fritosaregood
Members-
636 -
Content Type
Profiles
Forums
Gallery
Everything posted by fritosaregood
I finished building up the daily port today. it took forever because the resin wouldnt dry. tomorrow or thursday ill get it wrapped in carpet..depends on if i find any money before payday. i added some fiberglass on the outside to round it out better. but that resin was takin forever so i decided to clean off my workspace and organize the scrap mdf and this is how i use most of the left over circle cutouts then i decided to touch the table saw blade when it was goin... pics arent too good i got a delivery today too some kicker 8 gauge. ring terminals and a 12pin wiring thing
i started on the daily port i made the flare radius 2" insted of 4" and it didnt bend well at all. im gonna sand down the unround parts, im also only doing 2 sided with flares instead of all 4. this way it might look more hidden, even thought its gonna come out on top of the back seat. more toys from ebay. 100, 80 grit sandin sleeves for a dremel. 7.99 plus shipping the port cant see the bad kerf though
I got a little more done I cut the whole for the sub, put it some t-nuts, and put in the threaded rod. now i just have to find my small bolts to make the terminals. I used some carriage bolt with the theaded rod mainly to keep the bottom of the box close to flat so it lays down better those expensive little things. almost $4 each i had to screw that nut over 3 feet. then i had to do it again for the other one.
I had a few finals today so i didnt get much done. I got the top baffle on. i just using a single baffle because ill have threaded rod for bracing. I also sealed the edged with more fiberglass and made more 45's from resin. I didnt get to many pics of it since fiberglassin gets pretty messy. I also got some toys today..sorta ^^ wat i get for bein on ebay at 3am I found some 3in air sander disk things 25 for $20 nice deal, some rubber grommets. 150 with different sized i think it was $7. and 2 fuse blocks.. i ran into a problem with my alt to batt wire got laid on my header and came about a millimeter from melting throught the wire loom and wire jacket. so now i wanna fuse both ends just to be safe. Ill get a pic of wat the wire looks like.
i might not do a vid of this port because its tuned at 49hz for comps. but after i get the box in the car i can measure for my daily port. after that ones built ill make some vids
more pics.
thanks all of yall. I wanted one big port and i wanted it flared. the biggest aero port was 6 inches. i saw how to make kerfs, tried it, and it was pretty easy. So i decided one a big square flared port. It came out better than i thought I have more done including an inside flared part, the pics will be up soon.
i got a little more done. I got the holes drilled to mount the port and the t-nuts put in. started on the inside kerfs
thanks everyone. i had to use a hand saw(whats that??) to finished the kerf cut cuz my tables saw wouldnt cut high enough i should have more done tonight, then more pics.
Good eye !! Yea, about half of it only has one layer, on the other half I put a layer of 1-1/2 oz mat on top of the 1st layer. I was very careful when I pulled it off so it wouldn't break or bend, so far it looks good. Thanks for the heads up on changing shape though, I didn't know that. Tomorrow I'll test fit it to see if it changed. If it does, I'll just have to make another one. it may not change until you start stretching the fabric over it. Oh, ok. In that case I should be ok, I'm going to build up at least 3 layers on the form before I start mounting rings and fabric. Thanks again. sounds good.
how many layers did you put on? it looks like only one. if its not enough it can change shape on you once you pull it off
1 saz 3000d or 2 saz 1500d or 2 t10001bd
fritosaregood replied to blkmrideon22s's topic in Sundown Audio
trade in program for the rf amp and jump on the saz3500 presale you have till may 1st till its over. edit: saw your sig -
i was about to take out my backseats for my next box, but decided against it Partsexpress. Its not a perfect match for the seats but for the vinyl on the door panes its dead on. http://www.parts-express.com/wizards/searc...FTOKEN=26967993 ive got the grey and some black also
Ill be working on puttin 2 15's in my trunk soon, and it may take me till the end of this summer to finish it. So for that time ill need the trunk empty to measure and test fit. so until that gets done I'm going to put 2 E8's in the center of my back seat IB. pics so far Thats all i can do for now. I'm waitin on some t-nuts to get here tomorrow
I think thats what i want to do now, get back to a stock look to my car. except for the trunk of course. redoin door panels is next up with more grill cloth to hide the speakers
Walmart FTW. quarterly bonuses to spend on subs!!
Finished up today. Its not as much bass as i would like, but after a week or so ill get use to it. Some grill cloth to hide it
Subtract 3 db from the 2.83 volt/m rating and it equals 1w/m. Im about 95% sure
I started running my Sundown 3000 at .5 ohms a little over a week ago, and I figured I'd share my experience with performance in regards to temp of the amp. Subs: 2 dual 2 ohm audiopulse axis wired down to .5 Electrical: 200 amp alt, one kinetik 1800 under the hood and one kinetik 1800 in the trunk. Sealed box, 2 cubes per sub, impedence rises over 1 ohm at 18 hz and doesnt drop below 1.1 ohms after that. Gains on the amp are set with 50volume on the deck as max Before started I took the temp of the amp it was 62 F I started playin music on volume 40 for 8 minutes, then I turned it up to 50 for 13 minutes. Total test time 21 mins. I measured the temp of the amp again: The side with the power wired was 78.4 F, the side with the rcas was 87.8 F The A/C wasnt on, outside temp was about 55 F, amp is mounted on a board with nothing above it. Songs played during the test were: Chain hang low Paper Planes Remix This is why Im hot Lollipop Remix Watch my shoes 3 Peat The subs cone temp were both around 76 F With this said, I feel comfortable running my Sundown 3000 and .5 ohms daily.
here it is. 200amp iraggi alt. kinetik 1800 up front and in back, 1 run 0 gauge. volume is 50 out of 62 in the test. the volume i set my gains at. if you look close one i get out of the car, im not reving it anymore and it drops below 14v
I doubt that, especially with YOUR electrical. I have one hell of an electrical and I'm in the low 13's high 12's on music. ill post a vid soon and its with a bass test then youll beleive me. What is your electrical
when im driving, it stays around 14.0~.5, for long bass notes it might drop to 13.5
I did it that way to show how hot it is to touch, because that is what most ppl use to compare temp for amps and subs.
