ramlion
New Members
    10
Everything posted by ramlion
  1. running 3 sa 10s in each own 1.2cube ported boxs, i dont like the 80hrzt sounds but at 50it sounds godlike,, i think the 80snds like to many tones tryn to escape at the same time in the sub for the type of music, but on bass boosted music 50hrzt just blows the doors off,sound perfect and clean
  2. ramlion
    best bass frequency for sa 10s
    What low pass freq is recommended for these subs.the boxes are tuned at 32
  3. i have the big 3 ,,0 gauged on all points , also have 0gauge ran to mount area and 0ground under 3feet,, i have a 300amp fuse, am i doin this wrong, i plan to run the amp down to a 1ohm load daily ,, will the 300 do well or do i need to step it up to a 350 or bigger,,
  4. ramlion
    new here...
    Just doin my intro.. read alot on my breaks at work.. keep getn pulled to this site to correct my so call audio install and setups.. great site ..from what I gather great group of audio enthusiast..my vehicle is in my sig.. running 3. Sa 10s dual 2ohm into a foxbox for my quad cab. .and a custom universal for center sub all around 1.2 cub space per sub. Off a lowend bamf 2000 amp. Come here to read up on the site subs and amp..before my true man up decision to purchase a bigger beefy amp...thanks for all the great info and ideas..
  5. ramlion
    proper length for ground
    thanks for the help guys the last answer was what i was hoping for... im not planing on running two 0 gauges to batery for pos and neg,, just a 3ft ground to a 12ft positive
  6. ramlion
    I want to ground 0gauge to frame on my quad cab ram.. I dont want to ground to underseat bolts or any area from the inside of cab. The shortest length from mount to frame rail is 1.5 ft to inside cab. My idea was to have a bolt weldeld to frame closest to my wire entry to cab. Is 3or 4ft ok for a ground wire at zero gauge..
  7. ramlion
    how long of a 0 gauge can i use before it becomes useless to use such a thick gauge for ground, is 3.5ft from frame to inner cab ok,
  8. ramlion
    What bout a long bolt going throught the frame..paint removed on both sides of contact points of the bolt using washers to help touch the missing paint spots
  9. ramlion
    new here...
    Sorry ,I ment sig under my avatar to the left of the post thread.. and thanks again for the hearty welcome.. cant wait to get my questions out..
  10. ramlion
    How did you guys find SSA???
    I googled a question about true amp wattage and been lurking ever since
