11,435 -
Days Won
28
Content Type
Profiles
Forums
Gallery
Everything posted by Duran
Yeah your right, damn he feel too nasty . Thats when you should just hang on the rim and catch a technical foul, never let go of a rim if your body is going in a swinging motion with a lot of forward momentum. You should add, "and if your too moronic to land on your feet"
best way to clean a basket for a recone
Duran replied to billystorms24's topic in Subwoofers / Speakers
As said above, a wire brush is the best for removing CA as well as preparing the surface for more glue. -
low notes send amp into protect
Duran replied to aimone's topic in Amplifiers / Head Units / Processors / Electrical
If you want a good balance of what you think is low and high bass, tune to 34-35 Hz. -
Got my 12" BTL and My BOlts and Tee nuts, But the Bolts dont fit..
Duran replied to antonmiller's topic in Fi Products
A bolt and T-nut is much stronger than just a screw in MDF. If you want something hard to steal her allen head bolts or even better, torx head bolts. -
I'd skullfuck you if I could. OP: You need a minimum of 100,000 watts to even get the BTL to move! Seriously though? Do some research on drivers and their behavior at all levels of power input. There is NO minimum amount of power needed for ANY driver.
The XXX is an AMAZING woofer, it's sad someone like that didn't give it then installation it deserves.
My subs are eleventybillion watts peak power, so?
Any amplifier you can find will work perfectly at driving those woofers.
the q is not an """SQL""" subwoofer, it is a sq subwoofer. it was not at all intended to get loud. to the o.p. get the bl, tune low and build a good box inside fi's recommendations shut up idiot. it aint a true sq sub you dumbass...... when have you ever heard of a true sq woofer with an rms rating of 1000. get real. dont correct me. Please stop spewing verbal diarrhea.
FFFFFFFFFFFFFFFUUUUUUUUUUUUUUUUUUUUUUUU!!!!!!!!!!!!!!!!!!!!!!!!!1
Back from vacation
Making a moofer of course
The magnet is 11.25" so it will fit just fine.
A lot of people here would love to double check the numbers for you, I'll be out of town for a while so I cannot.
The bracing will change tuning because it occupies airspace. It can be done a lot of ways, wooden dowels, window bracing, and threaded rods are the most common. Check your enclosure with this calculator, as it used the correct formulas and is right if the vent has a bend in it, the RE Calculator does not calculate port bends correctly.
Enclosure Build for deejayarecue (Two 10 Inch RE SE's)
Duran replied to Argent Audio's topic in Argent Audio
Too bad Andrew won;t be doing any new enclosures in the next few months Good look with your new driver Andrew! I wanna see it! Very nice looking enclosure too! -
I'm in $51.50 then! I just found change in my couch
X3 for welding connectors. As well as welding cable over "car audio wire"
It's not on the market There are vent holes running vertically on the top plate as well.
