xhilr8n
New Members
    12
Everything posted by xhilr8n
  1. xhilr8n
    15" btl application
    i did a 146.3 with the dd but want higher numbers with the next setup. I look forward to seeing more of your install. I have heard that not many have better customer service than fi. Only thing i can remember being better was where someone sold on car audio a set of burned up ssa's or something like that and them being burned up and the manufacturer taking care of them anyway.......... either way always awesome. jason
  2. xhilr8n
    15" btl application
    I want another t-line in my truck. I had a dd 9515g, it didn't hold up. I will have 3kw on hand. What options on the 08 model BTL would get where i want to be with suspension, cooling, and power handling, as well as x max........If a combination of stiff spiders was needed then that would be ok as well. I just don't really know how well they will handle this type of application. It a 2006 nissan frontier(the big ones) xtra cab so i have a decent amount of room as my backseats are removed. advice will be appreciated. Jason
  3. xhilr8n
    15" btl application
    thats the way mine was setup, my last one was designed by Pete K. for the dd9515G. It's was chanbered 1/4 wave. how much power do you have on it, any vids, pics or anything i wanna get and idea of how they will do.....i am thinking with the hi xmax coil and all the cooling options etc. that they should fair well...... Jason
  4. xhilr8n
    Subwoofer Choices
    I am looking into the following subs over the next couple weeks before i purchase one. DC level 5 Mach 5 spl Sundown nightshade(isn't this the same as the old btl) FI BTL Eclipse 9115(found one new in box) for 600$ 4hp motor at my local shop
  5. xhilr8n
    Subwoofer Choices
    Well earlier this year i had a crossfire vr2000@1ohm around 3kw on a dd 9515g in a Pete K. designed t-line. I really like the output through a broad range of frequencies, and plan to do another t-line setup. However i think i could have made a better choice for woofers I have a 2006 nissan frontier (the bigger ones), have quite a bit of room if neccessary. Undecided on an amp to power it but will be at least 3kw with proper alt and batts. I have installed two sets of PG RSD6.5 comps with 100 watts per channel still running passive for now. i think the two sets of comps ran active would almost keep up with the system i have in mind. The plan is to do another t-line but with a woofer better suited for that kind of enclosure. There are a couple factors i am taking into consideration 1. X-max 2. Rms in said enclosure 3. Sound Quality (an eclipse ti 15 outdid the dd in the same box by far. 4. I want it stupid loud, would like to break a 50(i know what it's hard) I think i am thinking in the right terms on this one, but i am welcoming and seeking GOOD advice from people with experience in similar situations Forgot to add, i want 2 12"s or 1 15<-----more than likely the single 15 ps.....the dd died twice, probably my fault but it wouldn't do what i wanted it to so it didn't matter. ' thanks for help in advance Jason
  6. xhilr8n
    FI's accomplish dual duty?
    I am planning to purchase a BTL 15 when they are available, i would like to know what kinda applications this sub is gonna be adaptable to. I had a DD 9515G, but everytime i talk to them via e-mail or on the phone their customer service is severely lacking lately. So i sold it. I would like to run one of the BTL's in the DD's place daily in a T-line Enclosure, and then in a standard slot ported, or possibly kerf ported enclosure for when i wanna meter it. What kind of options are gonna be available, and what the specifics of them. I went the the website, and the options and just complete overview of the sub is obviously being revised for the new model. Options i remember that i would be interested in would be High X-Max coil Cooling option Pretty stiff suspension for it to hold up in the T-line without loosening up over time. Would also like a Dual 2 ohm configuration if that is an option. If someone knows what the other options are please let me know. This isn't just a post to waste everyones time, i have been reading and searching, and still am to try and figure out exactly what i want this sub to be. This WILL be my next steup, so in advance i appreciate the time people take to reply. Thanks, Jason
  7. xhilr8n
    i believe so.....if this one won't work i'll have another one designed. I really like how it sounded tonally sp? If you can design one for spl that would sound nearly the same for daily i wouldn't mind that much either. I would rather stick with my two different boxes though. one for daily and one for comps etc. When you say mass loaded, can you explain, i don't know all the terminology. Maybe i can answer that question with more explanation of what you are asking. The box had no fill etc., just a woofer and a lot of area etc. Jason BTW.....thanks for the responses finally.
  8. xhilr8n
    nothing?
  9. xhilr8n
    SPL-15
    if price is under 400$, give me a date that they will be done, i would like to have one.....
  10. xhilr8n
    Whats Going On
    thanks......and NICE sig man.
  11. xhilr8n
    Whats Going On
    well i am new here hence the post in the newbie section, just kinda want to hang out on a different board. plan on reading and absorbing as much info as possible.
  12. xhilr8n
    Whats Going On
    I live in Dothan AL, i have read some good stuff about this forum. My current setup is: Panasonic 6505U headunit DDin dash DVD Crossfire cfq 5.2 preamp/crossover Crossfire VR 354 mid/highs amp 2 sets of SS rf60 components front and rear 2 Optima Yellotops Kicker wiring/rca's/etc. lots o' 1/0 1 crossfire vr2000 15" Eclipse TI, in a Pete K designed T-line i had the box origianlly designed for my DD9515G, it is in the process of being reconed, and should return to action soon.
