bigbruno
Members-
126 -
Content Type
Profiles
Forums
Gallery
Everything posted by bigbruno
Are you going to Houston tomorrow with it?
It was the same here in the College Station/Bryan area. It snowed for a little over 4 hours, and got pretty heavy for about half of that. It was pretty neat to see that happen this far south in Texas. Everybody here at work was outside having snow ball fights, and building snow men witht the customers coming in. It never does that here, and I hoping it'll do it again this year, but more of it next time.
Been busy with work, because of being short handed all week. That and I quit checking as much after all of the IPS errors earlier in the week.
I think with those dimensions, it would be a really tight fit for a 12. Why not step down to 2 10" bl's, or even 3 of them, and keep everything else the same. It be an easier fit.
Payment sent for 2 :bigclap:
Check with Ray from Team Man-up, he runs in that class and just did a write up the Sundown section on using the Maxx-Link. I think he said he uses a Batcap 8400, and seemed to be a pretty serious battery.
Yea, I have never tryed to take seats out with air bags in the shoulders... I would be so pissed if one of them blew haha... I will try this and pray several times during I don't knopw what kind of car you have too, but most vehicles you have to let sit after disconnecting the battery for 15 seconds to a couple of hours afterwards to let the battery backup in the air bag module discharge. If not, it can possible still discharge and set off the air bags. Think I should just disconnect it for a whole day? It is a 08 Mazda6 According to the service manual on yours, Wait one minute or more before doing anything to it after disconnecting the battery. Another thing to remember is htat on the newer one there are wieght sensors in the seats now. DO NOT REMOVE THE SEAT FROM THE RISER IF YOUR CAR HAS RISERS ON THE SEAT!! If you do, you will have to buy new sensors, which are usually around $50 to $100 each and take four of them on average. Plus then you'll have to take it to the dealer and have them re-calibrated which can take a couple of hours to do. The sensors, once un-torqued from their positions, are not re-useable. Just be caqreful with it. Other than that, have fun
That was a phone number from a song. :bigclap: I can't remember the song now though.
Wait a minute, you can't run 2-way active + sub with the H100 ? You can run 2-way active plus a sub, but not 3-way plus a sub.
2002 Caddy on bagz...8 Fi BTL 18's, 2 RF T15k amps (new vid pg 31)
bigbruno replied to meade916's topic in General Fi
Those are extremely bright for as small as they are. -
head unit suggestions
bigbruno replied to danieln_88's topic in Amplifiers / Head Units / Processors / Electrical
If you look around on E-bay, you can find the Pioneer AVH-P500DVD for a good price. I have been contemplating one of those for myself. -
Usually you don't use it in a ported box because it'll end up blowing it, or chunks of it out of the port. When it does, it can be dangerous. If I'm thinking of the same stuff, and with the way you used it, I think it'll be ok.
Request sent
To me that basket looks like the LMS Ultra too. That ought to be one mean woofer. If it can handle the abuse and power levels htat he subjects them too, then it will an awsome package.
4 havoc15's, AB500.1, D3100's, Fisher Custom's box
bigbruno replied to duece212's topic in Build Logs
I'm tuning on this one -
rockford amp
bigbruno replied to B7L|BL4Z3R's topic in Amplifiers / Head Units / Processors / Electrical
Did it go into protect right before/at the same time it blew the fuse? If it did, then it probably saw a major drop in voltage at about the same time it blew the fuse, causing it to go into protect. I would upgrade the wiring, and then try it again. That's probably all it was. -
What'll the pricing be like on them?
Have you tried e-mailing Nick at Fi, he might have something he could send you.
sorry just confused b/c I thought the Q's were 1000 watts rms each and the sundown is only 1500 watts rms or so and would be underpowering them. It also partly depends on how big or small of a box you are planning on using.
As far as I know of, they only come in D2 and D1 coils.
You could always get the amps from Db-r for cheaper, and they still come with a good warranty too.
Pretty impresive for a sub designed not to be an SPL monster. You sure that's the same jeep now too, it's alot neater than it was before Isn't this one supposed to be your SQ sub, or is it the in-between ?
What's the specs on your box?
Coming in with the 100.4D revision - current ETA is the 21st of next month. Could be a bit more or less, but that is the ETA. Oh, ok. THat gives me a little more time then.
