KU40
SSA Round Table Member
    6,348
  • Days Won
    21
Everything posted by KU40
  1. KU40
    Fi bl 18
    It'll lower the power handling, but other than that it's just up to you if you like the way it sounds.
  2. KU40
    Welcome to the IHoP
    I didn't want to quote the picture post because of length so I did this one. But you went to the beach and posted no pics of babes? Man arrested at laguna beach videotaping and taking pictures of young women. I think you'll be fine as long as you aren't poking your camera 2' from a girls undercarraige. If you aren't a perv there should be no problem.
  3. KU40
    Replace 3-12q sealed with
    Just build a ported box for two of your twelves and get it over with.
  4. KU40
    Welcome to the IHoP
  5. KU40
    Welcome to the IHoP
    http://www.ddaudio.com/dd/caraudio/DD_woofers.asp?series=Z Correct me if I'm wrong, but I believe someone was burping one of these with 36,000watts. I like the non-serious write-up they did for that sub. Especially the part that says that they tried to make a machine that would measure how many watts the sub makes but they couldn't do it, so it must make a lot. haha, definitely a play on all the morons who say their subs make or push power.
  6. KU40
    Welcome to the IHoP
    I don't understand what any of that says or means, it sounds like nonsense.
  7. KU40
    Welcome to the IHoP
    I never have.
  8. KU40
    Welcome to the IHoP
    Doesn't it make you wonder how many subs it would take to do that as you drove by some ones house? NO. I could give a fuck less, my music is for me. I don't have some little penis I need to compensate for and annoy the world by driving by them and alerting them to my presence. x2.
  9. KU40
    need a clarification on "nice box"
    x2. There are some sub companies who do make good recommendations, though. I expect Fi to be one of them. Proper box depends on a lot of things, many of which are user preferences. Do you like underdamped or overdamped enclosures, high or low tuned ported enclosures, do you want something that plays certain frequencies well or one that plays evenly from 20-80 hz, etc.
  10. KU40
    Scion tC 150db box design
    Maybe make a couple of 2d sketches to show the contraption at different angles, then we can piece it together in 3d in our heads? I'll just say to make sure that you allow enough airflow around the enclosure for the subs so that the air tunnels don't act as a second port. Plus you don't want one of those situations like some people run into who use too big of a box facing backwards in the trunk, the bass just gets stuck behind the enclosure and isn't as loud as it could be if facing forward. That back wall will also have to be VERY solid, because it will try to dissipate a lot of the energy as vibrations if it can. Good luck though.
  11. KU40
    dissapointed in my score..
    Are you sure it's from turbulance and not from the increased port area? Two 6" ports do have over 1.5 times the port area as three 4" ports.
  12. KU40
    once again 2 12" Havocs on saz-1500d
    It can push them fine. You'll just probably want to get your one reconed to a dual 1 and buy a dual 1 so that you can wire the amp at 1 ohm and get the most out of it.
  13. KU40
    Welcome to the IHoP
    Had the first basketball game of the spring season tonight. We got beat by the best team in the league, but hopefully we'll win the rest of the games. aaaaaand I'm spent.
  14. KU40
    F-150 in Kennesaw, Ga
    Hello there. I'm local, but local in Kansas.
  15. KU40
    Welcome to the IHoP
    Just had a bolt of lightning followed by a HUGE thunderclap. At first the thunder was just loud and cracking and I thought it was about over, then all of a sudden it just dropped and BOOOOOOOM and it shook the house. aaaaaaawesome.
  16. KU40
    OK what would you have done 29Hz on DOWN
    barter up until you get a new XXX.
  17. KU40
    ported vs sealed
    I'd try the ported box, tuned to 30 hz. It may surprise you.
  18. KU40
    Prices?
    go on ebay and see what they're going for.
  19. KU40
    Need help with cllean sweep
    That JL FAQ question is talking about putting output wires from the clean sweep into factory amps. So if you go head unit - clean sweep - factory amp - speakers: It may not work. You're supposed to go head unit - clean sweep - aftermarket amp - speakers. If you just went from head unit - clean sweep - speaker, you just don't have any power going to the speaker because the factory head unit only puts out a signal, not actual power to power the speaker.
  20. KU40
    Prices?
    That box looks to be 2 cubes, not even close to large enough for that 15". Port is too small as well. It probably sounds terrible.
  21. KU40
    Prices?
    I don't think that's a good price, but I'd never buy an L7. But it does come in a ported box so maybe it's not actually a bad deal. Did he tell you the specs on the box? Your electrical system should be fine, if this is going in the F-150.
  22. KU40
    Monday Blue's
    The dustcap won't matter.
  23. KU40
    This sub Dual 2 ohm?
    That's due to exactly what Tirefryr was talking about.
  24. KU40
    Welcome to the IHoP
    The long par he made on 15 sealed it for him I think. After that bunker shot, he seemed pretty perturbed, but the putt seemed to bring his swagger back. That guy has got to be one of the toughest mental specimens on the planet. No doubt.
  25. KU40
    usually .7 or .8 on a 1 ohm coil.
