sure Ipod headphone voice coil: umm maybe 40 qauge? lol HU Power cables:12
I chose the 89 because it's built like a tank, little to no body flex. I chose blades(which I'm assuming are just normal rims) because I think spokes are for bicycles. Jon's Lincoln being the ONLY exception.
You just have me an idea....
2008, and 2009 models. The cone is a bit better on the 09, much less cone flex. No real difference motor wise, just more cooling in the new one.
^^ By that I meant check the voltage.
All I saw were boobies! I wasn't looking for a dog though
New Mach 5 Build - Zero Power Compression
Duran replied to mrogowski's topic in Subwoofers / Speakers
That's a large coil...guesstemate thermal handling? -
alternator whine plus turn off pop noise
Duran replied to SouthPole1989's topic in Amplifiers / Head Units / Processors / Electrical
You only have to ground the RCA's on Pioneer head units when you blow the pico fuse. Even then that can be prevented, and you could to a better job grounding them...^^that's awful. -
8's aren't "faster" than larger diameter subwoofers.
Check your RCA's before and after it cuts out.
Now you get to pay for their mistake.
