4,800 -
Days Won
29
Content Type
Profiles
Forums
Gallery
Everything posted by lithium
components are the ones with a seperate mid woofer and tweet. the others you are referring to, with the tweeter in the middle of the woofer, are called coaxials. more info is need on your install to suggest any products.
Low cost subs for high displacement project...?
lithium replied to marisume's topic in Subwoofers / Speakers
triple post... -
my bad...
u could pick up some 15 type r's or kicker l5 / l7s off ebay or something like that on the cheap... -
wall time
thanks for the advice, id hate to waste cash on something that not effective.
guess ill try some walk-throughs ive read for tuning by ear first. i think the rta would be useful, as far as, a visual verification. i think my plan for my doors are to open them back up and try to kill as many rattles as i can. if that doesn't take care of them all ill try a closed cell foam and mlv barrier (like i should have done in the first place lol).
ya, i've gone back and forth with this for awhile... before this install i was all for it, but now i think i can get some good results with other tuning methods.... then again, maybe with an rta i can do even better... its a tough choice right now i should probably be focused getting this build done before i try and tackle another project. hell, i dont even have the door panels back on yet, and now im starting to plan a false floor of some kind... im out for the night, any opinions on the build and shit is welcome. thanks guys
if i can come up with a way to get my sub mounted in my friends regular cab s10, he'll probably take it off my hands (actually i have this worked out pretty well ). from there im not sure where to go... any ideas? edit: just remembered... i've considered building a cheap RTA, cost is about 100 bucks. i've read alot about it on diyma, specifically, a post called build a RTA for under 100 bucks (i think that's what its called). i dont think i have the ear for more tuning... im more of a hands on/visual kinda guy
Sorry my iPod is double posting
Haha. Thanks, these beasts make my sub seem pointless LOL!. I have them crossed at 40 w/ a 18 db slope. Next step down is 32.5 I think. The driver side 3" is alittle off axis buy will be corrected with new pods.
mounting depth on these bad boys? looks like about 5.5 inches tops, based on the pic with the soda can?
sorry guys, been busy... ok i know its looking alittle ugle but ill be cleaning things up shortly. but first i have to do afew things. turns out my doors aren't deadened enough for these sls's... i believe the rattles i have are parts of the mechanism that moves the windows up and down... so now ill be opening things back up to see what i can do there. next up i have to make new pods for the full ranges. originally i thought they would fit right into a 3" pvc end cap but i had some specs messed up. i should have ordered the 2.5 inch full range and that could have fit in the 2" end cap. then again i think i have a solution to my problem here. i plan to use the fancy new router jig i baught my dad to make some rings that i will form into something that looks like the endcaps....or.... ill try fiber glassing them up there (never done fg before...) after this all is taken care of i plan to move on to remake my amp rack.. currently i have it holding my amps upside down under my rear deck (hides them pretty well ). but i think i want to change this up by making a false floor. this would provide allot more security for the amps and make for a much more stealth install. i am also considering integrating the sub into the false floor by fg'ing the spare tire well, etc. well that takes care of what i plan to do next... ill save a review of the speakers and everything till after i get the install correct. however, so far everything is amazing. i took some time to make sure that im not over reacting thru some kind of psychological mind trick where i think it sounds better just because its new. this really is the best sounding system i've ever heard (cant compare it to anything tho...). the detal is very impressive. the 8's can dig so damn low im not even using the sub. if i can get the door rattles calmed down ill be golden. up top the 3's are beautiful. no harshness or lack of upper end. current restriction dont allow me to get the driver side mid completely on axis so once again i wont go into more detail till the install is complete.
ive heard the assassin, great lil sub. very accurate reproduction and it wasnt even broke in. i ran it in a 1.2 cub sealed box, but i assume, if like the other AA sub i own (arsenal), that it will stay accurate in a proper ported enclosure and gain some extra output aswell.
holy shit haha that rf is pucking hilarious! which model is that? edit: nvm i just looked it up, its a p2. thats really sad, for a company with some good equipment, to produce bullshit like that...
could u provides some links to info that could explain this more then "sounds nasty.." http://www.crutchfield.com/S-MLIdlc3FE4h/learn/learningcenter/home/speakers_glossary.html Standing waves Standing waves occur when the sound from your speakers is reflected back and forth between the parallel surfaces in your room: the side walls, the front and rear wall, and the floor and ceiling. This effects amplifies some frequencies while others might get canceled out, creating areas of differing sound pressure or loudness around your room. thanks
yeah i kno....lol had the box in the other way then flipped it and was to lazy to flip the subb... haha it says "ass"
Hifonics problems
lithium replied to Julian's topic in Amplifiers / Head Units / Processors / Electrical
loose ground or power wire at the amp? -
I assume m5 ment they should be getting lower. Pop one of the mids out of phase once if u havent. Also if it comes down to new woofers u could do a deticated mid bass and a small full range. I just did this myself with great results. I used an 8 " peerless Sls with a 3" peerless full range. I'll be updating my build late.... The instal is still kinda rough... But sounds amazing!!!
could it be the battery's ground to the frame that is causing it, not the amps ground? you might as well upgrade the battery to chassis ground anyways.... it looks cooler that way edit: duran. sick ass avatar btw
heres the pics guys. i need to get some sleep so ill just post for now and give a run down on what im planing to do with everything else later. before after other side (more on axis then they look, but ill talk about that more later...) dooooooooors before other side gota get some sleep. ill post more shit later
ordered some of the stuff from partexpress... i had a 5 dollar off coupon so i figured what the heck i got my dad the router buddy for fathers day! im already thinking of afew ideas to try out with it... ill explain more when i post some pics up within the hour. sorry to keep anyone waiting...
just throwing a thought out there... ground back to battey neg. up front? swap amps to verify if it is the amp that is damaged? do u have other amps off same power and ground?
