Corey54
New Members
    15
Everything posted by Corey54
  1. Corey54
    Your order # and when shipped
    My sub shipped out today! Should have it by next Wednesday
  2. Corey54
    Sounds like its gonna be a while before my sub is built. I'm on day 14 already
  3. Corey54
    I ordered mine the same day as you. Will you comment on this when your sub ships out?
  4. Corey54
    what the fuck today is day 15 for me and it still says awaiting fulfillmentI'm on day 12 and its still awaiting fulfillment too. How is this guys done before ours?
  5. Corey54
    Order #2589
    When should I expect my order to arrive? Order number #2589 1 15" SSD. The order was place August 12th
  6. Corey54
    Order #2589
    Does it take longer if you put a few options on it? Like cooling and hight qts.
  7. Corey54
    Order #2589
    Yes I did read it. I also heard that Fi was taking longer to build there subs then it says so I was wondering if they solved that problem yet or not.
  8. Looking for advice tuning my new deck. I have a Pioneer DEH 80prs, a Soundqubed 1200d running at 1 ohm with 2 12" alpine type x subs. I have my low pass filter set at 80hz on my deck but I don't know where to set my low pass filter at on my amp? I was told to just turn it up out of the frequency range of my subs but idk if that's right. Bass boost is at 0 and the subsonic filter at 10hz. Gain is at nominal power. I have my subwoofer level on my deck set to 0db. The crossover slope it at 18db. Automatic sound levelizer at high and source level adjuster at 0. Graphic equilizer is flat.
  9. Should I adjust my graphic eq at all?
  10. Turn it all the way down. I don't know exactly how but the sealed boxes don't need a subsonic filter. I'm sure someone else will explain why.Ok thanks
  11. I have a sealed box so where should I set the subsonic at?
  12. I'm looking for a new battery to replace my stock battery. I have 0 gauge wire for my power and ground. I'm running a soundqubed 1200d amplifier with a 15" Fi SSD in a 2.5cuft sealed enclosure. I've been looking at the Kinetik KHC2400
  13. Hmm.. Il have to look them up. Have you used any of the Kinetik batteries? A buddy of mine has one so he recommended I buy one but I wanna know what my best options are.
  14. I have an '04 Cavalier. I'm not sure if I need one but I was told that my stock battery won't give my amp enough power and that I should buy a battery that will put out around 2400 watts. I heard that the lights and everything else that is electrical draws around 1000 watts.
  15. Corey54
    Did your order ship out yet? I placed an order on the 12th so I was wondering how long it's gonna be before mine ships out.
