Steven Kephart
New Members
    21
Everything posted by Steven Kephart
  1. Steven Kephart
    My theatre
    I just upgraded to an HD projector as well. I built a screen with this material: http://www.dazian.com/cgi-bin/page.pl?acti...d=339&group_id= It is acoustically transparent, so you can put your center channel behind it. I basically built a frame and stretched the material with great results. It only cost me about $30. I had previous experience with the stuff after building a 16' by 9' screen at Adire. I did make one change after talking to Kevin at DIY Cable. I stretched some black grill cloth behind it which masks any framing from being viewed through the material, and improves the blacks a little bit. Hopefully that gives you some ideas.
  2. Steven Kephart
    XXX or RL-s?
    Dan kept his comments to the facts about each type. There was no "bad mouthing" about it as everything he said was true and unopinionated. But just because you don't like his conclusions doesn't mean you need to take cheap shots at him. Or maybe you could prove factually that his conclusions are wrong?
  3. Steven Kephart
    New mids?
    Ah, I see what he is talking about now. Those actually aren't "Adire" drivers. Those are drivers Adire is designing for an OEM client.
  4. Steven Kephart
    New mids?
    They aren't out yet if I remember correctly. <{POST_SNAPBACK}> I believe he's talking about these surplus drivers: http://forum.soundillusions.net/showthread.php?t=56323 But IMO I would choose the Extremis over that surplus driver as it has more excursion. After all it was designed to out-perform the Revelators and Excel's.
  5. Steven Kephart
    different motor techs
    Dan Wiggins just did a run-down of different motor designs on the Adire forum that should give you what you even more information. Here's a link: http://forum.soundillusions.net/showthread...3755#post583755
  6. Steven Kephart
    Hello vladd. You can find a couple technical papers in the tech section on Adire's website about XBL^2. Here's a link to them: http://www.adireaudio.com/Files/XBL2TechPaper.pdf http://www.adireaudio.com/Files/XBL2DetailsPaper.pdf It's easier to draw pictures than to try to explain how it functions, but I will try. Think of having 2 "gaps" of magnetic flux with a certain height, and the space between the gaps being the same height. Now picture a coil twice as long as one of the gaps. Now picture the top of the coil filling up the bottom gap, and hanging down below it. Now picture the coil moving up toward the other gap to where now the bottom of the coil is completely covering the bottom gap, and the top of the coil is in the space between the two gaps. Now picture the coil moving up further still. Now the coil is starting to enter the upper gap, however it is leaving the bottom gap at the same rate. This means that the amount of flux the coil is seeing is staying the same as it transfers from one gap to another. Now it can continue moving up until the bottom part of the coil is in the top gap. As you can see, you get a great deal of excursion from a short coil. I drew a picture a long time ago that should help with your visualization. It shows the coil at it's peaks of excursion. Here's the link: http://memimage.cardomain.net/member_image...68_115_full.jpg
  7. Steven Kephart
    how to recone tutorial
    Just to let you guys know, it is also stickied in the Advanced Discussion Forum as well.
  8. Steven Kephart
    Recommended Test CD's
    If you want a really good imaging CD, check out Planet Drum by Mickey Hart (ex Greatful Dead drummer). http://www.amazon.com/exec/obidos/tg/detai...=music&n=507846 The Fifth Element soundtrack is a pretty good one as well.
