juanl
Members
    41
Everything posted by juanl
  1. juanl
    Recone FI BTL
    I tried to buy it from the website but doesnt give me shipping to puerto rico arghhhhhhhhhhhhhh
  2. juanl
    Recone FI BTL
    im having trouble contacting FI guys to buy a Recone for a 18 BTL Old triple stacked magnetwith basket shipped to puerto rico i have send several emails but no respond could someone help me
  3. juanl
    Recone FI BTL
    my daughters jajajjaaajajja i need the recone double.7 think going with others amps just send you an email again nick so can tell me the price and what paypal account i deposit the money thanks a lot
  4. juanl
    Recone FI BTL
    heehhehehe thanks a lot nick well pic speake better than me i need a recone for 18 with basket for this motor double 2 ohms thanks a lot again ill check if i got your email right
  5. juanl
    Recone FI BTL
    thanks a lot i mailed them again hope to get respond soon
  6. juanl
    Recone FI BTL
    i emailed them several times just was thinking this could be faster but thanks for the help i mailed them again
  7. juanl
    18 ascendant havoc
    im looking for price of 2 18" ascendant havoc d1 shipped to 00725 and another question is this woofer can be reconed thanks they are gonna be run with a hifonics XX colossus
  8. juanl
    FI BL
    i already owned about a year why
  9. juanl
    FI BL
    im looking for a price for 2 18 inch FI BL fully loaded for daily d1 shipped to 00725 thanks a lot they are gonna be run by a hifonics XX colossus
  10. juanl
    FI BL
    thats what i want to know how much is extra for the shipping to puerto rico thanks
  11. juanl
    18 ascendant havoc
    yeah i was looking and didnt find anything i dont think they have a distribuitor in puerto rico
  12. juanl
    RE-XXX Recone?
    they must be very busy man because they always answer very fast i have a post a little down and they replied very fast man
  13. juanl
    need recone
    yes i think its a apocalipse 12"
  14. juanl
    need recone
    a friend of mine is needing a recone for a 12 inch atomic apocalipse can you do this recone and how much is with shipping 00725
  15. juanl
    need recone
    thanks man as soon mi friend call me i tell him thanks ohhhhh another question how much i s a fully loaded btl 18 for daliy ship to 00725 thanks
  16. juanl
    need recone
    this is the woofer
  17. juanl
    need recone
    no its for a friend of mine how can i measure it the woofer he have it complete he only burned
  18. juanl
    need recone
    you dont do recones for this sub
  19. jeje well it happen to me one time te fuse tht was for the external regualtor blow and it wasnt charging because it dont have power
  20. check the fuses maybe your alternator is not getting power
  21. juanl
    help with aeroports
    heres what i found about the sub the new ones because the older version does not come 15" Mounting Depth - 13.5" Mounting Hole Diameter - 14.5" Overall Diameter - 16" Bolt Hole Circle - 15.25" Motor Width - 10.5" Motor Depth - 5" Basket Depth - 8.5" Displacement - 0.27 cu. ft. Weight - 76 lbs. 15" Electrical Q Value -Qes: 0.58 Mechanical Q Value -Qms: 3.62 Total Speaker Q Value -Qts: 0.501 Free Air Resonance -Fs: 19.10 Hz Equivalent Compliance -Vas: 207.0 liters One-Way, Linear Excursion -Xmax: 54 mm Efficiency -SPL 1W/1m: 85.81 dB SPL Effective Piston Area -Sd: 810 cm^2 DC Resistance -Re: 4.2 ohm Nominal Impedance -Znom: Dual 2 ohm Thermal Power Handling -Pe: 2000 W Force Factor -Bl: 18.16 Mounting Depth - 13.5" Mounting Hole Diameter - 14.5" Overall Diameter - 16" Bolt Hole Circle - 15.25" Motor Width - 10.5" Motor Depth - 5" Basket Depth - 8.5" Displacement - 0.27 cu. ft. Weight - 76 lbs. 15" Sealed: ported: 18" Sealed: ported: Compact 0.85 1.7@35Hz Compact 1.6 3.2@35Hz Compact 3.3 6.0@35Hz Optimal 1.1 2.2@34Hz Optimal 2.1 4.0@33H but this is from the new oner i dont know if they are the same man i bought them used to a distribuitor in puerto rico heres the link http://reaudio.com/specs.html#sp_xxx
  22. i have a question i have an 1.25 cubic inch pvc tube for 1 15" and i want to tune it to the peak freq. of my car. i dont know what frequency is best for spl in my car i have a 4 door mitsubishi mirage and im going to use aeroport 3" and the woofers are RE XXX thanks in advance im new to this of port is there any advantage using larger aeroports in sealed i measured in the 58 thanks
  23. juanl
    help with aeroports
    ok and if i use 2.0 cubic feet i downloaded winisd in my other computer and i didnt know how to use it i was making some testing and yes with sealed tube with less than 1 cubic feet hit over 150 if i cant figure this out im thinking using it sealed but with 1.5 cubic feet thanks
  24. juanl
    help with aeroports
    ok and if i use a 2.0 cubic feet tube with 6" aeroport could this work or still not im trying to get it the most compact posible because i dont want the woofer inside my car jejejejeje
  25. juanl
    help with aeroports
    as dan said is local competition we dont have iasca or dbdrag and they divide us like that
