Bobaflob
Members
    449
Everything posted by Bobaflob
  1. Bobaflob
    A little lost
    I dont have anything in mind for the other amps and i am open to suggestions.Going for a simple 2 speaker setup also, and open to suggestions on speakers. Set up is for music.
  2. Bobaflob
    A little lost
    Think i solved the problem Cleanbox . Run rcas from reciever to this then xlr to amps and crossover?
  3. Fuzz Busta Shows Voltage, and you get a compass and fuzz buster.
  4. Bobaflob
    10 gauge Klear Kable help, please
    The square and circle shapes are used to differentiate between negative and positive, Example: Plug Square shaped into negative terminal on woofer, and plug circular shape into positive on woofer. Then you can tell where to plug the wire into on the amp Pos+(circular) Neg-(square)
  5. The way gas prices are im going to have to move my system out of my Truck and into my car. Only problem is i cant seem to find a high output alt for my 90 stanza. Anyone got any suggestions?
  6. According to this application guide i found, a 1990 stanza has the same alt as a 93-95 altima. http://www.autopartsway.com/acp/index.cfm?...s~PGpd~PT851570 Found this alt from iraggi. http://cgi.ebay.com/ebaymotors/200amp-Irag...ShippingPayment
  7. Im thinking this might work http://cgi.ebay.com/ebaymotors/200amp-Irag...itemZ7958308993
  8. Bobaflob
    ALL IA SUBS ARE ON THE SHOP
    Theres a listing for a 21" death row. On the specs it only goes up to an 18, and on IAs website it ony shows an 18 death row. http://www.soundsolutionsaudio.com/zencart...;products_id=26
  9. Bobaflob
    Made a new fi customer
    Went out to move my vehicle earlier(after bumping my bl 18") and noticed a car sitting in the road. I got in started it up and the car rolls forward and out pops a cop. He asks me if i was playing my music loudly earlier, and i told him I was. He skips right past the warning and asks me what i got, and i told him to shine his light in the window. He says holy chit and asked for the company name so i told him. He wrote all down on a notepad and told me what he had in his previous system ,and we bullchitted for a few mins and told me he would look into it and rolled off.
  10. Bobaflob
    Amp screwed?
    thank you for your help and advice
  11. Bobaflob
    Amp screwed?
    Got my amp and sub hooked up, started bumping some music then it cut off. I went back to check out what was going and and saw that a razor blade had fallen across the speaker terminals on the amp. Now the amp wont power up.
  12. Bobaflob
    Amp screwed?
    Never mind when the bass hit it diconnected the remote on wire at the same time the blade fell so lucky me.
  13. Bobaflob
    Mounting Fi Bl 18
    Thanks that all i needed to know.
  14. Bobaflob
    Mounting Fi Bl 18
    Got my bl today, went to bolt it into the box and noticed that the holes in the gasket don't go all the way through. I can see the holes on the bottom then the lip that comes off of the surround goes over the whole and blocks it. Do i drill through it?
  15. Do not purchase these amps from the ebay seller riversidetrade they are defective. They were never supposed to be released to the public. The heat sink is to small causing them to overheat and fail. On the good ones the heat sink extends out beyond the case. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...;Category=39739
  16. looks like a little piece of plastic that overrides the internal voltage regulator of your alternator.
  17. Bobaflob
    Best Amp for a BL?
    Im going to use a MTX TA81001 for my bl, its birthsheet says 1897 at 14.4v