  9. Steven Kephart
    BL motor strength and performance
    Ok, BL is made up of the B field; the magnetic flux effected by the coil, and L which is the number of turns (length of wire) effected by the magnetic flux. When you change the number of turns (changing BL), you change Re. Now on to dual voice coils. Think of each voice coil as seperate. Each voice coil has it's own Re that will multiply by two when seriesed and divide by two when paralleled. Well BL is effected because when in series there is twice the length of wire, therefore higher BL. In Parallel you in essence double the thickness of the wire. Steven Kephart Adire Audio
  10. Steven Kephart
    Secrets to box building
    One thing I like to do when building enclosures is when the edges of the MDF are going to be exposed, cut that piece 1/4" large. Then when you build the enclosure, you should have 1/8" of wood sticking out in those areas. Now use a flush trim bit on a router to cut the excess off and you are left with professional looking edges. Steven Kephart Adire Audio
  11. Steven Kephart
    new towers for me questions
    I wouldn't recommend the equipment and software for the DIY'er. It is extremely expensive and difficult to learn how to use. That's why I suggested the kits to you since the design work is already done. In fact if you want some killer sounding kits for cheap, check out Exodus Audio's offerings. They are by far the best performance per dollar I've heard. Steven Kephart Adire Audio
  12. Steven Kephart
    Imaging, phase, and soundstage
    Each vehicle/system is so different it is very difficult to say. It also depends on the persons abilities to set the time alignment properly. Keep in mind that custom pods are generally aimed, so they are more on axis. This could be a benifit if falling into what I described earlier. I guess the point of my comments isn't to completely rule out kick pannels. It's just to help people get a realistic idea of what the benifits/weaknesses are. My plans for my car is to put the mids in the lower doors, and put the tweeters up in the A-pillars. But then I've got some pretty crazy processing available with 72 dB per octave digital slopes on the crossover which will greatly reduce comb filtering and allow me to run the tweeter much lower. I'm also going all active so I can adjust the time alignment on the tweeters and mids seperately. And finally to tune everything from there I have a pretty crazy parametric equalizer. The results should be pretty amazing, I hope. Steven Kephart Adire Audio
  13. Steven Kephart
    That's what beaming effects is the off-axis response. If you are crossing the driver over before the off axis is rolling off then aiming probably won't help any. I kept my comments mainly to actual speaker positioning and really didn't mention time alignment. Changing time alignment in intervals smaller than 3 miliseconds will make a difference in the frequency domain, which is most likely what you were hearing. If you noticed, I mentioned that the new speaker locations would also have a change in the frequency domain. There are several ways this is effected. The main one I remember Dan telling me was that you change the spectrum of comb filtering. I guess what I learned from all this, and I hope others do as well, is that kick pannel positioning isn't always THE BEST solution. Generally speaking, the easiest and best way to set things up is to use the stock, lower door locations and utilize proper processing. Steven Kephart Adire Audio
  14. Steven Kephart
    High BL is not necessarily a good thing. You want just as much BL as needed, and that's it. To understand why, you must understand what happens to the parameters when you change one thing like BL. Here's a quote Dan Wiggins once posted that explains how they interact with eachother: "Vb is proportional to Vas (double Vas, double Vb). Vb is proportional to Qes squared (halve Qes, quarter Vb). This is for the same Qtc/alignment... And since Qes is inversely proportional to BL squared, if you double BL you cut Qes by a factor of 4, meaning the box volume for a given alignment is cut by a factor of 8. Now, that is all well and good, but consider what Fb does in relation to Qts/Qes... Fb is inversely proportional to Qts, thus as you raise the BL, and lower the Qts, you raise the Fb accordingly. Double BL, cut Qts by a factor of 4, meaning Fb just jumped up 2 octaves!" As for BL and Re, when you double Re you double BL. So two subs with the same BL and different Re's have different motor forces. That's how they interact. I'll try to get more information to explain why. I hope that helps. Steven Kephart Adire Audio
  15. Steven Kephart
    We use LspCad for a lot of things as it is a great program. But I believe Dan mainly prefers and uses Praxis for crossover design. I believe he also likes MLSA and Speakeasy as well, although the latter is less user friendly. I know he doesn't like Lms as it isn't as accurate and doesn't have nearly the functionality. It's really neet to watch him do it. First he has me build test cabinets and mount the speakers. He then tests the frequency response of each speaker, and then uses the program to design a crossover to match his own response curve (this is something he and Dr. Hyre spent thousands of hours of testing and listening to come up with). He then hooks up the speakers to his computer and listens to the crossovers, using the software to simulate the new design. He can then make changes to the crossover based on available values, and tweak the sound for the clients tastes. Once we have a good sounding crossover, we order the parts, put them together, and take a listen again. Steven Kephart Adire Audio
  16. Steven Kephart
