fritosaregood
Members-
636 -
Content Type
Profiles
Forums
Gallery
Everything posted by fritosaregood
might not be a must, but its worth getting. when i got my saz3000, i didnt put it in till i had my h/o alt in and 2 extra batts in the trunk but there is a guy who host some local comps around here with a rd audio3250( ive heard its the same board as the saz3000) and he has stock alt and batt, and it still does some nice demoing before we start comps
Battery Connection Question
fritosaregood replied to rk772's topic in Amplifiers / Head Units / Processors / Electrical
not sure on those batts. but my kinetik batts have the bolt on post, those allow you to just bolt on ring terminals instead of buyin endless battery teminals for as many batteries as you feel like having -
ive tested grounds when i installed my setup, and they all read the same voltage as the battery. i also removed all the ground that were just to sheet metal and made them to frame pieces
Ive got a sundown 3000 amp and a 300amp circuit breaker. ive been to a few comps and my circuit breaker has blown in some of my runs. Is it ok to run the system without the circuit breaker just for comps?
i really like the circuit breaker. saves money from replacing a fuse every time, and its quicker to reset. but ill try out a fuse once i put it all back in and run it full tilt and see if the fuse blows. if the fuse still blows ill have to add more juice i guess.
oh, i didnt know that.
ill have to look into the split frame i have a stinger one, but its not in the car yet. ive had that system out of the car for over a month now, but i dont remember havin my lights dim when runnin it at full tilt when driving, but usually after 5 or so minutes at full tilt on music while driving the circuit breaker will blow.
ill try turnin my gain up once i put that setup back in. my deck doenst go negative bass boost. just one the eq another thing. Im plannin one runnin two dual 2 ohm subs for comps soon. so ill have the amp on a .5 ohm load. ive heard it puts out 3700ish watts at .5, will this be a problem with the 300amp circuit breaker? i dont think you have enough back bone to run that amp at half ohm full tilt. how if your ground done on this car or suv im guessing. its a honda accord. the grounds in the trunks are to a frame piece. wat else would i need to run at .5 ohm? i assumed id be find since its a little power increase
its a dual 2 wired at 1, gain is maybe 1/3 or less, rca voltage from deck is 4 volts, my bass boost is at half, IMO... drop the bass boost to none.... raise the gain a little.. and wheres your subsonic set? on your head unit where is your bass set to? ive had the boost on none before and there is very little output. but maybe raising the gain would take care of that. my subsonic is set at roughly 20~25 right now. hu bass is 0
what does your electrical look like? if you dont have enough power behind that amp the breaker will trip. 200 amp alt, 0 gage everywhere it needs to be, 2 kinetic 1800s, and an autozone battery under the hood
you said 17 years old and you have a daughter.. and your throwin all this money into a car... that doenst seem good, but i know id be doin the same thing.
i think ac outlets are 60 hz
Glad you like it.
what turns you off from sundown?
no sir. i just did that box in a day, no resin nothin. so i wanted to make sure its sealed good. plus i only plan on keeping it for another week at the most. Update so far: Xenon 200.4 on the way Clarion Flipout on the way Batcap 2000 picked up this weekend. still lookin for a 3000 watt amp. the sundown 3000 are on sale for 750 right now
I've looked around for different test tones, i still dont know how to make my own, but i found a site that offers free test tones 10 seconds long. there is a place at the bottom to download a zipped version of all the songs. Stereo, 16 bit, 44,100 KHz 0 db http://www.ronelmm.com/tones/
Building Steam with a Grain of Rice by DJ Shadow
the port volume does not account into the .60ft^3 if thats what your mean by the question.
The name "Akoustic" coming from the word Acoustic which means a branch of physics that studies sound. Akoustic...type-o in the "who we are" page.
What Mp3 player do you have? suggestions....
fritosaregood replied to TOOLMAKER's topic in Computers / Electronics / Music / Games
i had a ipod mini. that just crapped out one day. so I got the older 30g zune when it came out, and its been great ever since. -
Do those grills screw into the same holes that the sub does? or do I have to make additional holes? Please help! I need 10" grills that use the same holes! Adrian those grilles use different holes. it shows in one of the pics on that partsexpress page
ive shown this to ppl that dont know to much about systems, and then they say they want a box with 2 10's and a 12 in the middle or something like that.. then i tell them not to do that. Then i have to explain the whole PR thing, but i dont mind all that. I wasnt even gonna do the floor untill i put the sundown in and needed a way to cover it. but now i think it looks great.
I think it's great, with the sundown on it gets nice and loud, and still sounds great. Ill probably keep this one in for a while too, until the next comp, then ill put my new axis back in
