KU40
SSA Round Table Member
    6,348
  • Days Won
    21
Everything posted by KU40
  1. KU40
    Welcome to the IHoP
    Time for a run along my new route. It should still be about 2 miles.
  2. KU40
    Welcome to the IHoP
    Sorry, apparently you guys get to hear my struggles through singlehood. Haha. I'll try to keep it down.
  3. KU40
    Welcome to the IHoP
    Have a lunch date on Saturday with a girl I haven't seen in about 4 years. Though I'm not sure if she has a bf or not, so maybe using the word "date" is stretching it.
  4. KU40
    Welcome to the IHoP
    one of the girls above me is moving out. darn. But I did see an attractive one get into her car this morning at the same time I did. I wanted to say hi but didn't. dammit. next time gadget, next time.
  5. KU40
    Welcome to the IHoP
    Took off work tomorrow, so three day weekend has begun. Sitting by the pool tomorrow fo sho
  6. KU40
    Frontend System
    I haven't bought components in 5 years and haven't stayed up on them.
  7. KU40
    How efficient is the Z15?
    I fixed your title.
  8. KU40
    Rear-Firing in Single Cab?
    How in the world do you have 12.5" behind the seat in a single cab? Are you 4 feet tall? At any rate, front firing is generally the best solution in a single cab.
  9. KU40
    port vs Sub location
    You don't have to use expanding foam. You can just cut out extra baffles of wood to cover the space and attach them onto the sides and top of your enclosure to create more of the wall effect.
  10. KU40
    Welcome to the IHoP
    to your moms, I came to drop bombs
  11. KU40
    Midrange amps
    Yeah, component sets are worlds better than coaxials. You can put crossovers on each speaker individually, you can change the mounting location of the tweeter for the best sound, the mid doesn't have a big hole in the middle of it for a tweeter stand, etc.
  12. KU40
    Got a Problem - Need Solution
    I'd put the subsonic around 27-28 hz. Lowpass no higher than 80 hz. 70 hz is even better. But this depends on how the sub sounds playing those frequencies and how low your interior speakers will play effectively. You'll want to balance the two. Gain setting depends on the input signal voltage from the head unit. You match the voltage through the RCAs with the gain voltage. That will give you maximum power. however, since you probably don't want to go that high with the power right now, you'll just have to play it by ear.
  13. KU40
    gaahh one of my subs blew
    Is the box sealed? Ported? Take some measurements so we can figure out the size of the box, and if it's ported, take measurements of the height, width, and depth of the port. Take the sub out of the box. If there are rips in the surround, spider, disconnected glue joints, etc., it's mechanical. If you can smell burning, can see a darkened voice coil through cooling holes, or the cone of the sub will not physically move and seems frozen in place, it's thermal.
  14. KU40
    Powering a sundown 4500d
    You'll want basically as large of an alternator as you can find for your vehicle and at least one extra battery. For wire size, at least 1/0.
  15. KU40
    Is this going to be a wall? Or almost a wall? having the subs face forward in an SUV in a non-wall situation is not ideal. It is like putting your home subwoofer in the middle of the room. If you've ever been in that situation, you know that's not ideal. Loading the sub in a corner of the room is much better. Same with a vehicle. If it's not a wall, you'll want to face the subs either back or up.
  16. KU40
    Dc Level 5?
    Just fine. There's no such thing as underpowering.
  17. KU40
    Welcome to the IHoP
    So you just gotta make him believe the right!
  18. KU40
    Do you mean that's the highest impedance that it's rated for? If so I guess technically that's all that Sundown posts for the amp, but that's just because nobody in the car audio world runs subs at higher than 4 ohms so it's worthless to publish the information. But it would have no problem running at 8, 16, or 1000 ohms. It will just reduce power output accordingly. As for putting in the 2000d, it sounds like you may have already done that. But I say go for it. Just watch the voltage, and I'd try to not go below 12.5 or so. That will put you on the edge of the alternator's output capabilities.
  19. It only has high pass crossovers that low? that stinks. Well, no, it's not very good for an active 3 way system. Although not all is lost, you could get something like a sundown 50.4 for the midrange and tweeter. Use the highpass on the amp for tweeters on channels 1 and 2. On channels 3 and 4 for the midrange, use the lowpass and subsonic filters to bandpass the speakers. Then get another 2 channel amp and use the lowpass on the amplifier and the highpass from the head unit to bandpass filter the woofer in the system.
  20. KU40
    Welcome to the IHoP
    I still need to put together my bedroom. It's a mess.
  21. KU40
    Difference in Cu. Ft.
    Short answer, no. Probably imperceptible. But it'll go a touch lower.
  22. KU40
    powering flatlyne
    It would work fine. You should never have to worry about blowing it that way.
  23. Active 3-way would be the best, but perhaps most pricy, option. You'll buy an 8" woofer, 3" midrange, and tweeter. Then you'll need at least a 4 channel amp and a 2 channel amp. Does that Kenwood head unit have any crossovers on it?
  24. KU40
    What box? What amplifier? Was it mechanical or heat-related damage?
  25. KU40
    Welcome to the IHoP
    Haha, that is AWESOME
