KU40
SSA Round Table Member
    6,348
  • Days Won
    21
Everything posted by KU40
  1. KU40
    slave amp require remote turn on?
    Some of them turn on when they sense a signal through the RCAs. But Sundown isn't one of those.
  2. KU40
    aero ports???
    Do a search on this forum, it has been brought up several times before. You'll find much info in old threads.
  3. KU40
    Fi BL 15
    First and foremost, he is confusing impedance and resistance. The impedance of each coil is 2 ohms, but the resistance is about 1.4 ohms. That's why when you wire in parallel you'll get 1 ohm impedance, 0.7 ohms resistance (aka DCR). You should probably find somebody who knows the difference between the two before you let them work on installing the equipment. As for voltage dropping too low, can't really tell before it goes into the car and you monitor it firsthand. But with a 120 amp alternator I think you'll be ok unless you play it for extended periods with the car off or at idle.
  4. KU40
    SSA's Daily fitness iHop
    Haven't been on since last week because I was out of town all weekend plus the last two days. Last Friday I did (trying to remember): Bench press tricep pushdowns decline bench military press Tricep dips About 40 pushups Ab work
  5. KU40
    Clipping
    Don't turn the head unit volume up above ~3/4 of its max. Or if you want to be exact, get an oscope and look.
  6. KU40
    Center port vs. port on the side?
    Not gonna notice a difference.
  7. KU40
    SAZ 2500
    How is the vehicle voltage?
  8. If JL won't give you a recone kit, they may not make them. Call a dealer store and ask. If a dealer can't get them either, you're SOL I'm afraid. Fi or others may be able to recone it, but it won't perform nearly the same because it will be totally differently-spec'd soft parts than what came stock with the sub.
  9. Hook it all up and see if the voltage drops to 12 or below. If it does, you need more electricity.
  10. No. You increase the chance of blowing the subs with that. Your door speakers don't have highpass crossovers on them, do they? Get some. Then you can turn the bass level on the headunit to 0 like it should be and things will be better.
  11. Just run a wire somewhere else.
  12. KU40
    Today I did: Squat 45* donkey calf raises seated leg curl Leg Press + calf presses Step-ups holding weights onto about 1.5' tall platform Lunge dips Ab twists on cables 3 miles on bike about as fast as I could go, steady 100 rpm for ~11 minutes
  13. KU40
    Welcome to the IHoP
    The gf is coming back tomorrow after 3 weeks in Ohio. I gotta shake off this distress from the last few days to perform. Or maybe it'll be great and help me work off stress. Speaking of stress relief, trying to motivate myself to go to the gym now. I'm pretty tired. But I should go. The last time I went was.......shoot like Saturday.
  14. KU40
    Welcome to the IHoP
    Oh snap! Dont u live in an apartment? Where did u have it at? Yeah. It was on my back porch. I didn't have anywhere to enclose it. I'm so full of rage I'm not sure how I'm going to work today. Sleep last night definitely wasn't the greatest. Woke up for an hour at a time a couple times, just watching my back porch light and listening to my apartment actually hoping somebody would show up so that I could beat the fuck out of them. I had two dreams and both were about it. I live in about the nicest part of the city, nothing out here is more than 10-12 years old. I thought I would be away from that shit. is it sort of a fenced in porch? Unfortunately no. Just recessed into the side of the building to a sliding door that goes to my bedroom. They didn't take my smoker, and that thing's much easier to carry. hmm.
  15. KU40
    Welcome to the IHoP
    Oh snap! Dont u live in an apartment? Where did u have it at? Yeah. It was on my back porch. I didn't have anywhere to enclose it. I'm so full of rage I'm not sure how I'm going to work today. Sleep last night definitely wasn't the greatest. Woke up for an hour at a time a couple times, just watching my back porch light and listening to my apartment actually hoping somebody would show up so that I could beat the fuck out of them. I had two dreams and both were about it. I live in about the nicest part of the city, nothing out here is more than 10-12 years old. I thought I would be away from that shit. Bummer man. You know, the best place for a thief is in the newer, nicer apartment buildings. Easy access (it is just a byproduct of apartment life) and the quality of the items are far better then they are in the hood. Yeah, quite unlikely to find a $400 grill behind any house in the hood. One of the MANY reasons I hate apartments. However, I had no choice really since I have been trying to save money for a real house. Figured I'd bite the bullet for 2-3 years to be in better position then.
  16. Here is a lot of your problem I bet. Set this to flat (0). What you were doing with that was cutting the signal at the head unit, then using the bass boost on the amp to effectively try and ramp it back up.
  17. Kinda OT, but what is the Bass EQ good for then? Seems like it's pretty pointless? Marketing to unknowing young'uns. To the OP, turn the bass EQ all the way down. Turn the low pass filter to around 70-80 hz, and if it has a subsonic, turn that to 28 hz or so. I imagine that amp has a switch for high pass/low pass crossover? Make sure it's on low pass. Are the RCAs from the head unit on a dedicated sub output? Does the head unit have a subwoofer level control setting (like 0-15, etc.)?
  18. KU40
    SSD 12 Question
    What is the tuning frequency
  19. KU40
    11cuft net too much?
    It will make noise. Power handling will be very reduced in the larger box, though, so lower the gain accordingly or else you're not going to have any subs.
  20. KU40
    What is my setup worth?
    Maybe 60-70% of whatever you paid for it.
  21. KU40
    atomic audio.
    Basically every recone costs 80-100. I actually haven't seen many if any cheaper than that.
  22. KU40
    Welcome to the IHoP
  23. KU40
    Welcome to the IHoP
    WHAT THE FUCK, SOMEBODY STOLE MY TRAEGER GRILL
  24. KU40
    What fits my needs? Fi Q or BL?
    You sound like a BL buyer.
  25. KU40
    Upper Body Work outs
    Check the date buddy, two years ago.