    Wow, this section doesn't get much traffic. Hopefully my information will still be helpful to you and others. I have been learning a lot about front speaker installation recently from my boss, Dan Wiggins. I've been trying to figure out what is really important, and what isn't. I've found out that there are a lot of myths out there on this subject. For one thing, I've found that people put too much emphasis on speaker aiming. It is only important if the speakers are going to have beaming issues at the axis they will be mounted at. However if you aren't taking the speakers up that high in frequency, then it isn't an issue. For example, let's say you are running your 6.5" mids to only 2.5 kHz or so and letting the tweeter take it up from there. Then you shouldn't need to aim the mid. The second one is mounting location. People spend a great deal of time and money on placing their speakers in the kick pannels. However I've found out that it might not be a wise thing to do. For one thing, the timing differences doesn't audibly effect imaging cues. The idea is that kick pannel locations will equalize the pathlength differences between the two sides. But when you actually understand how our hearing works, you will find that it isn't necessarily true. So let's look at two things you must understand about our hearing. First of all, you must understand where we get imaging cues from. For frequencies 1000 Hz and up we get our imaging cues strictly from amplitude differences. In other words, if a tone within this frequency band is played louder on the left side than the right, then the sound will sound like it is coming from the left side. For frequencies 500 Hz and down, we get our imaging cues strictly from timing cues. Now you will notice that midrange drivers do play a majority of those frequencies effected by timing. However there is another limitation of our hearing that you must understand. That is called the Latent time of Fusion. What that is is a limit of how quickly our ears can preceive a sound. This limit is around 3 miliseconds. If a tone is played twice within 3 miliseconds, then it will sound like one sound. So how far would you have to move your speaker to effect a 3 milisecond change? That would be around 3 feet. So unless you are moving the speakers that far, then the imaging won't be effected by timing cues. Now that's not to say that your speakers won't sound different in the kick pannels. It's just saying that any differences you hear won't be caused by the above as usually claimed. The differences are frequency response related and come from changes in tonality from comb filtering and differences in reflections due to the new mounting location. This change in frequency response could be good or bad. It is usually the latter as the speakers are now located deeper in a hole with even more surfaces to effect them. The question you have to ask yourself is if it is worth the extra time and money to take the chance. Steven Kephart Adire Audio
  17. Steven Kephart
    How to rebuild a woofer
    I know this was asked a while ago, but I thought I would add the answer. Remember that BL is B times L. B is the magnetic flux seen by the coil, and L is the length of wire effected by the magnetic flux. If you make the wire larger, you change quite a few properties of the subwoofer. For one thing, it becomes more difficult to stack the same length of wire in the gap. You also effect the moving mass, DC resistance, inductance, and as mentioned earlier BL which will effect other parameters from there. And the question comes up of why? Thermal handling isn't a major issue with the smaller awg wire typically used currently. So if it aint broke, why go through all the trouble of trying to fix it? Steven Kephart Adire Audio
  18. Steven Kephart
    The crossover is THE most important part of any speaker system. You cannot just select some off-the-shelf crossover and hope to get good results. This includes textbook electrical slopes. This is because they need to be designed specifically for the speakers being used in their intended application. There is much more to a crossover than just the crossover points. There is equalization, level setting, etc. and they should take into account the natural response of the drivers as well. Designing all that into the crossover is "voicing" the speakers. You really need expensive test equipment and software to design crossovers properly. I'd really recommend for you to look into kit speakers. They Have the crossovers already designed and include all the parts and speakers needed. All you have to do is build the cabinets and put it all together. Steven Kephart Adire Audio
  19. Steven Kephart
    ported doorpods
    That might be the best idea anyway as it will reduce early reflections. As a suggestion, try wrapping them in some thin foam padding and then grill cloth. You should be able to hide the ports behind the grill cloth without impeding their performance any. That is unless you want them visible. yeah..so u say... lol..we're not there to hear them are we?? noooo, all we get is crappy audio on a sweeet video....though now when i think about...i always turn the sound off when i'm watching pr0n anyway... nevermind...lol... wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee <{POST_SNAPBACK}> I say so tooo!! Of course I'm bias. In fact, I'm listening to 4 of them right now. Watching movies is sooooooo much fun at home now. In fact I took the sub back to Adire since I didn't need it. Heck, I've got the displacement of a 12" subwoofer after all. Sky Captain makes my couch shake. Steven Kephart Adire Audio
  20. Steven Kephart
    ported doorpods
    Those pods look incredible. You did an awesome job on the fabrication. You are making me want to finally swap my Koda's with the Extremis. BTW, how are you planning on finishing them? Please forgive me if you already said. I must admit that I skimmed this thread. And for those who want to see more vids of the Extremis in action, you can find a few more vids on www.woofervids.com. Steven Kephart Adire Audio
  21. Steven Kephart
    IN SHOCK....
    I just wanted to give my sympothies for this absolute horrible occurance. I truely hope that the perpetrators are caught and fully punnished for their actions. And Above all, I hope all the equipment is returned to you. Being robbed of not just equipment, but your livelyhood is so horrible. I really don't want to see SI go away because I think you guys have a really good thing going there. I want to let you know that I truely wish you the best of luck in this situation. You are in my prayers. Steven Kephart Adire Audio
