Howlowd
Members
    43
Everything posted by Howlowd
  1. Heading Back To AFG in the AM
  2. Heading Back To AFG in the AM
  3. Heading Back To AFG in the AM
  4. Hard to explain. Currently i have the standard single fifteen ported to the back, sub and port rear facing. I have a 03 maxima, and would be interested in sealing this to the interior of the car and firing the sub forward, with the port firing up through the rear deck into the rear window. I did something similar in my last max but still had the sub firing up. I sat i a car with two orion hccas sealed to the rear seat and ported finging up through rear deck, and NEED THAT. Anyone up to the task?
  5. Howlowd
    Any Builders Near Seattle area?
    well its weird. it was a ported box, that they built to fire the subs into th cabin of the caddy. the port went up through the rear deck. but he got 0 rattles due to the subs not firing into the rear at all. they expanding foamed all around the piece "sealed" to the passenger compartment and just covered it wit trim panels. alost like how you d go about sealin a sub ib.
  6. The tdx is the one done by you guys. wondering if you have the correct coils yet? Dual 2 ohm? and the tdx i would like to set up with dual spiders and any options if avbailable. sent an email as well. thx. SSG Douglas Sands.
  7. this rawdogj from the sphere? <--Magic Beans/Jus4SPL/Howlowd/Doug what the hell you been up to?
  8. Howlowd
    TC 9 Recone-In need of
    Can you shoot me a cost and addy, took a dive today. NEED a dual 2 ohm setup, also let me know if theres any options available. will be off a 1501d. as well any news on the TDX 15?
  9. Howlowd
    bump
  10. Howlowd
    bump
  11. Howlowd
    it was in the sig :/ thought i put it in the topic line as well its a fifteen.
  12. Howlowd
    TDX RECONE-Followup? Been a WHILE...
    thanks. ill give it a couple weeks and would you be able to email me or do i need to post back here? thank you for the help. doug [email protected]
  13. Sent two emails havent received an answer, would appreciate if you guys could hit me up. last comms you were working on getting the dual 2 ohm coils as discussed? thanks...
  14. Howlowd
    any update?
  15. Howlowd
    thanks. can you also pm me a number. as stated i have someone thats got roughly 20 tdxs he wants to get reconed. Im going to pass the email info to him as well. I appreciate it. I want to replace this tc9 bad
  16. Howlowd
    No. It hasnt been sent in yet. I want to, as the sub that was returned is a dual 1 ohm. I need a dual two ohm. that was discussed prior to sending it in,but when it showed, half the impedance. scott said he was going to verify that he had the coils, and just hasnt gotten back to me. I ended up in another NCOES school that i wasnt supposed to go to , so now its been over a month and a half. Id just like to get it going and thrown in the car at this point.. Ive also passed your info on to someone that has approx 20 of the tdx and mac daddy's for recone.
  17. Howlowd
    thanks hopefully they get to it. soon.. id imagine itll be busy as all get out once they do come back...sigh..
  18. Howlowd
    dont know when their coming back today, but ill bump it anyway
  19. Howlowd
    Diamond Audio TDX 15 Recone
    Gentlemen, The sub arrived today, and I cant say that im anything but impressed. Thanks for the extra that you put into repackaging and getting it here. Again the offer stands on the funds for the item, but either way it is appreciated. Not too often that a company stands up when something doesn't go as planned in a transaction. ITs appreciated and I definitely will be using FI in the future just because of this. I have yet to install the sub due to not knowing what the specs have changed to. If you could give me a lowdown on what i now have it would be appreciated. Currently i have an enclosure at 3.6 cubes tuned to 32 hz. Using the equipment in my sig (And an arc keq5 up front to tune the sub ). Could you give me a rundown of about what the sub now is, More along the lines of a Q or what? And recommended wattage for daily driving. THanks. Considering going back to my sealed enclosure just want to make sure not to damage the sub if its been returned as a different setup. Thanks again guys.
  20. Howlowd
    Sub showed up today. impressed with the look. Miss the honeycomb goodness but the cone that you used is a good look. thank you scott. as stated i do appreciate it, and the followup was above and beyond. thanks. only small questions niggling at my mind now though.. would like to know the specifics on how much power to tune the amp to though, running a mtx 1500 watt. dont want another episode anywhere near this as i havent blown a sub in a good number of years. Thanks. SSG Douglas Sands
  21. custom options, good follow up, and a quality hand built woofer tooled to your specs. gonna fall to box design, but i know that the brahma was an exciting woofer. Have yet to hear an xxx.
  22. Howlowd
    thanks for the contact scott. its appreciated, and the followup was above and beyond. thank you. ill update you with the results when it arrives. thank you again. SSG Douglas Sands
  23. Howlowd
    bump, didnt get an answer on the email, let me know guys.
  24. Howlowd
    thanks for the update scott. awaiting an answer on the email.
