NDMstang65
Super Moderators
    4,860
  • Days Won
    39
Everything posted by NDMstang65
  1. NDMstang65
    btl 18 cuts out at high volume HELP!!!!!!
    Ok well the manufacturer claims it is a 1 ohm stable amp. Are you saying that it cant handle 1 ohm because the amp is defective? Specs SPECIFICATIONS RMS Power at 13.8V 1400W into 2 ohms with less than 1% THD+N 2200W into 1 ohm with less than 1% THD+N S/N Ratio: -92db A-Wtd Frequency Response: <10 to 225Hz Lowpass Filter: Variable 24db, 70 to 200Hz Idle Current: 1A Dimensions (LxWxH): 15” x 9.25” x 2.25” FEATURES Ultra- Efficient Class D Audio Output Stage
  2. NDMstang65
    Of course you aren't going to have any problems...you are running at 2ohms, not 1ohm. If you have the problem when something is wired to 1ohm...then you need to duplicate that situation again with another speaker. The amp probably cannot handle 1ohm...and freaks out and shuts off.
  3. NDMstang65
    Since everyone seems to want Neo...
    hmmmmm
  4. NDMstang65
    In the chat...
    afadfaeraeaeaee
  5. NDMstang65
    reconed xxx question
    No clue there, he probably has a XXX recone with the integrated lead suspension on it.. By full dustcap you mean it is dished like a bowl? Or is it a "Boob" style cap like we use on our subs?
  6. NDMstang65
    Finished setup in EK hatch
    Looks good man!
  7. NDMstang65
    SSD 15 build time
    3-7 business days to build, then they ship.
  8. NDMstang65
    recone, does it matter if universal was selected?
    3-4 days to build it and ship it out.
  9. NDMstang65
    ~ 2 weeks or so.. You might want to recone it yourself.
  10. NDMstang65
    D2 is the universal gap.. You are good to go.
  11. NDMstang65
    Tech specs for X line
    Box stuff is below the specs on the website, I just never wrote a 'Tech' section for it. The same 12-16sq inches of vent area apply as always with our subs.
  12. I'd suggest purchasing the sub last...because you can customize it for generally whatever scenario you have going on..
  13. NDMstang65
    Fi Sssd 18" box size limitations - help evryone
    That..isn't going to sound good at all.
  14. NDMstang65
    The BL 15' fully loaded power handling
    it's a stair step gentleman.. the stock one is rated at 1000...options add from there
  15. NDMstang65
    AA Havoc Suspension
    Regardless..if you have stress marks around your surround you probably have popped holes/rips in the spiders radially at 12,3,6,9 oclock.. You didn't have your subsonic filter set right to roll things off properly...the screen printing on those amplifiers is a crap shoot at best because the variance in the potentiometers that they use can be as high as 20%..regardless of what anybody wants to say. The only way to set it properly is by verifying where the filter rolls off with a tone burst track on a bass CD...
  16. NDMstang65
    I did not receive my order
    As far as I am concerned, until it's in your hands, the seller is responsible. I.e. if it never shows up, they need to take it as a loss and send another. No reputable company would leave you out in the cold because of a screw up before it ever hit your possession. And I'm pretty sure no judge would side with them if they did. UPS has to deal with it...and the OP hasn't replied back saying anything. We can talk to our rep..but until he files a claim there's nothing we can do.
  17. NDMstang65
    In the chat...
    gfs
  18. NDMstang65
    Recone Help
    The cooling comes from the motor machining.. 1500 watts shouldn't be an issue as it'd be the same coil that the BTL uses provided it will fit in the gap...
  19. NDMstang65
    Recone Help
    Not a great deal can be done, we'll use a High xmax style coil and integrated leads. What makes our subs different from everybody elses is the ton of machine work that goes on inside of everything. We simply can't add that to a motor that has already been magnetized.
  20. NDMstang65
    Is something wrong with 15 ssd?
    Take it out of the box and free air it at 20Hz and get it to full stroke and see if it still makes the noise.
  21. NDMstang65
    Recone Help
    Can't use that basket. Ballpark figure on a recone is $100, the baskets are $32. You can either send it in to us or you can give us the dimensions of the top plate and we can build you a recone up...
  22. NDMstang65
    T-Line box Fi Q15
    Wasting your time and money..and will end up with a dead sub. Don't do it ..just giving you fair warning.
  23. NDMstang65
    UPS drivers mess up occasionally...call UPS with your tracking number and ask them. Whatever address you entered on the website when you placed your order is the one that we put on the ticket...
  24. NDMstang65
    Reminds me of a leaky sealed box..
