KU40
SSA Round Table Member
    6,348
  • Days Won
    21
Everything posted by KU40
  1. KU40
    How to pass a drug test.
    Quit smoking. Like, forever. This is stupid.
  2. KU40
    Welcome to the IHoP
    Just spent a 3 day weekend back at the gf's hometown of Centerville, VA. It's like 30 miles west of D.C. I believe. Lots of money there apparently, and it's ridiculous to rent or buy a house. It was a nice area though, lots of trees. Just lots of people. We went to the Air and Space Museum by Dulles airport, and that was really cool. Her dad helped work on the SR-71 and develop and test the flight suit for it when he was in the Air Force. It flew from California to DC in 1 hour and 4 minutes one time, averaging 2,100 mph. I guess it's maximum speed was 2,250 mph. Don't have to worry about SAMs at that speed, you're faster than they are. Ha. But it's entire long body behind the cockpit and the wings were just stuffed with fuel cells, and it burned through it all within 2 hours on average. That gets expensive, and the reason the plane was retired. Other interesting fact was that each pilot had an envelope with a letter and 50 cents in it, and it was for in case of a crash and somebody found the pilot they could read the letter, which said that this man is not an alien and this craft is not a UFO, and please use this 50 cents and call this number (an air force number so they could locate and retrieve the wreckage). Also, the plane was originally called the RS-71, but when President Johnson was introducing the plane at a press conference he misread it as SR-71, so it stayed that way. Ha, interesting tidbit. The Enola Gay was also in that museum. It was a bit eerie knowing its past. They also had a space shuttle and one of its engines on display. 1.5 million pounds of thrust
  3. KU40
    18" btl and a RF 4000.1bd
    Watch your voltage. It WILL sag down to 12 or lower on hard bass notes if you have the amp turned up to put out the BTL's RMS wattage. Do NOT let it sag below 12. If it does, turn your gain down until it doesn't, and leave it down until you get a larger alternator and extra battery. If you are smart with the gain and volume knobs, you will have no problem with 4000 watts on a BTL. However, I'll tell you that being smart means you won't be getting all 4000 watts from the amplifier.
  4. KU40
    Welcome to the IHoP
    The MRI yesterday showed a near complete tear of my ACL. goddammit. What is it with this board? Those of you who post regularly in here may want to watch your knees.
  5. KU40
    Welcome to the IHoP
    Knee has stopped getting better the last two weeks so I went in for an MRI today. We'll see what it shows on Friday. I want this damn thing to heal, I miss running and biking and lifting.
  6. KU40
    Homemade Subwoofer..Must watch!
    It wasn't really making any good/listenable noise, just....slapping. But I guess if you're bored and want to just rig something up, at least you did something.
  7. KU40
    1st 2010 Camaro SS with hydraulics - MUST SEE!
    I don't really understand the point.
  8. KU40
    BTL Wiring Size
    Since it seems that you already have the wire, just cut strands off.
  9. KU40
    1 15 inch FI Q and Soundstream 2500D
    Probably because you're likely clipping the amp with too high of a gain or bass boost, which sends more power than 900 watts to the sub. At full clip it could be near double that. Also, moving to an Fi section since this is just a question, no hello.
  10. KU40
    polk mom 6x9's move air........
    I'll be waiting for the post where you say you blew these too.
  11. KU40
    my xcon died :(
    Well now you're going to need $200, 100 for the alternator and 100 for the recone.
  12. KU40
    my xcon died :(
    Buy a different sub. It's users like you that give a good product a bad name. There is absolutely nothing wrong with the power handling capabilities of the voice coil on the XCON. You just clipped the amp to shit and probably sent the sub 2500 watts. I guarantee you would have blown your Kove if you had given it the power that you gave the Xcon.
  13. Stay away from that junk.
  14. No. Absolutely no difference. Once the signal is in the single positive and negative outputs before the split, it can't even tell how many splits to different terminals there are. You could put 1,000 splits with a 1,000 voice coil sub and it couldn't tell.
  15. KU40
    250w to little for power hx2?
    I can't believe the underpower myth is still around. It's the dumbest thing I've ever heard. How much power do you think your sub is receiving when you have your volume knob at 1? I'll give you a hint- it's much less than 250 watts. Chances are very good that it's even less than 1 watt. Is your sub being hurt every time you turn your head unit DOWN to level 1? Check your box for air leaks. Those sound like a tapping sound from the sub when it plays. And I'm sorry to say that your dad is very wrong about underpowering causing tinsel leads to mess up because of distortion. I don't even know how those things could be related to each other. Tinsel leads slap the cone due to excursion. If you are putting little power to a sub, unless it's in free air or below tuning in a ported box, it's not moving very much. Thus the cone wouldn't even be traveling far enough to hit the tinsel leads.
  16. KU40
    sub and amp wireing
    So........ how big is the alternator? How big is the battery? We all don't know the factory specifications for every car ever made. A 60 amp stock alternator would have very different results with this setup than a 120 amp alternator.
  17. Well it is a normal ported box. Owned. I think he means without the 3142553523521"s of port lol Yes. It's a very small net volume box. The port area is appropriate, and the length is just what was needed for the very normal tune of 33 hz. Any other ported box with those specifications would be built the same way. So
  18. Either, doesn't matter. They're fairly similar in power output, either could destroy your sub just as easily as the other with the wrong finger on the volume knob. It's all about how you set/use the gain.
  19. KU40
    sub and amp wireing
    Well you didn't tell us what your electrical system consists of.
  20. KU40
    help on MT10" db drag
    Again, change the box. Change the tuning frequency.
  21. KU40
    2.3 CUBIC FEET FRONT SLANT box
    Not at all. Moving to spl/sq/fabrication section.
  22. KU40
    Welcome to the IHoP
    Find some open country. Less things to run into
  23. Just turn your gain down. That will draw less current.
