4,860 -
Days Won
39
Content Type
Profiles
Forums
Gallery
Everything posted by NDMstang65
If it is clanging..that means the coil is running into metal. This is either caused by a leak in the box, or too much power..or a combo of both.
2500+ watts on a 1200 watt sub might be the problem man..way too much power.
Which 18" Fi subwoofer is this? Old BTL? Old Q? New BL? Double Sta
NDMstang65 replied to mobileaudiophiles's topic in Fi Products
Same parts..cooling and whatnot is way different in the new BL vs. the old BTL, just 6 years of change in technology, spiders, tinsel leads, cones, surrounds etc. -
You'll need a BL recone if you order a recone. That's a 1st gen 2 stack BTL though. -
Something is broken inside of the passenger door..if the window is down it can flop around and hit something and shatter it Pop the door panel off and start wiggling the regulator and the tracks..odds are you've broken/moved something
They aren't going to rip you off, you should have been emailed a receipt to the email address that you provided when you placed your order.
Just lowered inductance and made the cooling work better due to a better compression ratio. Yes it will work fine.
Keep in mind today is only the 13th business day as well, depending on when you placed the order. There was also a holiday in there too.
No, that is incorrect. The point of your battery is it for it to be there to start your car, it is reserve capacity. Once you have started your car you can remove the battery and it will continue to run because the alternator is running the electrical system because it produces electricity by spinning and creating a field. Do not attempt to drive the car because the alternator will full field and charge at 20+ volts because it will see that there is no battery and it will see it as "dead". To the OP - Yes, you need to add a bigger (preferably AGM or Dry cell) style battery to increase your reserve capacity for your electrical system.
Displacement is king in IB, do the math..you'd have to buy twice as many AE woofers to equal the displacement of the IB3's. From experience, around .36 on the Qts end is ideal for IB..any lower then that things start acting funky.
The magnet itself is the same size..at the end of the back plate it's pretty close to 4" if i remember off the top of my head. I don't have one around me to measure.
Stick a single 15 or single 12 in a ported enclosure with one of the down firing power ports that polk uses and use it as a coffee table, it'l work great. You could get the suspension a bit lighter on the SSD, but in all honesty you really do not need to. I've got a BTL with 5 spiders in my HT and it sounds phenomenal. Fs has absolutely nothing to do with the frequency response at all..it's just a urban myth that online junkies ride..for some unknown reason.
Before you do it, are you just wanting to use 1 large 1ohm amp now instead of two smaller 1ohm amps? If you are intending on wiring things below 1ohm for a daily scenario I would highly suggest you do not do it.
Magnet diameter is 190mm and it necks down from there on the backplate, so 190mm is the widest point that is ~1.2" from the bottom of the basket flange (pulling this off the top of my head from memory)
Cost of parts goes up and they've ate it for a LONG time..never updated the pricing accordingly. All of the stuff on the recones is written backwards for copyright reasons.
The steel parts are coated and baked..for them to rust it must be really sticky where you are. You could knock it off with a little scotch bright pad and shoot a little more silver paint on it if you'd wish, but odds are it's probably going to rust again.
sweet
Difference between 1st and 2nd Generation Q woofers
NDMstang65 replied to Ndnkobra's topic in Fi Products
The soft parts are the same for the most part, spiders are different now on the most recent versions. The motor/cooling technology is significantly different then the previous Q. It is simply a continuation in more advanced design that happens over a period of time . -
That should explain it, however you need to rough both surfaces up a bit with a little bit of sand paper, wipe both of them down with acetone and then mix a little bit of 2-part epoxy and put the slightest bit on the flanged side of the bp power plug, spin it around and let it dry over night. Hope this helps!
- 2 replies
1
- recone
- compression plug
(and 1 more)
Tagged with:
Typical for people to throw them in the box and snap the terminal off of them because they are sissies.. You can get a new terminal..looking at around 10 bucks or so to ship one to you
Law of averages..you will have some flawed magnets that will crack..it happens 1 out of every 3000 or so. They'll get you fixed up, par for the course is the dipshit postal workers to try to ram the box into the postal box out on the street at the shop..in which it jams in there and we had a hell of a time trying to get it open.
As long as they are both of the "UFO" motor style then yeah it will be fine.
It'l work fine
They will be available shortly, 3" coil 750w woofer. This is 16 of them in the green truck with ~200 watts (if that) a piece. Sorry for the quality of the video, just got the phone that I could make a video with.
