NDMstang65
Super Moderators
    4,860
  • Days Won
    39
Everything posted by NDMstang65
  1. No shit?! Dude, it was nuts before... If i make it out west this summer i've GOT to hear it I had no idea you were doing 2 of the amps!
  2. NDMstang65
    Hey scott or nick
    Dual 2 is fine...waiting on Scotts email, i combined a ton of recones into one... I think yours was in there, if not he should see this when he gets on here tonight. Thanks -Nick
  3. NDMstang65
    will this work
    Might work fine, odds are it's going to roll off pretty quickly on the 'upper end' around 60Hz or so... The low end should be retarded though . Thanks! -Nick
  4. NDMstang65
    can fi compete?
    If you have deep pockets, whatever you want can be made. It all depends on how much money you want to spend .
  5. NDMstang65
    BL horizontal mounting
    No sir.
  6. NDMstang65
    I need a 10" recone for Brahma MKII
    :edited: Crap..saw your zipcode, never mind. Should have you a quote this evening. Thanks! -Nick
  7. NDMstang65
    4 18" BTL Build
    Awesome man! How do you like the subs so far?
  8. NDMstang65
    will this work
    That's tuned a little low...i guess you could try it and see what it does. I've personally never tuned one that low. Thanks -Nick
  9. NDMstang65
    Which FI sub fits my needs
    How much power and how much room do you have to work with? Thanks! -Nick
  10. NDMstang65
    Honestly, with a properly designed suspension...it won't matter how you mount it. Thanks -Nick
  11. Can't wait to see how those 4 3100's work with that amp!
  12. NDMstang65
    Hey scott or nick
    Nope that's just a recone kit for a XXX...what impedance coil are you wanting? (assuming probably a dual 1.4) I'll get you a quote shipped tomorrow. Thanks -Nick
  13. NDMstang65
    2 15" Q's or BL's
    BL's will be more likely to peak than the Q's and should be louder... ~1500 watts tends to be optimal for "loaded" BL's... Thanks -Nick
  14. NDMstang65
    Hey scott or nick
    $85 plus whatever shipping is to you. Thanks! -Nick
  15. Only way to minimize it is to not have them . All i can tell you to do is hook it up and listen, if you don't hear it then your good to go. Thanks -Nick
  16. NDMstang65
    SSD 12 problem
    They are going to get soft after running them for a while... If it becomes an issue then it should be covered under warranty Post a picture if you get a chance. Thanks -Nick
  17. No...the tinsels go all the way through the cone and are buried under glue next to the coil/neck joint... You can't trim them down....there's actually strands of wire that goes through the outside layer
  18. NDMstang65
    Couple of BTL questions
    When you kill it, that's too much. Honestly man that's 100% install dependent. We've had people run tons of power on burps with no issues. We stick to our guns with 2kw rms, if you find it can take more and is louder with more power then that's great. However, we won't say that it will take it, simply because we do not know the install and the scenario in which the sub is in... Thanks! -Nick
  19. NDMstang65
    Couple Power Upgrade questions for someone
    I would say 2 of the kinetik 2400's or 2 of the Powermaster 2400's would probably cover you, in addition to your alt and wiring upgrades. Thanks -Nick
  20. NDMstang65
    how much for a ssd 18 shipped
    Should be able to have you a quote on Monday, unless Scott sees this before hand this weekend. Thanks -Nick
  21. NDMstang65
    cant get my order in!!!!!!!!
    Sorry man... If you have paypal the email there is Sales"at"ficaraudio.com When you do that, include all of your shipping information, Name, Address, Phone number, Email. Exactly which woofer you want (Including all options, coil impedance, size etc.) I just got the email yesterday morning saying that you wanted to order one, so i forwarded it over to Scott around 3pm which is how he got in contact with you last night. Sorry about that, we're working on getting things more streamlined with some new software so things can't fall through the cracks. Thanks! -Nick
  22. That's pretty much it... Thanks -Nick
  23. NDMstang65
    fi ssd and a us amps xt1600.2
    Doubt very seriously if you have room for a 18" sub in your trunk... With that said a 15 would be pushing it as is. Thanks -Nick
  24. NDMstang65
    xmax for 05 xxx
    32mm You don't want to tune a xxx to 40hz...the more of your posts i read the more i think you really have the wrong sub for what you are wanting to do... The XXX is not an SPL sub, quite the contrary actually...and shouldn't be tuned any higher then 33hz for any reason. It's made to listen to, loudly, and cleanly. Thanks -Nick
