tezin87
Members
    745
Everything posted by tezin87
  1. tezin87
    Help with my R's
    depending on the displacement on the type r's.....i looked at alpines site the other day and i think it only reccomended 1.75ft^3 per sub. so you should be ok. but if you want to go bigger then go bigger. i suggest looking at the website and downloading the manual, it will have all the answers there.
  2. but what if you have one on a stock 110amp alt? is it still possible to go over 14.3?
  3. tezin87
    Help with my R's
    i dont know how much the r's take up but the port will take up 1.17ft^3. so that brings you right at 4ft^3, subtract sub displacement and you should be around 1.8ft^3 each i think.
  4. tezin87
    Starting to get fustrated
    So what was the problem?
  5. tezin87
    10" Fi BL Box Build
    i know this is a little old but the build looks great. how'd it sound once you got everything in the truck?
  6. tezin87
    99 Maxima Build Log, 2x 15" Type R's
    looking great so far....nice work
  7. tezin87
    Help with my R's
    no problem man, just tweak those dimensions a little to get the size you want. but like i said make sure you check with someone once you decide on what you're going to use. i remember reading on here that it's been wrong before.
  8. tezin87
    Help with my R's
    box width-40 box height-13.5 box depth1-22 box depth2-22 square port width-5 square port length2-0
  9. tezin87
    Help with my R's
    you should check out http://reaudio.com/speaker_box/LPort_Box_Calc.html and see what you can come up with. they even give you measurments on what size to cut the mdf. but i also heard that it can sometimes be inaccurate so double check with someone on here before you start the build.
  10. tezin87
    Help with my R's
    Whoever is going to design your box will need your max dimensions first. 40'' long x 13.5'' high x 22'' deep will give you 4.7ft^3 Port of 5'' wide x 12'' tall will give you 60in^2 of port and a tuning of around 33hz Once you subtract port displacement and sub displacement you should be around 3.5ft^3 or 1.75ft^3 per sub which is what Alpine recommends.
  11. tezin87
    Just Got my 15" FI Q a couple days ago
    Was there a huge difference in output when switching to ported from sealed? Because I only have around 1.5ft^3 to work with and i'm debating between a Q10 ported or a Q12 sealed and I'm trying to figure out the difference in output between those two. Sorry if I hijacked the thread.
  12. i just realized reaudio's program is for L-shaped ported enclosures. so the length of the first port wall will automatically be one port width away from the back wall because they are expecting you to add another port wall to the right. so if you don't want to use an L-shape port, you might not want to use this program. the shortest they're going to let you make the port is 20.25'' (26.5-.75 for the back of the box-5.5 for the width of the port) and that gave you a tuning of 29hz i believe.
  13. go to reaudio.com and use their box builder and your port would only be 13.5'' tall if your box was 15'' tall (subtract 3/4'' for top and bottom of box)
  14. tezin87
    3 12" icons
    should sound fantastic. what do you have up front?
  15. tezin87
    Understanding/dealing with cabin gain
    I have a regular cab truck and have the same problem. It sounds much louder and deeper when the windows are down. Don't know what it is, I just figured it was because the subs are right behind the seats.
  16. Is it dual 4 or single 4 ohm?
  17. tezin87
    Sports
    I went to highschool with Julian Wright. Great basketball player and even better person.
  18. tezin87
    Sundown Entry Level Woofer
    Over 140db in a sealed box with 1 12''? Is this right?
  19. tezin87
    New here for the 2nd time
    Welcome! I've sure learned alot in the few short weeks that I've been a member, these guys know their stuff.
  20. They should sound better actually, a much more linear BL curve due to the XBL^2 tech in them. As for output, I have no clue, but my guess would be no. They will be loud I'm sure, but compared to a ported sub with more Xmax, they probably won't be as loud. Yeah that's what I figured. Adding a second one should make up for it I'm sure. Two 12's in around 1.5 cubes would be nice as it is.
  21. Will the new BMs be able to compete with the older version even though they are recommended for only .5ft^3 sealed? By compete I mean output, I read they were supposed to sound just as good.
  22. tezin87
    Earthquake!!!
    I'm sitting in my classroom and I just felt another quake. Much less powerful and for only a few seconds....everyone else felt it too so I can't be imagining this.
  23. tezin87
    Earthquake!!!
    Haha I know, it was crazy. I thought it was my roommate shaking my bed to mess with me, but when I opened my eyes and no one was in my room I got real confused. Then I heard the cups and plates in the cabinet ratteling and my bed was still moving back and forth. Pretty crazy considering I live in a 4-story, 56 unit apartment building.
  24. tezin87
    Earthquake!!!
    I'm in Charleston, IL (Eastern Illinois University) and that earthquake shook my bed so hard it woke me right up.
  25. tezin87
    smaller boxes
    I was wondering the same thing. I'm either going with 1-12'' sealed or 1-10'' ported and I'm limited on space. Then I noticed the Havoc 12'' can be in 1.5ft^3 ported and it caught my eye.
