KU40
SSA Round Table Member
    6,348
  • Days Won
    21
Everything posted by KU40
  1. KU40
    Welcome to the IHoP
    I believe I can't see it because I have them turned off so you should post it also.
  2. KU40
    2 way active, mid bass prob
    I forgot to ask this earlier, but have you tried switching the phase on one of the mids? Sometimes that helps midbass response drastically.
  3. KU40
    btl options??
    Go to the Fi website and look under the tech section. I believe there's also a sticky in one of the Fi forums on here that explains everything.
  4. KU40
    fi btl 12 opinions
    Everyone is going to say they like it. Why don't you try being more specific with your question and what you want out of the sub. Also try using the search feature. Tons of threads have already been started about it.
  5. KU40
    I need to know how much watts max this is
    i only have 1400watts max to work with but im going to use the bp power up grade By volume he means physical space for the enclosure.
  6. KU40
    Do not be a menace. If you do you will get no further support from people on this site.
  7. KU40
    Polyfill for SPL
    Oh, so you want to do like a kerf flare. Search for it on here, I'm pretty sure somebody has done a write-up of how to do it. Basically you make vertical cuts along the back side of the port that don't go all the way through the wood. This allows you to bend the wood backwards in a curve.
  8. KU40
    Do yourself a favor and stop thinking about max wattage. it means nothing. Also, I'm not sure where you got that the Q can handle more power than the Bl. Here, I'll quote from the tech section of Fi's website that you didn't read: "The BL line is pretty much a lower power alternative to a BTL or a higher power alternative to the Q series of woofers. "
  9. KU40
    Polyfill for SPL
    Run a router over the edges of the port.
  10. KU40
    Welcome to the IHoP
    Man I needed more sleep. Oh well, I have tomorrow off so I can sleep in tomorrow morning. Yeah right. I'll still wake up at 6:45-7.
  11. KU40
    Welcome to the IHoP
    It is so fun. Watching the big splash as they attack, never knowing when it'll happen then BAM. I hadn't gotten into it until this year. I carry no less than 100 top water plugs with me at all times. On the deck of my boat there are usually at least two topwaters tied on. Do they work better in shallower water though? The reason I've never really used them before is because I've never had them work. But recently on my trip to Minnesota they worked for the river I fished on, and another time at a farm pond. That's pretty much it. I can't really get any lake fish to bite them here.
  12. KU40
    I must have glossed over the sealed in .2 cubes part. I agree, you are likely choking the mid. Granted I haven't heard all speakers, but I haven't heard one yet that sounded good when it was sealed like that. Especially ones marketed for car audio use, because they are generally designed with infinite baffle application in the doors in mind. Sealing them is the opposite of what you probably want to do.
  13. KU40
    Welcome to the IHoP
    Agreed. Nuke it off the orbit. Off this universe I guess I didn't know a subwoofer is both resistive and reactive because he can wire it to 1, 2, or 4 ohms! Hey, at least we're getting new quality members. They're all experts! I can aplaude them for trying to apply their learning. But it stops there There comes a time when just making the effort isn't good enough anymore, you actually have to be good at it. I think that happens around 8th grade.
  14. KU40
    Welcome to the IHoP
    This is what ghost riding gets you: http://www.youtube.com/watch?v=o1O7ZvDFP_8 Ha, that was set up for sure.
  15. KU40
    Welcome to the IHoP
  16. KU40
    Welcome to the IHoP
  17. KU40
    Welcome to the IHoP
    I worked 14 hours on Monday as well. Outside in the 100* with basically no wind. It was a hot mofo. I drank like a gallon of gatorade, two waters, and a pop. Only the pop because the town I was in (Kirwin) is small as hell and doesn't even have a gas station, just bought it from a vending machine that just happened to be outside the place I was working.
  18. KU40
    What frequency is the highpass crossover for the mids set at?
  19. KU40
    ICON 10 problems?
    That is from being dropped, most likely from the shipping company. It may have just been a tiny crack when you put it into the enclosure for the first time and unnoticeable, but the vibrations tend to promulgate such things. I can't really hear anything in the video. But since it only got worse when you put the sub back in, maybe the gasket didn't seal well to the box this time and you have an air leak.
  20. KU40
    Noob Questions
    I think you'll want to get a bigger, better amp to do the BTL justice if you go that route.
  21. KU40
    Q 12's to 15's SQ Question
    Perhaps if you used terms more specific than the completely broad and subjective "SQ" somebody could more precisely pinpoint the differences.
  22. KU40
    problem with rlp 12
    You're welcome, Mr. Sarcasm. Do you honestly expect somebody to help you less than an hour after you start the thread at midnight? Sheesh.
  23. Seriously? If you draw more current than the fuses can handle, the fuses blow. They are there to protect the amp from drawing too much. That's their whole point of existence. ps- even if lightning struck that amp it couldnt put out 3500 watts. Not only that, but if it did you'd likely blow your 1000 watt-RMS BL sub.
  24. "Loud and clear" is not what I meant by how good your interior speakers are. What is meant is how low they can play. Woofers in a component set sound much better at 80 hz than a sub does, so if you can get away with having your component play 80 hz, by all means do it. Same with 70 hz, 60 hz, etc. So set the lowpass of the sub at a place only to pick up where the interior speakers leave off in the lower midbass region.
  25. I'm not sure why you trust winISD's FR graph, that is based on an anechoic chamber, which a vehicle certainly is not. I would contend that it's useful as a general guide, but definitely not with the specifics that your project puts forth.
