lithium
SSA Regular
    4,800
  • Days Won
    29
Everything posted by lithium
  1. If the parameters are accurate, they can be useful. However they often aren't accurate, and even if they are accurate, will change significantly as the suspension loosens up. Personally I'm more concerned with SPL at this point in my life. At my listening levels, it's impossible to discern small imperfections in sound. I can understand your side of the argument, but it simply doesn't apply so much to my listening habits as it does your own. why would any reputable company publish inaccurate specs? I was going to post something showing how you're constructing a straw man argument to defend your position but I think that would be lost on you. The fact of the matter is, assuming the T/S specs were measured correctly, we can predict how a woofer will behave. Its physics.
  2. lithium
    small space questions
    10s will be louder than 8s, thats the only difference.
  3. how much loss is power compression responsible for? is it in the neighborhood of 2-3 db for one woofer or 3-4 db for another? thats not significant if those two woofers have a large difference in efficiency.
  4. lithium
    should do alright. not sure what you're reference for output is so who can say its its loud enough.
  5. Different drivers have different degrees of power compression, which can very much make the drivers stray from their efficiency ratings at various power levels. Also, there isn't a well-followed standard behind most manufacturer's efficiency ratings, as was stated earlier in the thread. my guess is that you can minimize that difference if you compare subs of similar power ratings and/or restrict the applied power to something reasonable.
  6. lithium
    new enclosure for the zcons
    winisd is pretty simple. plug in the t/s specs and the enclosure size. but drawing any conclusion or comparisons between enclosures requires a bit more understanding.
  7. lithium
    wait how the fuck do you think SSA came up with enclosure recommendations in the first place? i understand that the program doesn't model in car response but no one here is claiming that it does.
  8. lithium
    go with the recommended enclosure spec from SSA. if you have you're limiting dimensions someone could probably design the box for you. I can design the enclosure. As in the cubic feet and tuning (port length) and figure cut sheet and build really good. . I just always see people talking about that you can see frequency response and port velocity and stuff like that. .... that's what I was trying to figure out SSA already figured it out. that's where their numbers come from.
  9. lithium
    dcon are probably too deep. maybe sundown sd would work. are you sure on the depth?
  10. lithium
  11. http://www.db-r.com/sell/store3/index.php?main_page=index&cPath=1_5_25_45_62
  12. i think it was this http://www.ebay.com/itm/Autotek-M4000-1D-Mean-Machine-Series-Monoblock-Class-D-Car-Audio-Amplifier-Amp-/141090674057?pt=Car_Amplifiers&hash=item20d9a8d589 not the old one, if that matters. oh wait i see. the old amp was the mm4000.1 and the new shit is m4000.1?
  13. You are forgetting acoustics my friend. cabin gain
  14. lithium
    UFO BTL worth giving up?
    http://www.soundsolutionsaudio.com/forum/topic/7168-a-technical-understanding-of-polyfill/ i guess it could get into the motor or something, maybe just reverse mount the sub if you're worried. You could also try fiberglass insulation stapled to the inside of the box.
  15. lithium
    you're worrying a lot over a little more than 1 octave. keep the install malleable. the ability to change the port tuning and so forth will definitely help. what EQ does you hu have?
  16. lithium
    you can get a flat response with the btl. just need some EQ work. understand that you're approaching the limits of human hearing and your perception of loudness isn't as simple as what a microphone is measuring (vibrations through the body for example). also consider when listening to music that one bass note at one frequency does not necessarily have the same amplitude as another note at another frequency. so if you think that one note should be just as loud as the other while listening to the song you're wrong. imo, when you're listening to this chopped or slowed music, worrying about flat response seems like a waste of time. just get the output you need, take care of the sound deadening, and knock down bad peaks. m5 said to sell your shit because you used the definition of SQ incorrectly. you've been around long enough to know what the definition entails. . I'm after loud as fuck that doesn't sound dirty muddy or distorted." this very easy to accomplish. 1000$ subs and highend amps aren't need. just basic install skills.
  17. lithium
    Help With Active Front Stage Setup.
    sounds great! no reason to jump in over your head. if you have a home stereo or computer speaker set up it might be fun to pick up a 2x4 minidps unit and play around with the software and tuning. i think this would be a great way to learn before trying to do it in a car.
  18. lithium
    in terms of distortion your music tracks that are processed to fuck with slowed music and shit are probably going to contribute more than the amps.
  19. lithium
    watts are watts. you're worried about clarity in the frequency range the human ear is actually not very good at discerning.
  20. lithium
    i'll post some more later tonight. looking at the numbers, its clear what these drivers were designed for.
  21. lithium
    ok first pic. i thought I would start with the box recommendations posted on the tc sounds page and compare that what a btl enclosure usually is.
  22. lithium
    how do you think products are designed in the first place?
  23. lithium
    yep. i'm not the very knowledgeable when it comes to subwoofer and enclosure modeling but the LMS really looks like a sub designed for home theater. if you look at the product page on tcsounds.com you can see lots of low tune recommendations. i'll post a few.
  24. lithium
    http://s1116.photobucket.com/user/wizart383/media/btlspects.png.html found them
